Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 10-01-2017, 04:08 PM   #101
Friends: (19)
Old 11-30-2017, 04:13 PM   #102
Friends: (19)
Just knocked up another Mig 29 in 6mm Depron ..... stiffened with 2mm CF rods.
Fuselage where G&G uses two foamboard sandwiched ... I used 3 Depron ... and then thinned where tabs engage matching holes.
I moved motor forward and used the common 2826 2200kv Turnigy motor ... but with a 5x5 prop ... I'm hoping to stick a 4S into this one ...
Funny enough my 6x6 prop was just a touch big ... so I must have made slight error in tracing / cutting. No worries ... 5x5 will be fine.
Have to figure out a colour scheme ....
Old 12-01-2017, 07:53 PM   #103
Friends: (19)
I altered servo position ... cut slot bigger and fitted 6x6 prop ... so back to 3S but I can always swap out to 6x4 and use 4S ..
Just need a couple of screw connectors for rods and weather to improve ...
Old 12-02-2017, 12:15 AM   #104
View Don Sims's Gallery114
Friends: (40)
Looks great Nigel. Linked my neighbor to this thread, he's getting into making planes out of foam board.
Don
Old 12-02-2017, 09:58 AM   #105
Friends: (19)
I'd draw up plans - but I have no way to scan and digitise.
For the price of the G&G planes - worth buying the kit ... then do as I did : Trace round the parts onto card or thin board. I used 3mm Depron.
Old 12-03-2017, 12:00 PM   #106
Friends: (19)
Original G&G Mig 29 weighs in at 255gr + battery
Depron scratch version weighs in at 253gr + battery !!
I've tested the 2826 2200kv on 3S 6x6 prop and it kicks 22A
Drop back to 6x4 and she kicks 18A on 3S and 27A on 4S ... 4S 1600 weighs similar to the 3S 2200 ... so I have choice ...
The thrust on 4S is WOW !! I can't wait for weather to break and I can get out there with it !!
Page generated in 0.10653 seconds with 32 queries
