New Corsair - My first all-scratch build
Old 06-01-2008, 05:54 AM
phupper
Flyin' Phup
phupper's Avatar
Default New Corsair - My first all-scratch build
This has been my project for the last month or so. Until now all my planes were conversions from chuckers. This time I used Elmers board and made my own wings and fuse.
Here's a link to the build pictures, as well as more finished pics. Enjoy!
http://home.roadrunner.com/~phup/new..._-_scratch.htm
Phil
phupper is offline
Old 06-01-2008, 06:02 AM
fr4nk1yn
^_^
fr4nk1yn's Avatar
Fantastic craftsmanship there. That would be fantastic from a kit, but scratch built...
fr4nk1yn is offline
Old 06-01-2008, 06:39 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Looks really good Phil. You did a great job finishing the foam.
Grasshopper is offline
Old 06-01-2008, 07:20 AM
Larry G
E-Pilot
Is the fuselage material chunks of packing foam glued together?
Sweet looking scratch build!!!!
Larry G is offline
Old 06-01-2008, 07:50 AM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Great looking F4U Phupper. Get some video of flight if you can .Come out to Chino fairgrounds if you live close by and we'll film for you LOL.
Alpea42 is offline
Old 06-01-2008, 11:16 AM
phupper
Flyin' Phup
phupper's Avatar
Thanks guys.
"Is the fuselage material chunks of packing foam glued together?"
That's how the fuse started out. Once I had the correct shape, I glued a sheet of Elmers foam board around it. Then much of the packing foam was hollowed out.
Phil
phupper is offline
Old 06-01-2008, 11:24 AM
Originally Posted by phupper View Post
Thanks guys.
Phil
Super nice Job Phil keep up the great work, Chellie
Old 06-01-2008, 06:11 PM
pd1
Still Learning
pd1's Avatar
Nice, very nice.
pd1 is offline
Old 06-01-2008, 07:34 PM
alienx
alienx's Avatar
Wow, I looked at your build pics. You could never tell what this plane looked like before you started. Very nice.
alienx is offline
Old 06-02-2008, 10:35 PM
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
Very nice. Is that cloth tape you have on the elevator and rudder? You did this in a month?! What did you use to seal the foam before painting? Yes I am full of questions, but I have a scratch build project of my own I am working on and one behind that as well.
P.S. You should get your pilot out of the bathroom and into the cockpit.
Voyager2lcats is offline
Old 06-02-2008, 11:25 PM
gfdengine204
gfdengine204's Avatar
Phil,
That looks absolutely fabulous! Nice work!
gfdengine204 is offline
Old 06-03-2008, 12:28 AM
phupper
Flyin' Phup
phupper's Avatar
Thanks guys!
"Is that cloth tape you have on the elevator and rudder? You did this in a month?! What did you use to seal the foam before painting?"
That's Ultracote on the rudder, elevator, and aileron hinges. It works best if you needle-and-thread a few stitches along the hinge line to hold the upper and lower hinge pieces together.
After spackling/sanding the blemishes (I can see) from the raw foam, I like to spray color over it. The solid color lets you see every little dent and bump you missed before, and the color is easy to sand so those can be fixed easily. Clear water-based polyurethane (I used gloss) goes on last to protect the paint. It also will make the color a little darker so plan ahead.
I started this build on April 21st, so 5 weeks is more accurate.
Phil
phupper is offline
Old 06-03-2008, 01:27 AM
Frodo
Frodo's Avatar
WOW!!! I could only dream...
Frodo is offline
Old 06-03-2008, 02:29 AM
Voyager2lcats
Thanks Phil. That's great information I can use (I am already using water-based polyurethane)!
Old 06-03-2008, 05:54 PM
TheEpoxyFlyer
Pretty Fly 4 a white guy
TheEpoxyFlyer's Avatar
Sweet! I have a weakness for the Corsiar....
TheEpoxyFlyer is offline
Old 06-03-2008, 07:16 PM
Voyager2lcats
Yes. I think I noticed that! Do you have one that you fly?
Mac1z
08-23-2008 04:21 PM
spitace
09-01-2007 06:06 PM
Murdock1
Beginners - Helis
07-02-2007 06:20 PM
Tonym
Beginners - Helis
03-20-2006 06:58 AM
ericthetree
Foamies
25
03-02-2006 04:53 AM
Quick Reply: New Corsair - My first all-scratch build
Page generated in 0.15689 seconds with 14 queries
