A Slow Stick post for the Slow Stick fans
Old 04-18-2006, 12:32 AM
skiman762
FFFC
skiman762's Avatar
Originally Posted by Bill G View Post
When I first read the "2 wings" part, I thought you were making a Slow Stick biplane. Now there's an idea. Would be a trip.
I think the problem might be supporting the two wings on such a small
boom tube but I know it's been done just doesn't look all the good most times
skiman762 is offline
Old 04-18-2006, 12:41 AM
skiman762
FFFC
skiman762's Avatar
How about a ducted fan SS biplane with the engine between the two wings and a twin boom setup like a p-38 twin rudders and 4 ailerons.... ummm have I lost my mind
there goes this months budget
Old 04-18-2006, 12:44 AM
qban_flyer
Guest
Posts: n/a
Originally Posted by crxmanpat View Post
Here's a couple of Bipe pics for ya!
Pat
That "Push Me - Pull Me" bipe version is a riot!
Old 04-18-2006, 12:45 AM
crxmanpat's Avatar
Originally Posted by bsoder View Post
So you think that 8x6E is going to be the way to go? Did you try the 9x4.7SF?
Tried the 9x4.7 over the weekend. I can definitely tell a drop in performance. I measured the 8x6E with the watt meter and got 14.5 amps static, 148 watts using a TP1320 3S. Amp draw is probably slightly lower in flight. I'll stick with the 8x6 for now unless I have another failure real soon.
Pat
crxmanpat is offline
qban_flyer
Guest
Posts: n/a
Now, that's what I call a novel concept.
Old 04-18-2006, 12:47 AM
crxmanpat's Avatar
That one is by a guy called "boomer" over on RCGroups. He is the ultimate Slow Stick perverter. He is the one with the 8 motor (yes, I said EIGHT MOTORS) version. He has tons of pics and vidoes posted over there. Some of that stuff is just jaw dropping awesome.
Pat
Old 04-18-2006, 12:52 AM
skiman762
FFFC
skiman762's Avatar
Pat
I saw that one pretty wild
I have enough trouble buying them one at a time..
Old 04-18-2006, 01:03 AM
LOW-N-SLOW
LOW-N-SLOW's Avatar
Hmmm. My SS just LOVES my 400XT bl swinging an APC 8x6E and 3S lipo!
Pat
I'm sure it does. I'm not saying it won't work, thrust is thrust and if you flail away with a little paddle hard and fast enough even a battleship will move. But it sure takes a lot of energy.
If you could gear reduce your 400tx to turn a 10 or 11x4.7 at 5500 rpm I think you'd see amps drop by 30 to 50% and slow speed control would be much crisper with more air pressure on the control surfaces and quicker acceleration on throttle up.
I think...
therefore I am...
probably an idiot...
LOW-N-SLOW is offline
Old 04-18-2006, 01:08 AM
bsoder
bsoder's Avatar
Tried the 9x4.7 over the weekend. I can definitely tell a drop in performance. I measured with the watt meter and got 14.5 amps static, 148 watts. Amp draw is probably slightly lower in flight. I'll stick with the 8x6 for now unless I have another failure real soon.
Pat
Ok. Have you checked amp draw on the 8x6E? 148W is too much on that motor I think - the limit I've seen is more like 10A.
bsoder is offline
Old 04-18-2006, 01:55 AM
crxmanpat's Avatar
Oops, the measurements I gave were for the 8x6E. I did not measure the 9x4.7. Corrected my original post.
Old 04-18-2006, 05:33 AM
qban_flyer
Guest
Posts: n/a
Talking
One of the guys at Hangar Hobbies in Sterling, VA has nine (9) GWS IPS "A" on his Slow Stick. While it flies nicely, it sounds like a hornet's nest in flight. Weird looking as well. He also has a clipped wing version of it!
Old 04-19-2006, 04:27 AM
Bill G
Super Contrubutor
Bill G's Avatar
Not at all. That's more original than the Slow Stick canards.
