Rudder not working right.. help!
Old 08-04-2021, 09:23 AM
Danni
Default Rudder not working right.. help!
Hello, I need some help!
Today when i was about to go fly, my rudder started acting up.
So, the issue is quite weird and i dont really know how to explain it but..
when the motor is all the way off, my rudder is all the way to the left, and i am not able to turn it at all. It is just stuck. But if i increase the throttle to about 25% then the rudder suddenly moves to its default position and i now have full control over the rudder and can move it both left or right as normal.
But then again if i increase the throttle to about 75% and above, the rudder goes all the way to the right this time and i am again unable to move it out of there unless throttle is decreased.. so it is basically kinda linked to the throttle in a way, and i have seen nothing like it before
This has issue has appeared during the couple months that the plane has been sitting due to some new flying restrictions. And i had none of these problems the last time i flew. But now when i finally have a license i am not able to fly. Please help!
(I also have a video but i didn't see a option for it here)
Any ideas what the issue could be?
Danni is offline
Old 08-04-2021, 11:21 AM
Video needs to be hosted by Youtube or other such as Vimeo.
What radio Tx and Rx do you have ?
It sounds like throttle and rudder have become 'mixed' .... so what radio you have can help us to think what it might be.
OK - lets try a few things ..
REMOVE PROP
I would say disconnect throttle, connect to another slot in Rx. Now try rudder see what happens.
Next - reconnect throttle to its proper slot and move rudder to different slot and see what happens - it will mean using different control of course on Tx corresponding to where rudder is plugged in.
Trying to understand if there's any crossover between the two functions.
Question - do you use the Tx on another model ? Is that also acting strange ? Are you mode 1 or mode 2 ? Are throttle and rudder both on left stick ?
Old 08-04-2021, 11:58 AM
Danni
All right here's the link for the video:
As for what radio i'm using it is an FMS 6 channel radio that came in the PNP kit with the plane. It is a FMS FXH-1280 plane and all i really know about the radio system is that it is 6 channel.
No i don't use this radio on anything else as it feels quite cheap and bad overall, i have had some proplems with the reverse aileron button switching mid air so i have been thinking about upgrading the system anyway. And i dont know what mode i'm in. How do i check?
Danni is offline
Old 08-04-2021, 11:59 AM
Danni
I will now try what you suggested
Danni is offline
Old 08-04-2021, 12:14 PM
Danni
So i connected the throttle to CH 6 instead of 3 that it was in, Still same problem except that the throttle obviously didnt work since i swapped ports. The rudder didn't turn before about 25% throttle and so on..
Next i connected the throttle to it's correct place as you said and put the rudder on the switch instead, this time the rudder was controlled by the 2 position switch as it should have, and no matter the throttle position it stayed in place as it should
So it seems like CH 3 and 4 has some kind of mix as you said. The controller has always been a bit iffy so i suspect that's the issue
Danni is offline
Old 08-04-2021, 01:28 PM
OK ... Mode 2 is Throttle and Rudder both on left stick. Judging by your video - you are Mode 2.
It sounds like you may have a gimbal problem ... that movement of one axis affects the other axis.
Is the model / radio still within warranty ? If so - go back to dealer and request solution.
If not - then you might remove back of TX and then check that Gimbals are working and fixed properly. .... any loose wires / connections ..
But yes .. FMS is a recognised brand and has provided good for many - but that radio does not inspire me with great thoughts. You will soon be looking for better and a move up in model ... so I would start thinking about what you are going to do.
Old 08-04-2021, 01:52 PM
Danni
OK
Then i'm defintly mode 2.
I will check warranty, but if the warranty is expired then I will probably just buy a new TX.
I was about to buy a new one already after the time when the controller suddenly reversed the ailerons mid flight and I almost ran into a tree. So I have had some serious trust issues with it already
Thank you so much for the help! You figured out what the issue (probably) is!
Danni is offline
Old 08-04-2021, 07:33 PM
One question is what radio Format the FMS uses ... because it may be possible to use a Multi Protocol Radio and still have the original Rx in the model.
To be honest - I would suggest a Multi Protocol Radio anyway ... but not the Lite versions ... that way - you can literally fly anything with the one radio. You don't have to worry about Spektrum .. FlySky ... Futaba ... FrSky etc. - it works with most their systems. You get amazing mixing and combos of channels / functions. The price is also attractive with greater abaility than the proprietary Branded radios.
But that's my view ... I have the Radioking TX18S as my latest radio ... superb radio ....
Old 08-05-2021, 06:43 AM
gyrocptr
[This has issue has appeared during the couple months that the plane has been sitting due to some new flying restrictions. And i had none of these problems the last time i flew.]
This is a WAG. Try disconnecting (removing) battery from the transmitter, and then reinstalling the battery. This may reset the "computer".
gyrocptr is offline
Old 08-06-2021, 06:12 AM
Danni
To be honest - I would suggest a Multi Protocol Radio anyway ... but not the Lite versions ... that way - you can literally fly anything with the one radio ....
Allright that sounds great...
​​​​​​​ i will definitly take a look at hat
Danni is offline
Old 08-06-2021, 06:19 AM
Danni
I Will definitly try this aswell.
Sounds like an easy fix
Danni is offline
05-27-2020 06:48 PM
Karnsy
Seaplanes E-Powered
07-23-2018 02:28 AM
Quick Reply: Rudder not working right.. help!
Page generated in 0.10321 seconds with 11 queries
