New Spektrum Receiver, the AR500
Old 09-02-2008, 01:47 AM
Rabbitcreekok
Rabbitcreekok's Avatar
Default New Spektrum Receiver, the AR500
I just stumbled across this new Spektrum receiver, the AR500. It comes in the new Corsair with the 5 channel transmitter. I called Horizon to find out about since it is AR500 not AR5000. It is a full range, five channel receiver. It can be used in any type plane, not limited to smaller foam models like the limitations on the AR6100.
As you notice, it has a longer antenna on one side and it is also cheaper than the AR6200, if you need a full range receiver, but don't need six channels. It also will be easier to mount, since it does not have the satellite receiver.
I was planning on using an AR6200 in my Solution AP plane build, but now I can save a few bucks and use the AR500.
Rabbitcreekok is offline
Old 09-02-2008, 01:51 AM
Hey Nice find! I can see that getting a lot of sales!
Old 09-02-2008, 01:55 AM
gfdengine204
gfdengine204's Avatar
Well, we modelers have wanted a Spektrum 4-ch rx unit, but this is darn close.
Thanks for the heads-up, Jim!
gfdengine204 is offline
Old 09-02-2008, 02:04 AM
Tell me about it.
I am still yet to use more than 4 of my channels! well a couple of birds I have set up with flaperons using the aucx channel making use of #5 but for the most part... 4 is it!
Old 09-02-2008, 02:07 AM
gfdengine204
.....and actually, this is a 4ch rx with a 5th ch for ailerons if you have individual aileron servos for each wing!
I think it's a tad overpriced.....Would have been nice at $49.99......oh well.
Old 09-02-2008, 02:13 AM
Overpriced? I don't think so.
Compare it to any "good" 72mhz receiver then add the cost for a crystal and you'll be at the same price or cheaper.
Old 09-02-2008, 03:08 AM
gfdengine204
I never bought 72MHz gear, so I'll have to take your word for it.
But, just saying, you can get the AR6000 and AR6100 for under $40 at some vendors, and $60 seems a little steeper than I would imagine.......but, I am a cheapskate.....
Old 09-02-2008, 03:10 AM
That's true but they have been around for a while.
The AR6000's were 69.95 everywhere when they first came out. They will come down in time.
Old 09-02-2008, 03:11 AM
gfdengine204
From your lips to God's ears.
Old 09-02-2008, 03:13 AM
Everything comes down in time... in the electronics world anyway...
Old 09-02-2008, 03:49 AM
fr4nk1yn
^_^
fr4nk1yn's Avatar
My 6100es have been performing stellar. I can only stretch my latest planes straight up and have taken then to the limit of my sight a few times.
I don't really see "full range" with the harder to package, My antennae are glued to the sides of the case for protection, and higher cost being a selling point to me.
How many larger models are really "4" channel?
fr4nk1yn is offline
Old 09-02-2008, 03:53 AM
max2112
max2112's Avatar
Default One more reason for DX7
Too bad it's not compatible with the DX-6!
max2112 is offline
This one is 80"
and this one 72"
and this one 60"
A lot of big models still only use 4 channels.
Old 09-02-2008, 03:55 AM
gfdengine204
But it's DX6i compatible......
I'm gonna go hide now so John don't kill me for that.
Old 09-02-2008, 03:57 AM
And again on the park flyer receivers, it's not range that's an issue. It's shadowing. This gets discussed over and over. You can fly a small plane as far as you can see it and then some. Put that same rx in my Waco and it'll crash for sure when I can still see it plainly because the signal will get blocked by the batteries or the motor.
Old 09-02-2008, 04:04 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
These are the only two 5 channels I have
Ailerons
Elevator
Rudder
Throttle
Retracts
Everything else I have is 4 or less. ........for now.
ID:	76965   Click image for larger version
Name:	The Jug in flight.jpg
Grasshopper is offline
Old 09-02-2008, 04:05 AM
EpoweredRc
3D Flyer
EpoweredRc's Avatar
if this small 5 channel rx is $60 they can keep it, i mean really how many planes is the 6100 a prop with room? its smaller then any reg 72mhz rx ever was and cheaper I can buy it for $49
the 6200 dual anntenna is for $59
I understand its small and full range but I would not buy one untill I heard some reports, I have never had issues with my rx's untill got a 6100 in trade and it won't range, just sent to Horizen hope to hear back soon about it and hope they get it fixed but not sure I will ever trust it.
EpoweredRc is offline
Old 09-02-2008, 04:22 AM
max2112
max2112's Avatar
Smile I'm more offended by the Cubbie avatar!
No worries, Kev!
I have no problems admitting the only way I could afford the DX6 was because I waited 2 years and bought one used w/ no servos or receivers. Maybe in about 8 or 10 months I'll be able to pick up a used DX7 pretty cheap.
max2112 is offline
Old 09-02-2008, 04:28 AM
gfdengine204
No worries, Kev!
Sure, make me feel bad now.
Old 09-02-2008, 04:30 AM
We don't really need to TRY to make you feel bad... comes natural I would think!
Old 09-02-2008, 04:31 AM
gfdengine204
Now how nice was THAT?
Old 09-02-2008, 04:32 AM
Grasshopper
He's used to feeling bad. Just look at his avatar.
Old 09-02-2008, 04:36 AM
gfdengine204
Geez, how did I know YOU would gang up.....musta been a PM from Bill.....
Let's get this back on topic, ok folks?
Old 09-02-2008, 04:39 AM
Topic??? what was the topic??? oh yeah receivers...
Lot's of big planes that are only 4 channel...
Old 09-02-2008, 04:42 AM
gfdengine204
No, the topic is:
Quick Reply: New Spektrum Receiver, the AR500
Page generated in 0.12295 seconds with 13 queries
