blade 400 3d fp?
Old 11-28-2008, 12:18 AM
xtrmn8tr
Default blade 400 3d fp?
hi all
can the blade 400 3d with DX6i radio system be sat up to fly like a HBFP?...till skills get better?
xtrmn8tr is offline
Old 11-28-2008, 02:42 AM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Yes, it could You would set the pitch curve to a constant number and run probably a linear throttle 0-25-50-75-100
I have read about this idea before but nobdy has posted back how it went, that I know about
give it a shot.
Heli Jim is offline
Old 11-28-2008, 05:08 AM
Druss
quite frankly there is not that much difference in flying characteristics between a fixed pitch and ccpm heli. the biggest advantage to a fixed pitch is that they have fewer parts and therefore are more robust in a crash.
Druss is offline
Old 11-30-2008, 06:26 AM
dbcisco
Like to build 'em
dbcisco's Avatar
If you can do this on your TX then you will convert the collective heli to a fixed pitch heli.
Set the Pitch to be a maximum (or less if needed) positive all the time and use throttle to change head speed only. That is what makes a fixed pitch heli.
It is sort of the opposite of idle-up.
dbcisco is offline
Old 11-30-2008, 06:59 AM
BlackholeZ
Blade CX2 & Blade 400
I was quite intimidated by the touchiness of my B400 when I first started flying it. Looking around online I found suggestions to make it a bit more forgiving. A flatter pitch curve makes the throttle less touchy. higher headspeed makes it more stable, and dual rate and exponential on the aileron and elevator makes them more forgiving. Having negative pitch in the lower half of the throttle makes it easier to spin up w/o the heli trying to lift off.
Here are my settings:
Throttle:
0,45,75,85,100
Pitch:
40,45,50,65,80
D/R and Exp
Ail: 90%, 5%
Elv: 90%, 5%
Hope this helps some.
BlackholeZ is offline
Old 11-30-2008, 07:32 AM
dbcisco
Like to build 'em
dbcisco's Avatar
Beats the heck out of turning it into a $70 FP doesn't it.
dbcisco is offline
cpatel529
11-23-2008 02:41 AM
MarK6565
Beginners - Helis
10-22-2008 12:54 PM
L0stS0ul
E-Flite Helicopters
60
05-23-2008 06:09 PM
Jizzer8181
E-Flite Helicopters
11
04-06-2008 05:41 PM
L0stS0ul
E-Flite Helicopters
33
12-28-2007 05:31 PM
3d , 400 , blade , fp
Quick Reply: blade 400 3d fp?
Page generated in 0.12996 seconds with 13 queries
