EDF pusher Jet scratch build- contest 2
Old 09-21-2008, 01:29 PM
Originally Posted by ministeve2003 View Post
Hey, nobody reminded me that we were supposed to do speed runs... It was just a maiden flight afterall.... Plus that thing is tiny... and my eyesight just isn't that good far out...lol
SK
LOL Hi Steve That was just a maiden flight to see if it was going to fly or not, Thank You for your help, I got My Wattmeter in, and hooked it up, the lipo that I had in there was kind of weak, it was sagging alot, its a 2250mah 3cell 20C, about 300Watts , 32 AMPS at a little above 8+ volts, I Have a 2350mah 25C 3 cell Rino lipo on order for it, i hooked it up to my 3 cell 4500mah lipo to test the Drain, and WOW 50+ amps at 500+WATTS, I need to replace the ESC, its only a 40 AMP Thanks Again for your help, when the New Lipo gets here and I Replace the ESC ,I will do a speed run with it, Take care, Chellie
Old 09-21-2008, 01:43 PM
Originally Posted by Larry3215 View Post
Next time, remember my advice for getting the best possible doppler reading on a speed run is for the pilot to fly the plane through the camera
Im sure Chellie will appreciate the extra effort
Hi Larry we were not doing a speed run on the jet, just testing to see if it was going to fly or not I need to get a better Lipo, the one i had is weak, its not a real powerful lipo just a run of the mill Wow lipo, its good enough for most planes, but this EDF, requires a powerful lipo, Our club has been testing the Rhino lipos, and they work great, I used a 4 cell 2350mah 25C Rhino lipo in my Funtana, and it went Balistic, I could not fly it full throttle, it was to fast I think my Funtana might do 100mph with that Rhino Lipo, Dang its fast, Thank you for the Advice on doing speed runs, I am going to do a speed run on my FunJet Sunday, I was going to do it saturday, but our flying field was closed for the day, My Funjet has a hobbycity 2845 2700kv Inrunner, 5x5 apc prop, 4 cell 2500mah 30C lipo, and a 80Amp ESC, here is a pic of it, take care, Chellie
Name:	funjet 001_1.jpg
ID:	78676   Click image for larger version
Name:	funjet 003_1.jpg
ID:	78677   Click image for larger version
Name:	funjet 005_1.jpg
Old 09-21-2008, 11:10 PM
Originally Posted by herk_1 View Post
How did you secure the DF to the tail? Doesn't look like there's enough surface area on that edge of Depron to hold it securely with glue. I have lots of DF parts lying around and was thinking of cobbling something together...probably won't look that nice though...I'm thinking of a kind of Rube Goldberg contraption...
Hi herk, Well I went to go fly it again today, and the epoxy broke loose at the EDF, I need to make another Fuselage for it thats ok, I found out with this build, that the fuselage needs to be a little longer in the front, to better balance the CG, and a little wider at the bottom, under the wing, to allow for a little bigger lipo, I think I will use some Basswood this time and secure the EDF in a little better, oh well, getting the bugs out of it as they say should have a new Fuselage done for it tonight, so I can fly it tomorrow again, Take care, Chellie
Name:	AAA 001_1.jpg
ID:	79181   Click image for larger version
Name:	AAA 002_1.jpg
Old 09-25-2008, 07:07 AM
Lightbulb What Did I Learn Doing this Build
OK, what did I learn doing this build, First of all, My motor is much more powerful than i thought I hooked up a wattmeter to it, and a powerful 3 cell lipo, and found out it is Drawing 500+ Watts at a little over 50 AMPS WOW Thats about 3/4 HP if 746 Watts is One HP, OK, I was trying to epoxy a 35 size nitro motor to foam thats about the same thing, It wont hold on for very long OK, I am Learning these Electric motors can be deceiving, in the amount of power they make here is what i did to make it work this time, I epoxied 2 -3/8 x 3/8 basswood motor mounts to the foam, and will attach the EDF to that, they look like 40 size motor mounts anyway, and i will screw the EDF to the wood mounts, I am making the Fuselage longer and a little wider below the wing, so a larger lipo can be used, Take care, Chellie
Name:	AAAA 001_1.jpg
ID:	79183   Click image for larger version
Name:	AAAA 002_1.jpg
Old 09-25-2008, 07:46 PM
that mount looks good, that should hold up better... how did that fan hold up anyways?
SK
That should hold up much better.
