Super Cub 480 Hot Rod kit, bolt on? Any interest?
Old 12-02-2008, 07:31 PM
AlexinFlight
AlexinFlight's Avatar
Default Super Cub 480 Hot Rod kit, bolt on? Any interest?
I am checking interest for the HZ Super Cub bolt on Hot Rod Kit. For those who want a PNP hop up. It uses stock white plastic firewall & screws and simply bolts in place. The pic shows it mounted to the stock SC. Don't want new servos..no problem, delete those then. Don't want a 480, no problem mount is drilled for any motor mount you want. Mount in the picture is the prototype, Mount is being made from lightweight aluminum and is one piece. Email direct is [email protected]
(1) 480 class Brushless Electric Motor
(1) Rotor End Prop Adapter
(1) Motor 'X' Mount
(1) 40 Amp ESC Brushless
(1) GWS EP1170 Propeller
(1) Lipo Battery 11.1v 2250mah 20C - 45 amp Lithium Polymer
(2) SERVO 9 gram Sub Micro Servo
(1) SERVO mounting plate
ID:	85508   Click image for larger version
AlexinFlight is offline
Old 12-03-2008, 12:56 PM
sidecar53
sidecar53's Avatar
Default I'd be interested-
Keep us informed. Rick
sidecar53 is offline
Old 12-03-2008, 04:39 PM
AlexinFlight
Production run should be completed soon. The mount itself is the most important part as it screws to stock firewall cowl mount and gives you the correct thrust angle immediately. Mount can be purchased separately if you want to mount your own motor. The servo mounting plate will be made from lightweight aluminum, available with or without new servos, screw your standard servos in and glue it in place, done!
Old 12-03-2008, 05:00 PM
groundrushesup
groundrushesup's Avatar
Will it look something like this? I'm interested because the GB is exactly the same as the one on the PZ P-51 and Spitfire.
groundrushesup is offline
Old 12-03-2008, 08:16 PM
AlexinFlight
Yes and No. Seems that that mount is limited to the mount specs for a Park motor, which is fine. I am trying to achieve a slightly more versatile mount, which maintains the Super Cub thrust angles exactly.
Old 12-03-2008, 08:43 PM
groundrushesup
I see. Specs on the motor? Stock thrust angles - especially down - for a more powerful motor can be problematic because the original intent to increase wing loading with down thrust may cause the cub to pitch up when used with a motor that has considerably more guts.
Old 12-03-2008, 09:06 PM
AlexinFlight
The motor, 1st pic, on the Super Cub has been test flown numerous times..it performs extremely well with the stock angle. If you wanted to change the angle it would be as simple as cutting the legs of the mount to adjust to what angle you want. Motor: 3530-10, 480 class 1000kv direct drive outrunner brushless motor capable of producing 42 oz of thrust from a 3-cell Lipo battery. Best performance with 10 and 11 inch props. No Pitch up that I have noticed or had any trouble with, just very nice controlled powerful flight. 1st pic Cub banked turn moving at a good clip not quite full throttle. Last pic is beautiful hand toss 3/4 throttle take off.
ID:	85617   Click image for larger version
Old 12-03-2008, 10:30 PM
Gohmer
Banned
Smile
Cost and weight please?
Gohmer is offline
Old 12-03-2008, 10:39 PM
AlexinFlight
If you just wanted the aluminum one piece mount, we are hoping to be able to offer it at $19.99, that is our target offering price.
Old 12-03-2008, 10:49 PM
Gohmer
Banned
Smile
Not sure yet. Just list them all please:
(1) Motor 'X' Mount
Gohmer is offline
Old 12-03-2008, 11:14 PM
AlexinFlight
We are not going to be selling individual pieces...it is either our new alumimum mount separate, or the package. Options for deleting servos or battery and complete package price has not been firmed up yet. What I am trying to do is make a bolt on 480 PNP kit at a great price.
We all know a Park 480 is 65 bucks and a 40 amp ESC is 54.99, a 2250 lipo is in the 23-50 range (depending where you get it and plus the shipping) my new aluminum mount is $19.99, then you have to assemble it. Lots of people like to do the assembly, I am putting this kit together for those that maybe are not so good with doing all that. Seeing how this has not yet been marketed and I would love to hear your feedback...what do you think a "Great Deal" price would be for the whole kit would be? PM me if you don't want to post it.
Old 03-09-2009, 10:11 PM
jecchile
jecchile's Avatar
Default I'm interested...
Please let me know when the kit is available and the price... Thanks...
jecchile is offline
sb13
3D Flying
01-14-2007 03:51 AM
sb13
01-02-2007 05:01 AM
gquiring
08-29-2006 04:08 AM
svo
3D Flying
08-08-2006 12:00 AM
mountaindr3wz
Foamies
08-27-2005 03:51 AM
480 , cub , kit , super
Quick Reply: Super Cub 480 Hot Rod kit, bolt on? Any interest?
Page generated in 0.11649 seconds with 17 queries
