Parkzone Spit, rebuild with no spares!
Old 08-21-2010, 09:04 PM
CPomeroy
C Pomeroy
Default Parkzone Spit, rebuild with no spares!
Okay, my first plane (PZ spitfire) crashed recently, due to signal loss:
[media]http://www.youtube.com/watch?v=aTPn_N9GG8Q[/media]
[media]http://www.youtube.com/watch?v=tCDZEE63VB4&feature=fvw[/media]
And I rebuilt it. And it crashed again, this time probably due to bad CG. and I rebuilt it AGAIN. Here's some photos, if you've got facebook.
http://www.facebook.com/album.php?ai...00000945632061
You can see photos of the original and the previous version in my facebook pictures.
Yeah, so does anyone have any pointers on how to finish the foam (insulation!) cowling? Primer, filler, undercoat, paint?
I forgot to mention, I added a tiny fan under the nose to circulate air when it's not flying; I frequently have overheat problems when i'm getting ready to fly. This fan is wired directly to an unused servo channel with 2 wires. I think it's wired to the positive and signal wires. IS THIS A GOOD IDEA? It doesen't seem to affect the plane a great deal, but when the motor runs, there is a slight jitter in the other servos, and when I stop it with my finger the jitter stops.
CPomeroy is offline
Old 10-07-2010, 06:34 PM
texasclouds
texasclouds's Avatar
i'd be careful that the fan doesn't draw too much power than the bec can supply. if you have a wattmeter, check the amp draw with fan on and all servos waggling. i'd expect that number to increase with windload against to surfaces.
air holes are free, cheap and don't draw electricity. i'd find a way to make use of that instead of a fan.
your design is kinda backwoods redneck...i like that...but you may be nose heavy. looks bully.
texasclouds is offline
Old 10-07-2010, 09:25 PM
MS_in_NY
MS_in_NY's Avatar
Nothing should be overheating with the model just sitting there powered up. Something is seriously wrong. You must have a short or a stuck servo that's drawing more current than the bec can handle.
.......Mike
MS_in_NY is offline
Old 02-01-2011, 06:55 PM
CPomeroy
C Pomeroy
I scrapped powering the fan with the reciever, because it was causing servo jitter, something I didn't want to try flying with. I have since solved the nose heavy problem (you're right, there was one) by installing a single AA battery in the tail, and using that to power the fan. It solved the CG and also kept the fan going. I also moved the fan to the interior because it was obviously going to snap off as soon as anything happened to the plane, such as landing.
CPomeroy is offline
kargo
ParkFlyers
08-08-2010 12:56 AM
baz49exe
Warbird Electrics
118
05-13-2009 08:27 PM
LectricPlane
Warbird Electrics
42
04-23-2009 09:32 PM
gunsmoke1971
Warbird Electrics
04-17-2007 04:10 PM
pappy60
Electronic Builders Workshop
08-11-2005 03:01 PM
Quick Reply: Parkzone Spit, rebuild with no spares!
Page generated in 0.08628 seconds with 15 queries
