Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
Old 06-25-2017, 11:04 PM   #1
F22trainer
Default Guillows P-38
Guess I should start the build thread before I get too far. All the plumbing is in. I spent a bunch of time beefing up the tail assembly and the stabilizer had to be rebuilt as it has some ugly warps, twists and gaps. The wing tips will get cut off and replaced a carved solid balsa taper to make it easier to sheet. One of the next steps is putting her on a diet...hole punch for wing ribs and formers.
I know I posted up some photos in another thread, but figured this was the right place to continue. All up it is 14.6 oz now, sans batteries (380mA /7.4V). Not sure where the CG is right now, but have plenty of space (if that's really possible) in each fuselage near the CG point.
Now for the really clever stuff...I figured out how to use the scale cutouts in the cowl and fuse scoops to be functional for cooling. Each section can be removed with a few screws or nylon bolts, except the vert stabilizers. Once they're covered and epoxied - they will be permanently attached - rudders can be removed to separate fuse from tail. Though I don't plan on doing that on any regular basis.
F22trainer is online now
Old 06-25-2017, 11:42 PM   #2
F22trainer
Couple of more photos I don't think I posted.
Old 07-09-2017, 08:56 PM   #3
F22trainer
Default Update on progress
Balsa sheeting has begun. Did an engine run and servo test and everything checked good. Battery box fits nice just slightly behind CG point with easy access under 'supercharger' cover. Plank sheeting worked good on lower fuselage half.
Old 08-17-2017, 05:21 AM   #4
F22trainer
Busy with work so have not had much time with the hobby stuff. Got a few shots of the wing sheeting underway.
Old 08-30-2017, 02:43 AM   #5
F22trainer
Default Post balsa sheeting
Balsa covering nearly done, reassembly to check fit under way. I'll try to get a video of start up tomorrow.
Old 08-30-2017, 12:30 PM   #6
Stay Quiet
Stay Quiet's Avatar
Club: Campobello Flyers
Very nice work! The P-38 has always been one of my favorite WW2 planes.
Stay Quiet is online now
Old 09-02-2017, 03:39 AM   #7
F22trainer
Default ...and now the fun begins!
Started dialing in the tail feathers and got all controls working from radio. All smooth - did get some "chatter" from the aileron servo - any ideas or worries? One vertical stalizer was covered at the end of the day, but I will post up some pics after tomorrow when more is done.
Old 09-05-2017, 01:56 AM   #8
F22trainer
Default Covering process and progress!
Tedious...
Old 09-11-2017, 04:26 AM   #9
F22trainer
Fuselage sections covered.
Old 10-07-2017, 03:56 PM   #10
F22trainer
Default Update
Final assembly underway, those plastic pieces are actually fitting pretty good but a few got deformed over the years and seems the heat gun is an essential tool. Don't want to get crazy with the details until after the maiden flight...
Stay tuned -
Old 11-05-2017, 11:14 PM   #11
F22trainer
Maiden flight is coming soon. Now for the question, should I put a gyro in it? Since I will not be the one flying, I suppose it could be off for the first flight a get all the trims set up. I have a great 'instructor' and test pilot at the AMP's club here in Phoenix. My thumbs are getting back up to speed.
The Lightning is at the point where I want to fly it before I spend any more time on finishing. I did a start up and taxi and was impressed with the ground handling. Made some minor linkage adjustments and changed the rudder control cable to a solid wire. The single aileron servo was just not enough and shoe horned two metal gear servo in the wing. When I build the next one it will definitely get micro's in the wing. Now I found a new issue. Rapid movement of those ailerons causes brownouts - normal movement has now issue. I do not plan to do aerobatics with it so I can live with it if it would not be a safety issue.
Thoughts?
Old 11-06-2017, 12:43 PM   #12
Friends: (10)
Gyros are quite useful especially on smaller planes as they help smoothen the flight and make the plane less effected by wind gusts etc. Usually they don't really make the plane easier to fly as such, just smoother looking in flight. For the maiden you would want to either disable the gyros or at least have the gain set low. Too high gain can cause violent oscillations which is the last thing you need on a maiden.
Good luck, she looks great!
