Mountain Models J3 Cub build
Old 02-03-2009, 10:17 PM
JustPlaneCrazy
Yeah it's rice. It gives me decent weight in a flexible container. Cheaper and safer (kids and pets) than lead shot.
Sorry, not minute rice, just some generic rice, 5lbs for like $1.25. I'm not planning on eating it anyway. More of a meat and potato kind of guy.
JustPlaneCrazy is offline
Old 02-04-2009, 12:07 AM
gfdengine204
gfdengine204's Avatar
Originally Posted by JustPlaneCrazy View Post
Yeah it's rice. It give me decent weight in a flexible container. Cheaper and safer (kids and pets) than lead shot.
That is an excellent idea. Thank you.
gfdengine204 is offline
Old 02-04-2009, 01:40 AM
gramps2361
gramps2361's Avatar
i'm going to give it a try hate all the pins to hold pieces in place then filling them in after. call it the tip of the day.
gramps2361 is offline
Old 02-04-2009, 03:32 AM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
FlyingMonkey is offline
Old 02-05-2009, 12:08 AM
JustPlaneCrazy
I'm glad everyone liked my rice weights, but I can't take total credit for it. I came across the idea of using bags of dry rice, warmed in the microwave, to keep batteries warm during winter flying. I believe it was in the "TIPS and TRICKS" section of a Model Airplane News (don't remember which issue). They worked well for that and I realized that they would make handy weights.
One more tip about pin holes (yes, another article). Take a Z-bend pliers and bend your pins. Simply insert them next to your pieces instead of through them. The Z-bend acts like a clamp holding the pieces without all the holes.
I'm a self-taught beginner so most of my info comes from magazines or Wattflyer
ID:	92598   Click image for larger version
ID:	92599   Click image for larger version
Old 02-05-2009, 12:42 AM
mararra
Now there's a reason to get a pair o' them cool pliers!
Fantastic idea; now if I can just keep from gluing them to the balsa ...
M
mararra is offline
Old 02-05-2009, 03:24 PM
gfdengine204
I have about half my pins bent with Z-bends just like that, for the same reason.
Good tip!
Old 02-05-2009, 03:56 PM
gramps2361
gramps2361's Avatar
where can i pick up a z-bend pliers, homedepot? building 2 models one started like to get one before i go to far.
Old 02-05-2009, 04:05 PM
gfdengine204
Gramps, I ordered mine from TowerHobby a couple years ago. Works great!
Old 02-05-2009, 04:08 PM
gramps2361
gramps2361's Avatar
thanks for the info. sorry justplanecrazy if i got of topic on your thread. hope your build is going well.
Old 02-05-2009, 10:37 PM
JustPlaneCrazy
Not a problem, Gramps, that what we're here for.
I picked up my Z-bend pliers at the LHS.
Old 02-05-2009, 11:16 PM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
This makes me wish the "thanks" button was back.
I dont care where you got it from - Im glad you passed it along!
Larry3215 is offline
Old 02-05-2009, 11:51 PM
gfdengine204
I went out yesterday and got a 10 pound bag of rice, some snack ziplocs and quart ziplocs.
Then my wife yelled at me cuz I already HAD ziplocs on my workbench.
Old 02-06-2009, 12:48 AM
gramps2361
gramps2361's Avatar
like i use to tell my wife "your young you'll get over it" just make sure you are out of arms reach when doing so.
Old 02-06-2009, 12:50 AM
gfdengine204
"Out of arms reach" is fine, but I DO have to sleep sometime....
My wife is a nurse, and has pointed out how a well placed injection could go undetected by the BEST of Quincy's......
Old 02-11-2009, 04:21 AM
JustPlaneCrazy
Default Update
Hello Everyone
Well, this week I finished up the wing construction. As I mentioned before, the fit of the wing parts is simply too tight. You will need to either sand the tabs thinner or enlarge the slots. I did whichever one was easier.
One note on aileron construction, pieces A5 and A6 are the aileron leading edges. This is not marked or mentioned so I had a lot of confusion when the directions told me to glue the aileron leading edges together at a 90 degree angle. It's a good idea to dry fit the entire aileron assembly as it is possible to assemble A5 and A6 90 degrees BACKWARDS. Fortunately, it was only tacked.
At this point, the major subassembly is complete and the next step is sanding and covering. I think I'll just go ahead and order that second roll of covering.
Until next time.
ID:	93283   Click image for larger version
Old 02-11-2009, 02:47 PM
mararra
"One note on aileron construction, pieces A5 and A6 are the aileron leading edges. This is not marked or mentioned so I had a lot of confusion when the directions told me to glue the aileron leading edges together at a 90 degree angle. "
I experienced the same bit of confusion. Luckily, I dry fit everything first. It became readily apparent then how the parts fit. One note of caution. When you get to covering the ailerons be very careful when shrinking the covering. It's real easy to warp and twist them out of shape.
M
mararra is offline
Old 09-30-2009, 05:37 PM
texasclouds
texasclouds's Avatar
how is the build coming along?
texasclouds is offline
buzzltyr
Scale E-Powered Aircraft
43
01-23-2012 07:27 PM
Sky Sharkster
04-28-2010 07:57 PM
49
12-09-2009 01:22 AM
Forge
46
08-19-2008 02:23 PM
johnhay73
ParkFlyers
40
01-16-2006 07:13 PM
Quick Reply: Mountain Models J3 Cub build
Page generated in 0.10883 seconds with 18 queries
