The Official DonsRC Wicked EDF Motor Discussion Thread
Old 02-11-2008, 07:06 PM
PerlAddict
PerlAddict's Avatar
Originally Posted by The Don View Post
Well I will tell you that the Alfa retro fit was annoying when I did mine. And basically the Wicked with 4S and alfa 5 blade verse XF fan 4S Wicked Extreme are the same watts and you get the same top speed. So thats is why I am using the stock fan and going that way and saving the $$$.
Why not try to use a sharp razor and cut the section off over the EDF unit? I actually cut my lower piece into three sections, the front and back were glued real good, and the middle I tack glued so I could take it take it off and on if needed by cutting the glue joints.
Don
I would do that, but I've got so many planes to put together right now that I hate to start taking the finished ones back apart before I even fly them. That, and I don't have a spare 40A speed controller at the moment and don't want to spend money for any more right now.
I'll at least get a maiden flight in on the stock system before I switch over. That way I can appreciate it more.
PerlAddict is offline
Old 02-12-2008, 02:56 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Don -- I just purchased a new RPM sensor for my Eagle Tree Systems Data Logger...
In order to set this RPM sensor up properly, I need to know how many magnets your Wicked EDF Extreme Motor has in the bell.
Can you please share this information with me? :o
Old 02-12-2008, 06:37 PM
The Don
Balsa Butcher
The Don's Avatar
Set it to 6 poles.
Don
The Don is offline
Old 02-12-2008, 08:38 PM
Lieutenant Loughead
UNCLUB OWNER
WOW! Only 6 poles?
Old 02-12-2008, 10:55 PM
The Don
Balsa Butcher
The Don's Avatar
Its the only way to get the high RPMS and not out run the ESCs.
Don
The Don is offline
Old 02-13-2008, 04:21 AM
The Don
Balsa Butcher
The Don's Avatar
Tested the stock EDF unit in the EDO F-15, same fan as the Hobby Lobby ARF and RTF F-18 they sell.
EDO Stock 64mm fan 5 bladed fan:
3S lipo, Wicked EDF motor, 41,000 rpm, 35 amps, 360 watts
That means a nice power boost over stock setup! The other good thing is the stock rotor adapter is the same diameter as an Alfa rotor plug. I just used one of my Alfa rotor plugs and pressed the rotor on to it. It was a firm press fit. Another interesting thing to note is the 5 bladed rotor is the exact diameter of a GWS EDF64, and the blade shape is even the same but the blade and hub are thicker and they do not distort. When I get more 4000KV motors in stock I will test on 4S. But a good upgrade for these kits may be to simply use a GWS rotor.
Don
The Don is offline
Old 02-13-2008, 04:39 AM
Hi Everyone I bought a wicked motor from Don, and its a great little motor, with a 1800mah 4 cell 20c lipo, 40 amp ESC and 4.7 x 4.2 apc speed prop, It Scares the Heck out of me Its Screams Bloody Murder, now I just need to Master getting the Mini Bee Wing into the air, I got one flight in with the 4 cell lipos, and speed prop, and it was fast, even at 1/3 throttle, at full throttle, I think I will make it into the 100 mph club I just need to get used to the less thrust with a speed prop to launch it, with a thin apc prop, its no problem, I am just Wondering, what size Ducted fan, would I need, for a mini bee wing or a Lynxs ? Keep up the good work Don, Chellie
Lets see 14.8v x 3000kv = approx 44,400 rpm No Wonder it Scares The Heck out of Me
Old 02-13-2008, 04:50 AM
rcproptester
We the People...
rcproptester's Avatar
Don, would one of these motors fit into a 45mm fan unit? I have a Kyosho illusion df45 that I need to fix after a crash, and was thinking of upgrading the motor and fan when I do.
rcproptester is offline
Old 02-13-2008, 04:52 AM
The Don
Balsa Butcher
The Don's Avatar
I would think these are way too big for that tiny fan.
Don
The Don is offline
Old 02-13-2008, 04:59 AM
rcproptester
We the People...
Dang. I have heard that some guys were doing a conversion with a LSJS motor and a Haoye or wemo micro fan.
Would one of these fit in a Wemo micro fan?
Old 02-13-2008, 05:05 AM
The Don
Balsa Butcher
The Don's Avatar
Did they have to use the standoff adapter to make it fit? I dont have either one of those fans to measure. The smallest fan I have mounted in is a GWS EDF55 and a Hyperflow fan.
Don
The Don is offline
Old 02-13-2008, 01:32 PM
TOMSAID
Must say I am most impressed with Dons service , I ordered a wicked extreme Friday received it Tuesday, thats faster than I would expect here in the UK. Quick reading on 3s for phase 3 f16 on xf fan was 32 amps 345 watts. Will get 4s set up at the weekend, in the mean time will see how it goes on 3s.