Old 11-25-2017, 12:54 AM   #13
F22trainer
Thanks JetPlaneFlyer,
Still making some tweaks and tests. Did do some taxi tests and got it tracking straight, even got up a little speed but backed off as she started to rotate - woah girl. Tweaks are kind of a pain, as I wind up having to remove the wing. Got one more to take out some elevator and get it centered. Hoping next weekend I can take two planes to the field.
I'll hold off on the gyro for now, but she is small and could probably use it later on. Kinda crowded in those little fuselages.
Old 12-18-2017, 03:56 AM   #14
F22trainer
Default ...and here we go -
Might get maiden flight next weekend, but got the final tweaks done in time to get this before sundown. Took it by LHS last weekend to get a second set of eyes to look it over. Discovered a few other things after making he recommended adjustments so was glad I made the effort.
https://youtu.be/XRYaQzQlpgU
Should I be concerned with calibrating the ESCs? They are both right out of the pkg. defaults. Suppose I should get a meter.
https://youtu.be/HbA15pYCy5Y
Other than that, everything indicates she is ready for flight.
Old 01-04-2018, 04:19 AM   #15
F22trainer
Default Good news
It's still in one piece!
Old 01-05-2018, 03:47 AM   #16
jeholliday
Looks great sitting on the ground. Need an in flight photo.
jeholliday is offline
Old 01-07-2018, 08:03 PM   #17
F22trainer
Working on it...maiden flight aborted.
Old 02-02-2018, 04:12 AM   #18
F22trainer
A few more tweaks are in order:
https://youtu.be/luDBK99t9fE
First, 3S batteries instead of the 2S 430.
Batteries need to shift forward all the way to wing LE in order to fit under covers
Receiver gets moved more forward
Nose weight will have to be reduced to meet CG after mod's - but that means it will be lighter, and that 's a good thing.
Old 02-02-2018, 05:37 AM   #19
jeholliday
It looked fast enough in the video. Maybe good thing it didn't get airborne.
Old 02-02-2018, 01:09 PM   #20
F22trainer
Funny, Dave and I said the same thing...
Might be time to just get busy with ver. 2.0.
Old 02-21-2018, 08:54 AM   #21
Seattle
This is a magnificent project that took a lot of dedication. Decades ago we had to do it this way, but the ready availability of foamies has got us spoiled.
I noticed that it's been 20 days since your last post, F22trainer, before the maiden flight. With so much hard work that went into it, I'm afraid to ask what happened. I'm guessing she might have had a discouraging encounter with the ground?
Seattle is offline
Old 02-21-2018, 01:22 PM   #22
F22trainer
Actually, she is still in one piece. Making some changes to redistribute and remove weight. Needs a 3S instead of 2s which is easy enough. But wing loading is really high and I want to do what ever possible to get it down. Receiver is getting moved, battery box enlarged and moved, and nose weight reduced to balance.
She will fly.
Old 02-21-2018, 02:50 PM   #23
Seattle
You have something non-existent in Seattle: A perfect field for high wing loading. Plenty of room for long approaches, no obstructions, a long paved runway.
Hopefully you've got sharper eyesight than I have; with the smaller size and the need for speed,that would help.
I raced small planes and learned this the hard way: Look sharp when the sun is low and wear your baseball cap.
With the CG comfortably forward, and more power from 3 cells, she might fly like a lead sled, but who cares? That P-38 shooting by like a silver bullet on a low pass is going to be glorious.
Sincere best wishes for success.
Seattle is offline
Old 02-21-2018, 10:21 PM   #24
F22trainer
Your can be assured the flight will be documented - good or bad.
Thanks for watching the thread and your wishes for success. I do miss the Northwest - in the summer.
Old 02-26-2018, 05:53 AM   #25
Seattle
Come visit us when the ground dries out, maybe in May. The whole place is saturated now, rain and snow.
Did you have a chance to try flying again this weekend?
Seattle is offline
Guillows Stearman Bill G Scratch and Kit Built Aircraft 45 01-14-2017 03:08 PM
Guillows 24" Beaver Bill G Seaplanes E-Powered 8 08-14-2016 01:02 AM
3rd Times a Charm, Ain't No Chance of Being Tail Heavy, Guillows 16.5" FW190 Bill G Scratch and Kit Built Aircraft 17 03-23-2012 01:42 AM
38 inches yak 55 harrys 3D Flying 3 12-11-2010 10:26 AM
Page generated in 0.24280 seconds with 111 queries
