The Official DonsRC Wicked EDF Motor Discussion Thread
Old 03-14-2008, 04:58 AM
  #126
Tusken
Originally Posted by hyperdynelabs View Post
Cool video! Mine behaves the same way with Don's motor on 4s.
With the stock motor and 3s launching gave me an uncomfortable pucker factor. I love launching it now since it just goes up in the air on 4s!
Heck ya, barely have to toss it now, allmost flies out of my hand.
Tusken is offline
Old 03-15-2008, 06:46 AM
  #127
AETCBoom4
Originally Posted by Tusken View Post
Here is my EF-16 with don's wicked extreeme, stock fan on a 4s Loong Max . Life is good on 4S
[media]http://www.youtube.com/watch?v=12xC8YgvVQk[/media]
what is your watt/amp pull with the Loong Max? Anyone have a feel for this batt with this setup?
http://www.hobbycity.com/hobbycity/s...idProduct=6265
AETCBoom4 is offline
Old 03-17-2008, 07:01 PM
  #128
hyperdynelabs
IIRC with the wicked extreme and 4s Loong max, amp draw was around 38 amps.
hyperdynelabs is offline
Old 03-17-2008, 11:47 PM
  #129
AETCBoom4
What was your watt pull? I'm trying to compare this with what I got before placing another order with Hobbycity. This is what I'm currently using. http://www.hobbycity.com/hobbycity/s...idProduct=6265
Old 03-17-2008, 11:52 PM
  #130
hyperdynelabs
I dont recall exact numbers. But it was in the 510-530 watt range.
Old 03-19-2008, 04:05 PM
  #131
PerlAddict
PerlAddict's Avatar
Don,
Do you have any numbers/graphs of the Wicked 4800Kv's with 5-blade Alfa rotors and Loong Max 4S (and 3S if handy) packs?
PerlAddict is offline
Old 03-20-2008, 02:14 AM
  #132
The Don
Balsa Butcher
The Don's Avatar
Originally Posted by PerlAddict View Post
Don,
Yes I do.
First graph is 5 blade alfa, wicked 4800 with LM 4S2250.
Second is 5 blade, wicked extreme 5400 on 3S2200 lipo.
Third is 5 blade with Wicked 4800 on 4S2200 TP Extreme V2
Don
ID:	60144   Click image for larger version
ID:	60145   Click image for larger version
The Don is offline
Old 03-20-2008, 05:25 AM
  #133
PerlAddict
PerlAddict's Avatar
Thanks a bunch, Don. How come no amp readings on those? I was actually asking because I wanted to double check and make sure on what ESC I wanted to get.
Old 03-20-2008, 05:30 AM
  #134
The Don
Balsa Butcher
The Don's Avatar
Because I forgot to click the button to add it to the axis :o
Let me reopen the FDR file and replot them.
Don
The Don is offline
Old 03-21-2008, 02:36 AM
  #135
The Don
Balsa Butcher
The Don's Avatar
Here it is with amps, I took watts off so you can see the amps scale more clearly.
Don
The Don is offline
Old 03-21-2008, 06:24 AM
  #136
PerlAddict
PerlAddict's Avatar
Thanks, Don. I was thinking of using a 50A ESC, but I think using a 60A may be a wiser idea, even though it means adding another .5oz of weight.
Old 03-26-2008, 01:04 PM
  #137
Bill G
Super Contrubutor
Bill G's Avatar
Well Don your Extreme 4800 is in my EDF64 Yak23 and it flys fine now. Wish I had batt room for 4s. I think I still may need to enlarge the cheater a bit more, as there is probably more power in the motor.
The sound of your motors adds a bit to the jet sound, compared with the inrunners. Seems like a real solid motor.
Bill
Bill G is offline
Old 03-27-2008, 06:14 AM
  #138
The Don
Balsa Butcher
The Don's Avatar
Awesome looking model!!!! Is that a kit or scratch build?
Don
The Don is offline
Old 03-28-2008, 01:42 AM
  #139
Bill G
Super Contrubutor
Bill G's Avatar
Don
Scratch built city. Actually the wing is a trimmed Parkzone Cub wing.
