Horten Bros Ho-229...in "Five Easy Piece"
Bobdaeronort
I was thinking about an Single 70mm EDFb too. But will most likely do a mid-prop setup.
I've been using KFm4 airfoils with CR on the leading edges and across the center in an 'A' frame config on my B-2 and PAK DA flying wings. My aerial cam vids with my B-2 have not revealed any wing tip flutter. I have seen the whole back-end of the B-2 flutter at high speeds and in heavy winds a lot though.
If you like flying wings check out my threads on the B-2 and PAK DA flying wings.
Bobdaeronort
Bobdaeronort
The powered version takes shape...
I have completed the build and tested the gizmos as well as loaded the wing and tossed her heavy for the final glide tests.
And now for the maiden flight...
Bobdaeronort
Bobdaeronort
Bobdaeronort
Bobdaeronort
Bobdaeronort
Here is the PDF Plan link for the "Five Easy Piece" Horten 229.
http://www.mediafire.com/view/5a9e8o...Horten_229.PDF
http://www.mediafire.com/view/q3dyni...29_A4tiled.pdf
http://www.mediafire.com/view/h8zkos...9_LtrTiled.pdf
Build video soon.
Build video soon.
Bobdaeronort
Bobdaeronort
Sortie II
http://youtu.be/f84kdXUHwbU
Bobdaeronort
Bobdaeronort
http://www.wattflyer.com/forums/showthread.php?t=71752
http://www.wattflyer.com/forums/showthread.php?t=71810
Bobdaeronort
I will do that soon, I got to finish up on my F-20 Tigershark for the Contest here, since your a scratch builder, come on in and join us
Bobdaeronort
Bobdaeronort
Bobdaeronort
Bobdaeronort