Hi Steve I was surprised at the amount of power this EDF makes, the lipo I had is not very strong, and was only putting out about 30 amps and 300watts of power, I ordered a 2350mah 25C Rhino lipo from hobby city, so that should be about 58.75 amps and give about 500watts BTW Steve, The Rhino lipo has a 37C lipo rating for 15 Seconds 86.95 AMPS, 800Watts Maybe can we say SMOKING FOAMY The EDF did not get hurt, Take care, Chellie
http://www.hobbycity.com/hobbycity/s...5C_Lipoly_Pack
I have a suggestion for a little better fan performance.
Take that section of the fuse just in front of the fan and cut it back a little further way from the blades and spinner - more towards the front of the plane. Also - taper down the square edge that faces the fan gradually down to a sharper point. That will help make the air entering the fan smoother and should increase efficiency.
Might give you and extra mph or two
Thank you Larry I will do that, I want to melt this Foamy jet with speed Take care, Chellie
Old 09-29-2008, 04:13 AM
Default Its all better now :)
Well its all better now, I glued 2- 3/8x3/8 basswood motor mounts to the fuselage, and used 2 bands of plastic, that are glued on with sumo glue and epoxy, that EDF wont come off now, I Hope I made the fuselage a little longer and wider at the bottom to fit a bigger lipo, and to regain my CG, from the weight of the motor mounts, I tried a 4 cell lipo in it, but it does not like a 4 cell so I will stay with the 3 cell lipo, more test to come on it, Take care, Chellie
Old 09-29-2008, 03:17 PM
Looks great Chellie!
Thank You Larry The lipo I was using in the beginning, is weak, I found out, its new, but does not give the power that it should, its a 2250mah 3 cell 20C, with the watts up meter, it was only giving like 32 amps and about 300 Watts @ 9volts, and then dropped from there, its getting a Rhino lipo, Our club has been testing these Rhino lipos, and they are great, very very powerful lipos, and inexpensive too, I am going to use a 2350mah 3 cell 25C Rhino lipo with a 37C Burst so that should be 58.78 amps at 25C and 86.95 amps at 37C for 15 seconds I think I should replace that 40Amp ESC in it it should be a rocket with the new lipo Take care, Chellie
Old 10-01-2008, 03:56 AM
Originally Posted by sportster20 View Post
Chellie,
I am new to this forum. Just found it this week and set up to post.
I have the same ducted fan/motor combo that you are using on this jet. I also created a jet similar to yours and installed this EDF. Here is what I found:
1. On a 3S 1800 Polyquest battery I was pulling about 43 Amps. I quickly cut and then shaved off three blades from the fan. This reduced the amps by about 6. It then drew about 37 amps. The thrust did not significantly go down, but the rpm did go up. The end result was more speed and less amps. Since you already have more than a 1.3 to 1 power to weight ratio, you probably won't miss the thrust. It was very easy to shave the three blades off and still have a balanced rotor.
2. Even 37 amps used intermittently is still too much for a 30 amp esc. I cooked it in the middle of my third flight. I was just having too much fun doing large loops. Loosing motor power on a jet that is still tail heavy is not a good thing.
Try shaving off three blades if you like. Then you might feel more comfortable using your 40 amp esc.
Michael
Hi Michael and Welcome to Wattflyers Your going to love it here, Lots of Super nice people here, Thank you for the Information on the Blades, I will try that, it makes sence Take care, Chellie
Old 11-05-2008, 04:12 AM
Originally Posted by profilefan View Post
Great job Chellie, very inspiring
Look forward to your updates!
Thank you for the complements The Jet Flies good, but it would be better if the EDF was moved forward more, or maybe even a Mid wing EDF, reson being, to move the weight a little forwards more, its a little neutral Balanced, and will stall, if your not careful, so having more weight forwards, it will recover from a stall better, All in all, its fun to fly, just dont stall it Take Care, Chellie
Old 12-12-2008, 07:16 AM
Originally Posted by babylon5 View Post
Hi Chellie, I always enjoy your creativity and your forum.
I wanted to know if the EDF unit outfitted with a 5.3KV outrunner brushless motor is the same unit as the one I have.
I wanted to attach a pic but have forgotten how to in this forum. Long time since i join the forum.
The current drawn is very high I think over 40 amps on 3s 4200maH lipo.(I use bigger
capacity to test so that high current would not load the lower capacity lipo cell voltage down and give a false sense of reading.)
After a minute of test, the motor was very hot and smells too, so I stop the test.
If it is the same motor & EDF, think go easy on the throttle.
