How Do I Mount My Outrunner Motor ?
Old 02-12-2010, 03:20 PM
  #176
Huffy01
Huffy01
Would someone be able to tell me the procedure for turning the shaft around on a Turnigy 42-70.
I bought a second hand plane which has the motor in front of the mount.
I had problem with this plane so I used parts of it to scratch build a new one.
As it my first scratch build I probably haven't built it properly and may wish to build something different with the motor mounted behind the firewall.
Huffy01 is offline
Old 02-12-2010, 06:34 PM
  #177
radialarm
Crash Test Clown!!!
radialarm's Avatar
It sounds like you have a radial prop mount that attaches to the motor bell with 4 screws, right? If that's correct then you need to buy a collet prop adapter for your shaft size, so you can attach the motor behind the firewall.
http://www.hobbycity.com/hobbycity/s..._shaft_(collet)
I couldn't find a 42-70, so measure your shaft. The other 42XX motors have a 5mm shaft.
radialarm is offline
Old 02-13-2010, 09:24 AM
  #178
Huffy01
Huffy01
Sorry ,I made a mistake with the model number .It's a Turnigy TR 4250-700kv outrunner.
http://www.hobbycity.com/hobbycity/s...trunner_/_720W
If you look at the photo on the website the shaft is poking out of the large end which has the 4 mounting screws .The one I have the shaft is mount the other way the shaft would come out at the end you can see in the photo.
Huffy01 is offline
Old 02-13-2010, 09:47 AM
  #179
you have to turn your motor around, and mount it like this, with a collet adapter for the prop, there are a few different motor mounts that you can use,
http://www.hobbycity.com/hobbycity/s...idProduct=5283
Old 02-13-2010, 09:52 AM
  #180
Old 02-13-2010, 01:22 PM
  #181
Huffy01
Huffy01
Here a photo of the plane I bought ,it use to have a nitro motor in it and the previous owner started to convert it to electric, I guess that is why it is mounted in this fashion.
So the next plane that I am building has the motor mounted the same way.
I think that my construction of the new plane may fail I am thinking ahead to plan a new plane.
My question is how do I change the motor around so that it will mount inside the fuselage/behind the motor firewall.
I have all the other part you have suggested.
Name:	new plane Wasp 008.jpg
Huffy01 is offline
Old 02-14-2010, 06:56 AM
  #182
You dont use the prop adapter that mounts on the can of the motor, you use the X mount, with a collet prop adapter on the motor shaft, like in the picture below, you may or may not need the spacers as shown, depends on the cowel and clearance you have, you just turn the motor around, and dont use the prop adapter that screws onto the can, thats not used anymore.
Old 02-14-2010, 07:29 AM
  #183
Click on this link, and it will show the motor reversed, thats how you mount the motor behind the firewall, hope that helps, Chellie
http://www.modelflight.com.au/ProdIn...tor_manual.pdf
Old 02-14-2010, 08:02 AM
  #184
Huffy01
Huffy01
The photo on post #182 is the same motor as the one I have but the shaft is poking out of the end which is closest in the photo.
Is it possible to remove the shaft and change it to the same set up as the photo?
Huffy01 is offline
Old 02-14-2010, 08:20 AM
  #185
Thats a good Question I dont know if your motor has been modified or came that way, with the shaft in a different position other than the photo from HK, Maybe some one else with motor rebuilding skills can chime in here, Take care, Chellie
Old 02-14-2010, 09:37 AM
  #186
Huffy01
Huffy01
I just ran down to my workshop and took a photo of it ,I hope it can explain a little better.
Huffy01 is offline
Old 02-15-2010, 04:51 AM
  #187
To tell you the truth, the motor position looks correct where its at, you just need to extend the cowel out a little to cover the motor or add a new cowel, i would not change the motors position, hope that helps, Chellie
Old 02-15-2010, 05:00 AM
  #188
I just used a mount similar to that one to mount my hacker in my big Pitts. Basically the same on that is in my Waco as well.
Old 02-15-2010, 05:08 AM
  #189
Hi Bill he has a odd ball motor, or someone modified it, its not like the motor from HK
HK motor.
huffy01 motor
Old 02-15-2010, 05:10 AM
  #190
maybe someone turned the shaft around, i dont know if that can be done or not, some one with motor building experience may be able to chime in here
Old 02-15-2010, 05:11 AM
  #191
It's not an oddball motor, the shaft has just been reversed.