Edit: I just saw that P38 Stick on page 2. Very nice! I have 2 geared Feigo 12mm LPS brushless setups laying around. Maybe a Pico P38 Stick? The LHS has one right now for 20 some bucks.
Bill G is offline
Old 04-19-2006, 04:33 AM
  #63
skiman762
FFFC
skiman762's Avatar
It's on the list I have one wing and some parts still left over from the last build might be a fun one to fly
Old 04-30-2006, 03:19 PM
  #64
mastrsn
"Look out for that pole!"
mastrsn's Avatar
Pat
Come on now, I ain't too bad either! Who do you think coined the phrase "Slow Stick Perversion" in RCG anyways?
"Look out for those pesky Lightpoles!"
( and :censored: Stupid people with Transmitters )
Poles -3, Stupid people -1, Bob -0
BB
ID:	10691   Click image for larger version
ID:	10692   Click image for larger version
ID:	10693   Click image for larger version
ID:	10694   Click image for larger version
mastrsn is offline
Old 04-30-2006, 03:26 PM
  #65
I like that twin boom version Are you using 1 or two servos for your rudders?
You could take that center aileron cutout and make a flap out of it! Probably wouldn't need it but it would look cool.
Old 04-30-2006, 03:32 PM
  #66
Glo4U
Default Twin boom SS
I like the twin boom version and the biplane. Can you post mor info along the how to side??
Gloria
Glo4U is offline
Old 04-30-2006, 04:49 PM
  #67
mastrsn
mastrsn's Avatar
The "Double Stick" only uses one rudder servo. I put a spacer bar between the two to steer them both.
Video is here: http://www.dawnpatrol.iwarp.com/photo3.html
(Not direct links, but will get you to the RCG thread where the video is)
More pics of perversion here: http://www.dawnpatrol.iwarp.com/photo5.html
and all the perversion you would ever want to see, but were too afraid to ask is here: http://www.rcgroups.com/forums/showt...&page=65&pp=10
Hope that helps!
BB
mastrsn is offline
Old 04-30-2006, 05:02 PM
  #68
mastrsn
mastrsn's Avatar
Oops, didn't see your second question. Yea, you could make the center a speed brake, but I think it would just get in the way of my bomb drop box, or camera, or my jato rockets .
I already have flaps, and when the ailerons didn't work out ( they suck on a Slow Stick wing), I made them into flaps as well. Take off rolls realy short now and she floats in for a landing
BB
ID:	10705   Click image for larger version
mastrsn is offline
Old 04-30-2006, 05:03 PM
  #69
mastrsn
mastrsn's Avatar
Gloria
Side?
mastrsn is offline
Old 04-30-2006, 05:31 PM
  #70
Twmaster
Registered User
Twmaster's Avatar
Take out the polyhedral and the ailerons will work great.
One of our flying cabal has an aileron equipped SS. Flies really well. Rolls etc. Inverted flight and so forth. Still floats in for landings too.
Twmaster is offline
Old 04-30-2006, 06:02 PM
  #71
mastrsn
mastrsn's Avatar
Naw, I like it just the way it is. Besides, who has time to rework old ideas?:p
On to the Slow Stick flying boat and the Ducted Fan Stick
(So many ideas, so little money...)
BB
ID:	10710   Click image for larger version
mastrsn is offline
Old 04-30-2006, 07:16 PM
  #72
Really neat stuff there Bob.
That is a really cool pic if the SS over water with the reflection and all...
Old 04-30-2006, 07:18 PM
  #73
mastrsn
mastrsn's Avatar
It's a passion, a way of life......
Did you check out the vids?
mastrsn is offline
Old 04-30-2006, 07:31 PM
  #74
Yeah, Really cool... nice job
Old 04-30-2006, 09:21 PM
  #75
crxmanpat's Avatar
Hey Bob,
How are you? I see you found your way over here also!
In all fairness, you must at least give me credit for posting a pic of one of your planes (Sopwith Bipe).:p
Stay away from them lightpoles man!
Quick Reply: A Slow Stick post for the Slow Stick fans
Page generated in 0.14389 seconds with 22 queries