Best wishes
B5
Hi B5 Long time no Hear the motor was a 5300kv, and it did draw a lot of amps, it did not like a 4 cell, thats for sure thank you for the complements I think a EDF with 3500 to 4000KV would be better, this was my first EDF, and i learned a lot from it, the jet flew well to, but dont get it into a stall, it has to be moving, moving the EDF towards the center, will make this jet fly even better, and recover better from a stall, I got my EDF from Hobby Cith/king, and they sell them on E bay Too, if you have the 5300KV EDF, using a 2 cell lipo, will be better, I even tried to cut 3 of the blades out of my fan, but that really reduced the power a lot, so I would say using a 2 cell lipo with the high5300 kv, and 6 blades, will work the best, Take care, Chellie
Old 02-11-2009, 02:03 AM
dmarko
dmarko's Avatar
cool build.
I hadn't seen this thread before
Chellie.. if you are watching?
Are you still flying this little charm?
Do you have actual dimensions ?
Kinda like you had pictures of dimensions for the delta wing build.
I'd be interested?
Dave in Naples,Florida
dmarko is offline
Old 02-11-2009, 04:04 AM
Hi Dave i used the wing from my twin boom pusher jet, and made a 9mm fuselage for it, the EDF flies well, but it will fly better if the edf was mid mounted, reason being, it wont recover from a stall, to much weight at the rear, but a mid edf will not be a problem, here is the dimentions to the wing, and the fuse you can make to fit your edf, just use the TLAR method That Looks About Right TLAR Take care, Chellie
http://www.wattflyer.com/forums/show...124#post265124
Chellies Pusher Jet Plans
Hi Everyone Well I Promised some Plans, Soooooo here they are, These plans are the Limit of my High School Mechanical Drafting , Lets see, I graduated from High School about 3 years ago, so that makes me about 21 now, yes thats right ?? Well It Sure Sounded Good to Me Here you Go, Have Fun, Chellie
Ps If using Foam Board, cut the slots in the booms and skid 3/16" rather than 1/4" for the 6mm depron
Old 02-11-2009, 04:09 AM
Dave, i will look around to see if I have the pattern for the Fuse, and get back to you, Take care, Chellie
Old 03-01-2010, 07:39 AM
babylon5
Here are some motor specs,
RC ducted fan combo unit
54mm 6-blades w/ 2409-7T brushless motor
RC ducted fan unit, 6 blades rotor with a high power brushless motor
great for all jet type foamies warbirds!!
BUY MORE TO ENJOY OUR 50% OFF DISCOUNT ON SHIPPING!!!
Ducted Fan Specification
<TABLE borderColor=#000000 cellSpacing=0 cellPadding=1 width=657 border=1><COLGROUP><COL width=133><COL width=517><TBODY><TR vAlign=top><TD width=133 bgColor=#00ff00 height=10>Dimensions
</TD><TD width=517 bgColor=#00ff00>62mm outer dia. x 71mm length (w/ motor)
</TD></TR><TR vAlign=top><TD width=133 bgColor=#00ff00 height=7>Shaft size
</TD><TD width=517 bgColor=#00ff00>3.175mm ( spinner adaptor type shaft)
</TD></TR><TR vAlign=top><TD width=133 bgColor=#00ff00 height=6>Weight
</TD><TD width=517 bgColor=#00ff00>71g ( with motor)
</TD></TR><TR vAlign=top><TD width=133 bgColor=#00ff00 height=5>Thrust
</TD><TD width=517 bgColor=#00ff00>680g / 1.5lbs ( flying weight)
</TD></TR></TBODY></TABLE>
Motor Specification
<TABLE borderColor=#000000 cellSpacing=0 cellPadding=1 width=545 border=1><COLGROUP><COL width=212><COL width=326><TBODY><TR vAlign=top><TD width=212 bgColor=#00ff00 height=10>Type
</TD><TD width=326 bgColor=#00ff00>2409H/7T
</TD></TR><TR vAlign=top><TD width=212 bgColor=#00ff00 height=7>Shaft size
</TD><TD width=326 bgColor=#00ff00>3.175mm
</TD></TR><TR vAlign=top><TD width=212 bgColor=#00ff00 height=6>KV
</TD><TD width=326 bgColor=#00ff00>5300kv
</TD></TR><TR vAlign=top><TD width=212 bgColor=#00ff00 height=6>Max drain current
</TD><TD width=326 bgColor=#00ff00>57A
</TD></TR><TR vAlign=top><TD width=212 bgColor=#00ff00 height=5>voltage
</TD><TD width=326 bgColor=#00ff00>11.1v ~ 14.8v(3s ~ 4s lipo
Hi Chellie, the 2409-7t motor is quite low KV.
