blade 400 pitch change ???
Old 01-05-2009, 12:32 AM
MARKZR7
Default blade 400 pitch change ???
The pitch on my blade 400 seems to change on it's own
not much but it will rise about two feet and the sound will also change
then it seems to fly that way for the rest of the battery
could the swashplate be stickingany help would be great
MARKZR7 is offline
Old 01-05-2009, 01:07 AM
theecoop
theecoop's Avatar
I would wonder more about it being in your tx settings,throttle or pitch curve maybe
theecoop is offline
Old 01-05-2009, 01:23 AM
MARKZR7
Thanks for the info
but I don't think that's the case
It only happens sometimes
MARKZR7 is offline
Old 01-05-2009, 01:27 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
since it's intermittent, I'd say it is likely binding. unhook the motor wires and run pitch changes from the radio and make sure the swash isn't "jumping" or tilting, etc.
xuzme720 is offline
Old 01-05-2009, 02:06 AM
MARKZR7
Thanks I may give that a try
or go to my lhs an bug them LOL
MARKZR7 is offline
Old 01-05-2009, 04:22 AM
Take a good look at your thrust bearings (part 17). If these are binding it will be hard to tell unless the rotor is spinning and putting a load on them.
Old 01-05-2009, 06:03 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Also check that the blade grips aren't binding which is what the thrust bearings are for. Unhook the linkage and tilt the blades like you're changing the pitch. Pull outward on the blade (away from the main shaft) while doing so and see if there is any grittiness or binding in the thrust bearings (make sure to grip the head block with the other hand to prevent bending/stressing the mainshaft). Check that the swash is free and the mainshaft is clean of any debris so the swash isn't getting hung up during pitch changes...
Hopefully one of these items is your culprit. Let us know...
xuzme720 is offline
Old 01-05-2009, 11:32 AM
MARKZR7
Thanks again for the help
MARKZR7 is offline
mrich_30047
E-Flite Helicopters
01-08-2008 01:45 AM
slogfilet
E-Flite Helicopters
11-05-2006 03:41 PM
CrashMaster39
10-18-2006 05:45 AM
iuam
Beginners - Helis
07-07-2006 05:19 AM
Ron S
E-Flite Helicopters
32
02-12-2006 07:47 AM
Quick Reply: blade 400 pitch change ???
Page generated in 0.11591 seconds with 13 queries