There are some set screws, not visible in the pic, loosen them up and tap the shaft through to the other side.
Old 02-15-2010, 05:13 AM
  #192
OK Great that helps Thank you, Chellie
Old 02-15-2010, 06:22 AM
  #193
Huffy01
Huffy01
I just had a closer look at it and could only find one grub screw and a circlip.
I managed to find an allen key to fit the grub screw ,loosened it ,then gave it a wack with a huge hammer and it worked.
I was a little scared that the bearing would come out too but it didn't move a mm.
After I took off the propeller adaptor I found a notch on the shaft.
If you look on the photo that CHELLIE posted it has a groove around the end . My motor has a circlip there I guess to stop the shaft coming out .
Thanks for the Help.
Huffy01 is offline
Old 02-15-2010, 03:25 PM
  #194
Yeah, put the c clip back on there and you're in business!
Old 11-20-2010, 10:41 PM
  #195
jumau
Got to expect losses...
Great references....Anybody has spec's for fitting a Turnigy SK 50-65 380Kv / 1820w
Thnks!
jumau is offline
Old 12-13-2010, 06:39 PM
  #196
FL RV Flyer
FL RV Flyer's Avatar
Hi Chellie;
I have an Easy Star that I am putting an EMax 2812 motor on. I need to build a ply mount for the motor and was wondering which ply to use, 1/8" or 1/4". I plan to epoxy the mount on the outside of the EZ motor housing and then mount the motor to it. Also the angles of 3 degrees left and down, do they apply to pusher aircraft like the EZ.
By the way we have a mutual friend, Jeff, from Head Up RC is my mentor and teacher here in Ocklawaha, FL. His wife owns the RV park we call home in the winter. Jeff says hello to you,
Thanks Jack
FL RV Flyer is offline
Old 12-14-2010, 03:15 AM
  #197
Originally Posted by FL RV Flyer View Post
Hi Chellie;
Thanks Jack
Hi Jack Dont say that at a Airport LOL, i would use the 1/4" ply, you wont need very much of it, and it wont weigh very much, and the screws will hold better in it, epoxy or gorilla glue the motor mount with out any down or right thrust, if you need down thrust or right thrust, add washers between the plywood and the motor mount to shim the thrust line, but i dont think you will need to do that, Hope that helps, Chellie
PS. Say Hi to Jeff for me and Welcome to Wattflyers
Old 12-31-2010, 09:25 AM
  #198
DL8698
Default How to mount motor on DG1000 glider?
Hi, everyone
DL8698 is offline
Old 12-31-2010, 09:27 AM
  #199
DL8698
Glad I "stumbled" onto this thread. Originally was looking for guidance on how to setup a twin motor system, as I am thinking of a P38. Really lovely plane!
When I saw this thread, I realise this is a good place to ask how to mount my motor on to a DG1000 which is non-motorised.
This is the DG1000 glider I got, FOC from a friend
http://www.hobbycity.com/hobbycity/s...dProduct=14419
and the motor I bought to fit in to the glider, TGY AerodriveXp 32 SK Series 35-48 900Kv / 770W
http://www.hobbycity.com/hobbycity/s...idProduct=7393
I intend to use 3s1p 1750 Rhino battery with a 12x8 folding prop.
Is it better to mount the motor in front or behind the firewall? I tend to think from point of view of strength it is better to mount motor behind the f/wall as there is less overhang in case I "land" the glider on the nose.
However, I guess the crash force has to go somewhere so if the mount does not break, the motor probably will, so motor in front of f/wall may be better. Breaking the mount is still preferred over breaking the motor, although breaking nothing is my preference
Does anyone know of a build thread where someone has converted a non-motorised DG1000 to motorised?
DL8698 is offline
Old 12-31-2010, 09:48 AM
  #200
Hi DL8689 here are a few ideas for you
[media]http://www.youtube.com/watch?v=xUBdAbq9t7I&feature=related[/media]
http://www.nitroplanes.com/ventus-di...sailplane.html
power pod
Quick Reply: How Do I Mount My Outrunner Motor ?
Page generated in 0.15460 seconds with 14 queries