I even tried another full airfoil wing on it later, but it didn't do as well, since the plane is heavy and really likes the lift of the undercamber. I did pad the underneath with a layer of sheet balsa in the front portion, to remove some of the undercamber to reduce drag.
The chrome really stands out on sunny days too.
RBC sells a larger kit version of the Yak23 for a 70mm. I'd really like to have one.
Bill.
Bill G is offline
Old 04-21-2008, 03:46 AM
  #140
CarreraGTSCS
CarreraGTSCS's Avatar
Don,
Have you run any tests using any of the Wemo fans?
CarreraGTSCS is offline
Old 04-21-2008, 05:07 AM
  #141
The Don
Balsa Butcher
The Don's Avatar
Which Wemo you had in mind.
Don
The Don is offline
Old 04-22-2008, 06:11 PM
  #142
Bill G
Super Contrubutor
Bill G's Avatar
Speaking of Wemo, I put your 30A Pentiums in a ME262 Scratchbuild with Hyperion 6000kv motors/Microfan. They probably won't stay there permanently, but was a fun experiment and flew well. Already flown before with EDF55s.
I would bet your Extreme 4800 would be good in a Minifan.
Bill
Bill G is offline
Old 04-23-2008, 06:25 AM
  #143
The Don
Balsa Butcher
The Don's Avatar
Wemo mini fan shipped out to me today
Don
The Don is offline
Old 04-23-2008, 07:02 AM
  #144
PerlAddict
PerlAddict's Avatar
Don, have you gotten in those spacers for the EDO fans and adapters yet? My replacement F-18 is coming in from Hobby Lobby, and I want to go ahead and stick a Cool Wind motor in this one right off the bat to run off 4S, and hopefully have it ready in time for SEFF. I've got a 40A Suppo ESC and an external BEC sitting here that I can use, so I'm hoping that will be enough if I stick the ESC in the thrust tube instead of the underside and get some airflow going over it.
Let me know and I'll shoot you an order in the morning.
- Dave
Old 04-23-2008, 10:26 AM
  #145
The Don
Balsa Butcher
The Don's Avatar
I just got a bag of 500 of those spacers You just drop it into the rotor then when you press the rotor onto the alfa plug it will stop it from pushing on too far.
Don
The Don is offline
Old 04-23-2008, 02:25 PM
  #146
PerlAddict
PerlAddict's Avatar
Awesome! You'll have my order shortly after 8:00 a.m. CST when I get to the office.
Old 04-23-2008, 03:52 PM
  #147
PerlAddict
PerlAddict's Avatar
Got my order in. =) I hadn't realized what a good deal I got on those first two Cool Wind motors I got from you back when they first came out! Not that they're that they're that much more now that you've got them listed on the site, but I hadn't realized you ate the shipping costs on my order before. So thanks for that, in hindsight. Was very nice of you and I appreciate it even if I didn't know it at the time.
Alright, I'm ready for some zoom-zoom!
Old 05-03-2008, 05:58 AM
  #148
The Don
Balsa Butcher
The Don's Avatar
I just finished my new Electrifly L-39 model.
Setup:
Wicked EDF Extreme
3S 2200 TP Extremem V2
Pentium 40 ESC
Esky 8 gram servos.
AUW is 21 ounces.
I added an outlet nozzle to try and boost the speeds a little. Hope to maiden this weekend if the rain holds off
ID:	64587   Click image for larger version
The Don is offline
Old 05-04-2008, 01:36 AM
  #149
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Thats a nice looking model Don.
Does it come pre-painted?
Hows the ducting?
Im very glad to see that your bench looks a lot like mine - now I dont have to feel so bad about my messyness!
Larry
Larry3215 is offline
Old 05-04-2008, 04:38 PM
  #150
easytiger
Banned Permanently
Hey, Don...I have that A-10, along with another one of those fan/motor combos, finally packed up for you. Should be out in the morning. Have fun.
easytiger is offline
Quick Reply: The Official DonsRC Wicked EDF Motor Discussion Thread
Page generated in 0.15549 seconds with 20 queries
