Buying an Miss wind s 50
Old 04-06-2021, 06:47 AM
khaldrogo
Default Buying an Miss wind s 50
Potential New Brand: The Best Corded Vacuum Cleaners Worth Buying From VAX
Vax is a popular vacuum cleaner company in the United Kingdom with extremely quality product lines. However, mainly this company only produces domestically so it is not too popular in other markets.
It took me long enough to learn about vacuum cleaners or was introduced to this company by England friends before I knew about it and was really surprised.
Today's article will give you useful information about the 3 Best Rated Vacuum Cleaners - The Best Vacuum Cleaners from Vax.
About the brand Vax
Vax UK Ltd was founded in 1977 by Alan Brazier - an expert in industrial carpet cleaning.
In terms of vision, Vax aims to become a manufacturer of electrical appliances and cleaning products specializing in the field of air handling and floor care.
Although Vax's vacuum cleaner has a much higher cost than other equipment on the market, it is still appreciated by many superior products in terms of design, features and technology.
Top 3 best-rated vacuum cleaners of Vax (Wired vacuum cleaner line)
1. VAX Air Lift Range
Described with adjectives like Powerful, Multi-spindle and the UK's lightest corded vacuum - the VAX Air Lift Range seems confident in what it does.
The machine is priced at $120 in the UK market and has the following features:
  • Powerful performance, strong suction for comprehensive cleaning both on carpets and on hardwood floors.
  • Multi-cyclone technology with the advantage of not losing suction power during the cleaning process. The suction power of the machine is always maintained and evenly distributed throughout the entire working time to help the house stay in the cleanest condition.
  • Separated machine parts that can be form a handheld vacuum cleaner
  • Lightweight, only 3.5kg for the detached body. Although it is a corded vacuum, the total weight of the VAX Air Lift is extremely light, notably the weight of the detachable body which is considered the lightest among the separate bodies.
  • Flexibility: With a separate design, this best-rated vacuum cleaner allows you to flexibly move between many terrains from home, carpet to car…
  • Flexible movement technology: helps move the machine between gaps, obstacles more smoothly
2. VAX Air Stretch Range
This is also one of VAX's Best Rated Vacuum Cleaners with these features:
  • Extremely powerful suction, the total weight of the body and the machine is only 5kg - very easy to move even if you have stairs or rough terrain
  • Price: cheaper than Air Lift Range (only $100)
  • Equipped with an extension hose and an extension cord. The total length of the machine can be moved up to 17m
  • Diverse nozzles suitable for every terrain in the house
3. VAX Air Cylinder Range
This is a good vacuum cleaner in the $90 price range. Some advantages that you will enjoy when buying the machine:
  • Cheaper than the previous two with similar technologies and performance
  • Advanced HEPA filter blocks 99.98% of dust and allergens
  • Large dust capacity allows long-term cleaning in large spaces without constant dusting
  • Turbo tool removes dirt, debris, fur, hair... in the house thoroughly
Although VAX is still quite new to a large number of foreign users, it is one of the top rated vacuum cleaners in the UK. Indeed, when you have tried VAX's vacuum, it will be difficult to criticize any points except for the slightly high price.
khaldrogo is offline
Old 04-06-2021, 07:01 PM
Past President of PSSF
Here is the data from Scorpion, should be able to find a good system from this.
http://www.scorpionsystem.com/files/...data_chart.htm
Wildflyer is offline
Crash and Safety Forum
2155
02-09-2019 10:50 AM
hayofstacks
03-05-2012 01:07 AM
02-13-2012 05:24 AM
Wiki Discussion Threads
06-20-2011 12:43 PM
Off Topic Chit Chat
25
06-07-2011 06:52 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: Buying an Miss wind s 50
Page generated in 0.07257 seconds with 8 queries