You probably could use in on a smaller ducted fan like the 70mmEDF but you will need 4S lipo for performance.
I have modified the motor so that it can fit into hoa ye 89mm EDF.
Runs around 36amps on 3S lipo. It spins the 89mm EDF at around 24,000 to 28000rpm.
babylon5 is offline
Old 03-02-2010, 04:25 AM
babylon5
Default 2409 7t motor modified for 89mm EDF
Hi Chellie, here is a couple of picture of what I did with the mentioned motor.
The entire EDF +motor + bullet weighs a mere 154grams.
For a time being, this motor setup will run on 3S lipo.
More next time.
ID:	122176   Click image for larger version
ID:	122177   Click image for larger version
ID:	122178   Click image for larger version
ID:	122179   Click image for larger version
babylon5 is offline
Old 03-02-2010, 06:42 AM
More next time.
Thats Kewl, Nice job, Just keep it under 100 MPH Take care, Chellie
Old 03-11-2010, 10:37 AM
babylon5
Default 2409 7t on 89-90mm edf test flight
Hi Chellie, test flight successfully, the 89-90mm EDF on a converted twin micro-jet .
Thrust is just 1:1 . The plane weights just over 1kg.
Runs on 4500mAH 3S packs peaks at 36amps at around 25000-29000rpm
This motor is 9pole and around 2.5Kv/V .
Plane is not very fast but quite fast.
Plan to upgrade the fan with a more powerful motor on 4S 400mah lipo.
More next time.
The blue colored plane in the back ground is the smallest version of micro-jet....all from multiplex.
ID:	122877   Click image for larger version
Name:	2) 90mm EDF.JPG
babylon5 is offline
Old 03-11-2010, 02:11 PM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
B 5 .. A club mate of ours flys those Micro jets. 4300 Kv motors and 4 inch pusher props. If he gets the C G right they are very fast.
Alpea42 is offline
Old 03-12-2010, 06:02 AM
babylon5
sorry, my previous post correct the statement...plan to run the edf on 4s on 4000maH ....400mah won't make it LOL
hi Alphea, the blue colored micro-jet are capable of over 100MPH with the correct pusher or EDF setup. Agree, the c.g is located at the bump but it is quite tricky to hand launch the plane with a pusher prop and mind those fingers during the launch.
babylon5 is offline
Old 03-12-2010, 06:06 AM
More next time.
Kewl those look great, i like the EDF on a pusher jet, because you wont get bit by a prop that way Take care, Chellie
Old 03-12-2010, 06:09 AM
I seen one micro pusher jet go 175 mph
[media]http://www.youtube.com/watch?v=46nxgGaGj94[/media]
Old 03-15-2010, 09:01 AM
babylon5
Hi Cheelie
Yes this particular micro-jet setup is just one crazy kilowatt hungry babe.
I think they juice the M-J to over a Kilowatt of power.
Next I am thinking of using your plane original plan for my next project but I will use corrugated plastic instead of depron foam with some modification to the wing to give it a suitable airfoil.
Corrugated plastic are more durable and take take in more abuse than depron foam.
babylon5 is offline
Old 03-15-2010, 09:32 AM
Hi Cheelie
Thats sounds neet please post some pics here of it Take care, Chellie
Old 09-18-2010, 08:13 PM
babylon5
Hi Chellie, long time no hear. I took some of your idea for the EDF tailess plane but use C.P. instead of Depron .
I built a proto-type with a flat wing shape and test glide and it seemed to glide pretty good.The glide test will approximate the c.g. position as well.
Next, I proceed cut out the actual CP material (2mm thick) and then bend and curve the CP material so as to give it a proper airfoil.
Attached are the various stages of the tailess EDF jet .
Many stiffener CP and ply added to the fuselage to yield reasonable rigidity.
The wing is 24 in span with the broadest width at 7in(without the aileron strip) and tapered 3inches width at the wing tip. This will give a pretty good aspect ratio.
The EDF will be a 55mm 6blade and will run between 16-18amps on 3 cells.
ID:	135686   Click image for larger version
ID:	135687   Click image for larger version
babylon5 is offline
Old 09-19-2010, 12:30 AM
That looks nice on mine, it did not like to be stalled, so keep it moving on the next one i make, it will be a mid motor design, that should take care of the stalling problem, if it stalls in the air, it would not recover. Take care and have fun, Chellie
Quick Reply: EDF pusher Jet scratch build- contest 2
Page generated in 0.18171 seconds with 29 queries