TOMSAID is offline
Old 02-13-2008, 03:53 PM
aethertek
aethertek's Avatar
The microfan shroud is .98" ID X .937 L,
larger than the current adapter.
A custom adapter could be machined to fill the motor mount or use the existing adapter & take a chance on breaking the micros shroud mount(thin plastic& brittle) mine cracked at the screw holes & a guide vane separated from the shroud. This was just testing a himaxx 5300 in it. A really good fan but the shroud needs some work... hmmm my next project maybe.
Don maybe a good choice for your 4000?
Kevin~
aethertek is offline
Old 02-13-2008, 06:29 PM
Pinecone
How about for a GWS 75 in an A-4?
Pinecone is offline
Old 02-13-2008, 06:43 PM
The Don
Balsa Butcher
The Don's Avatar
I have one on order will post data as soon as I can.
Don
The Don is offline
Old 02-13-2008, 08:06 PM
Bill G
Super Contrubutor
Bill G's Avatar
Now we need to get you building EDFs.
Admittedly not as efficient as pushers, but its the cool factor that's worth it.
Bill G is offline
Old 02-14-2008, 12:19 AM
The Don
Balsa Butcher
The Don's Avatar
Originally Posted by hyperdynelabs View Post
I can say the wicked extreme motor on 4s with an xf fan is absolutely awesome! My HP F-16 looks like a rocket, 100+ mph is cake with Don's setup.
Where did you mount your XF fan? Is it in the stock location? Or did you move it back? Any balancing issues on 4S?
Don
The Don is offline
Old 02-14-2008, 12:34 AM
Hi Bill I like the EDFs one reason is because the fan is not out in the open, much much safer, So i am following this thread to learn of a good power system, that will push a lynx or similar plane 100mph or more, I really like the Dons motors, they have a lot of power to them, for the money, they are hard to beat, Take care, Chellie
Old 02-14-2008, 12:36 AM
And I think I may have found what I was looking for Chellie
Old 02-14-2008, 01:44 AM
rcproptester
We the People...
Kevin~
Old 02-14-2008, 02:32 AM
hyperdynelabs
I mounted the fan 3" back from the lip inside the duct. I know the instructions say 2.5" max, but with the 4s battery if you go 3" back then it will balance fine.
I have my 4s loong max battery mounted 1/4" from the back of the cockpit with an AR6200 mounted up in front. Balance point should be around 180-185mm from TE of wing (within 160-190mm spec). No extra weights needed to balance it.
Plus you can run 3s by just mounting a 3s batt a tad forward.
Don
hyperdynelabs is offline
Old 02-14-2008, 11:13 PM
TOMSAID
What size battery are you using I have noticed on 3s that the increase in weight from a 1700 to a 2200 makes quite difference when launching even though its only 35 grammes. Most of the 4s 2200 available here are another extra 60 grammesabout 240-250 grammes for a 2200 4s, does the extra thrust from the wicked extreme make up for this extra weight, and how does it effect landing at present it can float in against a light wind.
TOMSAID is offline
Old 02-15-2008, 01:28 AM
hyperdynelabs
Using a 4s batt the wicked extreme will get you near 1:1 thrust-weight ratio, which is a great improvement over stock. The plane still floats in fine, I can still do a high alpha on landing. The plane is still balanced, and with 4s it doesnt alter flight characteristics from what I have seen.
If you are going to a heavier battery and not rebalancing your CG, I can see a difference in launching. On 3s and a nose heavy bird, expect launching to be a bit different. Use lots of up trim.
Old 02-15-2008, 05:08 AM
The Don
Balsa Butcher
The Don's Avatar
Tom,
The power increase form 3S to 4S is HUGE. It will fly the extra weight with no problem. 3S on the Wicked Extreme is similar to the stock setup as the KVs are close. The real difference comes on 4S. The stock motor will burn up after a few flights on 4S, the Wicked Extreme will not. By the way, glad to see the motor got to you so quickly!!!
Don
The Don is offline
Old 02-15-2008, 11:32 AM
TOMSAID
I saw that on the box the motor was delivered in it says use low timing only, earlier in this thred you have said the motor is 6 pole. My escape information says 2 pole low 6 pole middle setting, is it better to stay with low timing or use the middle setting, also what is the frequency setting of the motor or is this not critical.
TOMSAID is offline
Quick Reply: The Official DonsRC Wicked EDF Motor Discussion Thread
Page generated in 0.12506 seconds with 11 queries
