AX new glider.
Old 08-05-2008, 05:29 AM
cebola
cebola's Avatar
Default AX new glider.
When I design AX I was thinking on the beginner.
The concept -laser cut and very easy to assemble is the main line of this design.
Some Ax features.
A glider for cheap servos, engine, prop, and radio.
Easy to build sophisticated on appearance.
Light and, and easy to transport.
Easy to fix and repair
Good performance on thigh thermals, flyable in any small place.
Strong and resistant.
Good L/D
Some Ax data
Wingspan -74’”
Wing chord at root 9”
Wing chord at tip 5”1/2
Aspect ratio 8.6
Wing Area 41 dm2
Airfoil HQ 3,0-10 – HQ 3,0-9
Spars rounded spruce 3/16 diam.
Weight empty 10oz (on structure)
Some Ax photos on structure, after more photos covered, and in flight videos.
Hope you like it!
Cebola
Brazil
Name:	AX & Krishna 046.jpg
ID:	74554   Click image for larger version
Name:	AX & Krishna 049.jpg
ID:	74555   Click image for larger version
Name:	AX & Krishna 050.jpg
ID:	74556   Click image for larger version
Name:	AX & Krishna 056.jpg
ID:	74557   Click image for larger version
Name:	AX & Krishna 059.jpg
Name:	AX & Krishna 055.jpg
ID:	74559   Click image for larger version
Name:	AX & Krishna 047.jpg
ID:	74560   Click image for larger version
Name:	AX & Krishna 058.jpg
ID:	74561   Click image for larger version
Name:	ax picttures 013.jpg
ID:	74565   Click image for larger version
Name:	ax picttures 007.jpg
File Type: pdf
File Type: pdf
cebola is offline
Old 08-05-2008, 05:39 AM
cebola
cebola's Avatar
Some videos, and more photos.
[media]http://br.youtube.com/watch?v=rZwcAGkq2nQ[/media]
[media]http://br.youtube.com/watch?v=siCs-1_ckCs[/media]
Cebola
Brazil
ID:	74573   Click image for larger version
Name:	ax picttures 016.jpg
ID:	74574   Click image for larger version
Name:	ax picttures 001.jpg
ID:	74575   Click image for larger version
Name:	ax picttures 009.jpg
ID:	74576   Click image for larger version
Name:	ax frota.jpg
ID:	74578   Click image for larger version
cebola is offline
Old 08-05-2008, 02:25 PM
Does this mean that the glider, built and covered, before electroncis, weighs 10 ounces? If so, that is amazingly light. Nice work!
AEAJR is offline
Old 08-05-2008, 04:15 PM
cebola
cebola's Avatar
Hi AEAJR
Ax structure weights has follow
Wing- 5,5oz
Fuse 3-oz
Tail group 0,7oz
Push rods and miscellaneous 0,5oz
The balsa for fuse stringers, are very hard 3;16, also the trailing edge.
Wing ribs are in medium Midwest balsa
Coverage, in super Monokote transparent blue (the heaviest part).
Glue, thin CA, and Titebond glue has reinforcement.
Spars, are in Midwest dowels 3;16 diameter spruce, whit vertical grain webbings.
The kit was laser cut in all parts, and Acad designed, this is the worst part in create models.
regards
Cebola
Brazil
cebola is offline
Old 05-24-2009, 06:36 PM
cebola
cebola's Avatar
More about AX
http://www.rcsoaringdigest.com/pdfs/...SD-2009-06.pdf
Cebola
Brazil
cebola is offline
Old 07-05-2012, 12:26 AM
KeithMc
Cebola,
The AX looks like an amazing glider. You mention in your first post that "the concept is laser cut . . ." Do you have files for laser cutting the parts? Figuring out where to drill all of the holes in the ribs for the dowel spars looks like quite a challenge. I would like to have, at least, the ribs laser cut.
Thanks,
Keith
KeithMc is offline
Old 07-08-2012, 07:19 PM
Rockin Robbins
Rockin Robbins's Avatar
Looks like a Wanderer! Should be a great flyer.
Rockin Robbins is offline
zerts
07-16-2008 03:05 AM
Leebert
05-16-2008 04:02 AM
pburt1975
02-07-2008 03:47 AM
Twmaster
02-08-2007 01:46 AM
ragbag
01-19-2007 12:23 PM
Quick Reply: AX new glider.
Page generated in 0.10978 seconds with 33 queries
