Home made charger?
Old 08-28-2015, 10:55 PM
Ben123456
Build Review Home made charger?
I have a 9.6 volt 1200 mah NiMH battery and lost the charger for it. I have a cord to plug into an outlet and alligator clips to attack to the battery but will it charge the battery or destroy it?
Ben123456 is offline
Old 08-28-2015, 11:15 PM
Its a question of what will happen first:
Battery can explode.
Blow the fuse or trip the circuit breaker
Burn down the house.
Could do all at once.
Old 08-28-2015, 11:32 PM
BTW... I have seen a few NiCds explode from accidental improper charging... Never seen a LiPo burn without purposefully being punctured to burn it.
When NiCd explodes its like a small grenade, throwing bits of metal at high velocity and having a small fire (which can spread).
Old 08-29-2015, 12:20 AM
Ben123456
Ok thanks I will just buy a new charger. Its not worth getting my hand blown off haha
Old 08-29-2015, 12:38 AM
Motionrc.com has a really nice AC/DC charger for $60
Similar to the Turnigy AC6, but higher output (probably relabel of the updated version of the same charger)
Old 08-29-2015, 06:57 AM
The Accucel 6 is in two forms .... the common 50W one and also the Eco6 one of 80W, which I bought recently and is actually a very nice budget charger.
I just do not understand why they insisted on an XT60 power in cord ?
Old 08-29-2015, 10:02 PM
Two or three years ago, a club member just finished charging his Nih battery pack in our shelter. Took the model to the flight line, and heard a real loud POP!
That Nih battery blew off its top, went through the side of the model, and went completely through another model located some 15 feet away.
These Nih batteries are equipped with a pressure relief vent to prevent this from happening. They don't always work.
(Wrong setting on the charger)
Old 09-17-2015, 03:38 PM
Jayd3
JayD
The other problem with making a charger from lets say a dc wall pack of 12 volts 200ma is you have no delta peak detection so you woun't get as good a charge.
A charger for just Nmih and Nicads is quite inexpensive I have bought a couple off of Ebay : Hobbico multi charger and a field charger both where around $10.00 Now They will not do Lipos ! and that is why people are selling them cheap. I even have a like new DC peak detecting hitec multicharge here I am likely to sell soon starting at a price of like $5.99
it's just not all auto and is DC input so it may not even sell
Jayd
Jayd3 is offline
Old 09-20-2015, 04:25 AM
Past President of PSSF
It doesn't even take an improper setting on a fancy charger to blow a Ni-cad. I had a 450 mah cell blow apart using the 50 ma over night charger that came with the system.
So far, I have more problems with bad nicads than bad lipos.
Wildflyer is offline
02-27-2012 09:18 PM
Howard Matos
FMA Direct
10-25-2011 08:03 AM
SimonXi
08-17-2011 12:02 PM
Howard Matos
FMA Direct
07-28-2011 03:04 PM
Bomb Dropper
Seaplanes E-Powered
13
03-12-2011 04:33 PM
Quick Reply: Home made charger?
Page generated in 0.12149 seconds with 13 queries
