2.20m Zagi wing info wanted!
Old 10-06-2008, 09:01 PM
sadkingbilly
Happy When Flying
Default 2.20m Zagi wing info wanted!
Hello,
I bought an original zagi wing with a span of 2.20m (2.19 actually). It's not new, the fellow I bought it off had it in his attic for five years, all he did with it was glue the halves together... Some info:
Data:
wingchord inside wing: 40.5 cm
wingchord outside wing: 15 cm
span: 219 cm
empty weight: 282.3 gram
What I'd like to know is: where do I put the CoG? I'd like to keep it a clean glider, no drive system, only highstarthook and towservo.. Then something like 4xAAA NiMh for the power.. Or a little bigger if needed. I'd like to give it elevons and if possible and useful crow flaps. so that will make 2 big servo's (14 gram?) or four smaller ones (9gram?)..
I need the wing to be able to seperate (I know there's a word for it.. anyone? My english just failed me big time..) so I can take the wing with me by car or bike. I guess it needs some system to strengthen it and also connect the two halves. Anyone ever did this before and has some pictures of it?
My plan is to make a zagi as light as possible, use it on the highstart or tow it up with my EZ*, then thermal it... All help welcome!
Alwin
sadkingbilly is offline
Old 10-06-2008, 11:49 PM
Arkitexas
Lone Star Flyer
Arkitexas's Avatar
I've only been involved in RC for three years and wasn't around when Zagi was starting out. That said, I have never heard mention of a 2.2 meter "original" Zagi. The largest I have seen is 60" or 1.53 meters. The CG for the current 1.23 meter and 1.53 meter Zagis is back 8" (203 mm) from the nose. You can download build manuals for various Zagis at
http://www.zagi.com under RESOURCES click INSTRUCTIONS.
I assume that you could calculate a proportional ratio to determine the CG for a larger wing. That at least would get you in the ballpark.
Also, there is a "center of gravity calculator" at
http://www.inlandsloperebels.com/Calc/cgcalc.html
Good Luck,
Rick
Arkitexas is offline
Old 10-07-2008, 01:21 AM
tushev
HATE HOVERING
tushev's Avatar
I build one 2m wing spun and the CG is 11 inch from the nouse, so yours shoud may be 12..
tushev is offline
Old 10-07-2008, 05:18 PM
sadkingbilly
Happy When Flying
Thanks for the info guys
Old 10-08-2008, 11:56 AM
r_kopka
Electric Only
r_kopka's Avatar
http://kopka.at/modell_f_wing.htm#Monster
Here is a similar model. I have only made a few flights with it and there are still some problems and changes needed.
I started with 210mm which I read somewhere. That was not good. I'm now at 242mm and I think it will move even farther backwards.
I would use bigger servos. The elevons are large. I also want(ed) to use crow flaps but it will land so slow (even with the weight of the motor and battery) without it that I don't think I need it under normal circumstances.
RK
r_kopka is offline
Old 10-08-2008, 01:11 PM
sadkingbilly
Happy When Flying
RK
Wow, AUW is 1800 gram! That's almost 3 times what I have in mind and it still flies well? Of course, I'm not going to mount a motor (in the first instance).. Or, perhaps if I can keep the weight low I'll mount a small BL motor (120-150watt) with a 1000mAh lipo. Seems the wing doesn't care about being a bit heavy. But will she still thermal - that is demanded
Old 10-13-2008, 07:41 AM
tushev
HATE HOVERING
tushev's Avatar
check this out:
[media]http://www.youtube.com/watch?v=tyDSsb5eGkU[/media]
tushev is offline
guapoman2000
116
11-05-2016 11:44 AM
clockworks
Flight Simulators
03-16-2008 02:08 AM
Kosh
Video Parking lot
10-24-2007 06:26 AM
rdr4evr69
09-19-2007 03:25 PM
YankeeRedneck
03-15-2007 03:39 AM
Quick Reply: 2.20m Zagi wing info wanted!
Page generated in 0.09829 seconds with 10 queries
