Flight Simulators Discuss computer flight simulators here
New ParkZone F4U Corsair for FMS/Clearview sims
Old 10-14-2008, 09:15 PM
ggunners
Default New ParkZone F4U Corsair for FMS/Clearview sims
Hello all!
I have just completed a model of the ParkZone F4U Corsair
for the FMS and ClearView simulators.
The ParkZone Corsair is a beautiful scale warbird that flies great
and slows down well according to all the online flight reports.
Model Specs are:
Wing Span: 44.0 in / 1118mm
Overall Length: 35.0 in / 889mm
Flying Weight: 30.0 oz / 850g
Motor Size: 480 size 960Kv brushless outrunner
Props: 3 blade 8.7x6x3, 2 blade 9.5x7.5x2
Radio: Proportional 4-channel FM, A/R/E/T
Battery: 3-cell 11.1V 1800mAh LiPoly
Please try the model with FMS or ClearView and let me know
how it flies or whether any adjustments are needed.
-- ggunners
ggunners is offline
Old 11-30-2008, 10:30 PM
alt-148
Foam Flying Dutchman
alt-148's Avatar
I tried the GWS version, but it seems overpowered to me.
Maybe because I compare it to my real-life Guan-Li corsair with a similar brushless set-up.
alt-148 is offline
Old 04-25-2009, 07:27 PM
iamman711
thanks,
your FMS creations are the best. keep up the good work. i hear a Zero and another warbird (2 this year) are going to be released at SEFF 2009 in a few days.
iamman711 is offline
Old 04-26-2009, 09:20 PM
smokejohnson
smokejohnson's Avatar
Cool, thanks ggunners .
smokejohnson is offline
Old 04-14-2010, 03:08 AM
mgrande11
mgrande11's Avatar
This flys just like the pz corsair.
mgrande11 is offline
Old 08-03-2010, 08:24 PM
barnburner13
barnburner13's Avatar
thank you for this one, it is helping me pass the time on CV while I wait for the real thing to be delivered
barnburner13 is offline
Old 12-30-2010, 08:05 PM
luzuriaga
Luxud
luzuriaga's Avatar
Hello ggunners! hey, I copied all the files into the models directory of the FMS but didnīt work...any tips or special treak to install it??
Thanks!!
luzuriaga is offline
Old 12-31-2010, 01:07 AM
ggunners
If you just copied the .zip files, they will not work. You need to unzip them to that directory using an unzip utility. There's some free ones on the web. Just Google them and install them. -- ggunners
ggunners is offline
Old 01-03-2011, 01:34 PM
luzuriaga
Luxud
luzuriaga's Avatar
Hi ggunners! thanks for your reply. I did that of course! may be the problem is my computer or something else, I have a couple of other models downloaded from the innternet and some works and others donīt. Donīt worry. Thanks !
Old 01-03-2011, 09:10 PM
ggunners
If some models are working and others not, I would guess that you are using FMS 2.7 instead of FMS 2 alpha 8.5. Most of the models since 2004 are FMS 2 alpha 8.5 models. -- ggunners
ggunners is offline
Old 01-06-2011, 12:56 PM
luzuriaga
Luxud
luzuriaga's Avatar
Thanks men! I havenīt tried yet but I just checked and you are right, my version is the 7.0. Thanks again for your help. By the way, Great web siteyou have!. Cheers from Argentina. Dario
Bad_B
Warbird Electrics
733
04-28-2020 12:14 PM
ggunners
Flight Simulators
02-16-2009 05:50 PM
warbirdmaster888
Warbird Electrics
07-01-2008 08:38 AM
SkunkyMagoo
Flight Simulators
05-22-2008 12:07 AM
Jeremy Z
ParkFlyers
43
11-24-2005 10:21 AM
Quick Reply: New ParkZone F4U Corsair for FMS/Clearview sims
Copyright Đ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
Page generated in 0.08547 seconds with 13 queries
