tilting heli / Blade 400
Old 01-05-2009, 05:37 AM
ozzydog
Default tilting heli / Blade 400
Hello all,
After a recent minor mishap my Blade 400 seems to lean to one side when flying. Appears to me that the when the blades are parallel to the ground and in a hover the body seems tilted. I guess I would expect everything to hang straight down when in a good hover.
Any thoughts? Thanks, Todd.
ozzydog is offline
Old 01-05-2009, 05:52 AM
MaxAdventure
AMA 198798
MaxAdventure's Avatar
check to see if the canopy mount is bent, or the tail tube has twisted. those are my first thoughts.
MaxAdventure is offline
Old 01-05-2009, 06:13 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
You will have a bit of lean as the tail rotor counters the torque of the main blades. The tail is blowing to the right to keep the heli from spinning so the heli has to "lean into" this sideways force. Or is your lean more pronounced than this?
xuzme720 is offline
Old 01-05-2009, 06:35 AM
Twmaster
Registered User
Twmaster's Avatar
And here I thought maybe it was something to do with them folks in OZ hanging upside down on the planet....
Twmaster is offline
Old 01-05-2009, 06:55 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Well, that too!
xuzme720 is offline
Old 01-05-2009, 10:57 PM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
If you are looking at the heli from the rear when hovering, it will lean a bit to the right normally. As mentioned above, this is due to the push of the tail rotor to left to counteract the torque of the main rotor. Percectly normal.
Heli Jim is offline
Old 01-08-2009, 06:14 AM
ozzydog
Just seems more then before the crash. Could a out of level swash plate cause this? I just got a leveler in the mail today so I will check that too. Thanks for your help.......
ozzydog is offline
Old 01-08-2009, 12:31 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
It might... make sure everything is level and balanced. Setup is everything with a heli.
xuzme720 is offline
Old 01-09-2009, 05:25 AM
ozzydog
ok thanks to everyone for the advise
ozzydog is offline
SkunkyMagoo
E-Flite Helicopters
13
07-31-2008 01:27 AM
Tennwalker
07-30-2008 12:55 PM
fateemagee
General RC E-Heli Talk
03-05-2008 03:59 AM
veekay
E-Flite Helicopters
33
06-10-2007 08:50 PM
walkingtall
Beginners - Helis
01-12-2007 03:13 PM
Quick Reply: tilting heli / Blade 400
Page generated in 0.08641 seconds with 13 queries
