Having problems with my new blade cx2 heli
Old 12-27-2008, 07:10 PM
cbflight92
Default Having problems with my new blade cx2 heli
I have just bought the aluminum lower rotor head for my blade cx2 and i can figure out how to put it on, i can not get the shaft out to put it on or anything so please would somebody inform me how to do this or give me a link
cbflight92 is offline
Old 12-27-2008, 07:37 PM
theecoop
theecoop's Avatar
look here. http://www.dacaur.com/heli/bcxhelp/BladeCXAssembly.pdf
theecoop is offline
Old 01-12-2009, 05:33 PM
schreydog
Default aluminum rotor
you don't have to remove the shaft, just loosen the two set screws on the bottom gear and pull the inner shaft. remove bearing on top,separate the linkage from the swashplate. loosen the four screws on the old rotor and it will slide off. sometimes you have to get sandpaper to remove burrs. when you put the new one on, do the top screws first as they must line up with the two holes you'll see on the outer shaft. also fyi, if you ever do pull the outer shaft, there is a brass step washer on top of the gear, keep track of this asit won't fly without it. schreydog
schreydog is offline
Page generated in 0.08572 seconds with 9 queries
