Should Start a thread on the Eflight DHC-2 Beaver..?
Old 06-05-2008, 03:22 AM
  #126
Charley
Charley
Originally Posted by beavenx5 View Post
The Taylorcraft is supposed to be a nice flyer also but I don't see many reviews of it with floats. TAnd the PBY looks tricky, this is why I think I will hold it off until I have a little more experience. I only started flying last November
I have a T'craft on floats. Here's the thread:
http://www.rcuniverse.com/forum/fb.asp?m=7541620
This will get you into the middle of the thread, which I started scroll up to the beginning and you'll see pics and my setup info. Feel free to PM or Email me if you want.
The model flies beautifully, wheels or floats. I also have a Beaver on floats. The T'craft ROGs better, IMHO.
CR
Charley is offline
Old 06-05-2008, 10:49 AM
  #127
nascarwings
nascarwings's Avatar
nice job on the job T'craft ....i was looking at one but the only floats i could seem to find were the gws one,s and i think they might be a little small..you said you have a beaver..on floats, what do you think of it ?...
nascarwings is offline
Old 06-06-2008, 05:56 AM
  #128
Charley
Charley
Thanks,
There are a couple of Eflite Beaver threads. Look 'em up. No need for me to add more.
CR
Charley is offline
Old 06-06-2008, 02:59 PM
  #129
beavenx5
beavenx5's Avatar
Thanks Charley for you opinion on the T-Craft and for the link.
I was at my LHS last night. He has the T-Craft on back order for at least 5 more weeks but had a Beaver there reserved for another customer. I got to open the box: what a nice plane and I think I can open the front over the battery compartment to fit my huge 5s A123 batteries...I ordered it last night at my LHS just before closing but I am having second thoughts...
I will call my LHS back this morning as soon as they open and cancel the Beaver and get in line for a T-Craft. From the comments about them here and on RCU, it realy looks like I shoud start with the T-Craft and then later on in the fall or next year move to the Beaver. This is the wise thing to do...
One of the big advantage of the T-Craft for me is that my T-28 Trojan, although still flying, is quite tired (too many hard landings and small crashes). I would leave the servos in the T-28 and use the E-Flite 25A ESC, Park480 910Kv motor and AR7000 receiver from the T-28 and install them in the T-Craft. This will cut the cost of this project in half and would be easy to swap back and forth between the 2 planes if needed. I also have 6 lipos for it :p.
I have exchanged e-mails with Mark from seaplanesupply and he seems like a great guy with the right floats for the T-Craft (the 24" or 26" Flat bottom ones)
beavenx5 is offline
Old 06-06-2008, 04:07 PM
  #130
nascarwings
smart man!!...dont get me wrong about the beaver nice plane just a hand full to get set up ...and with a couple of changes on eflites part should be a nice scale flyer..after seeing the nice job charley did setting it up for floats..think i might have to add one to the old hanger.....keep me posted on the floats there is also floats made for a little plane they call Wilga 2000 it has 24 inch floats..not sure if they would work but might on the t craft
Old 06-07-2008, 01:02 AM
  #131
navy atc
Default Ditto
I too think thats a good idea.Especially, as you indicate, the Trojan's taking a lickin still.
As far as swapping servos.For my Late Taylorcraft, I used hs65's Karbonite for rudder and elevator.HS 55 for ailerons. Ill use 65's all around on round 2.May be overkill, but oh well. The T-craft w/a 480 is a screamer.I was amazed at the acrobatics it could do and its a beauty to look at.
Good Luck Man!
navy atc is offline
Old 06-07-2008, 01:49 AM
  #132
Charley
Charley
Default Beaver Floats?
Gang,
This may be heresy but if I had it to do over I'd use foam or built-up balsa/ply floats instead of the fiberglass ones from E-flite. Those suckers are heavy! And so is the supplied hardware.
CR
Charley is offline
Old 06-27-2008, 03:30 AM
  #133
nascarwings
any one still flying the beaver.....mine are still going....i think i have the beast under control..lol....
Old 06-27-2008, 04:22 AM
  #134
navy atc
Default Hey Nascar
Hey man, hadnt heard from ya. I've been dorkin around modifying a HZ SC wing of late, and have been slooow on BeavII.But, should go up this weekend.I hope to post pics of slight electronis bay mod, dual rudders and of course the Lights...
Please, regale us with your "tails of Beaver conquests"..
oh yeah, we want pictures too.
Good hearin from ya
navy atc is offline
Old 06-27-2008, 06:51 PM
  #135
nascarwings
Default beaver
Im starting to get a few hours logged on this bird...and still flys like a truck...lol...it requires alot of up elevator on the trim and no mixing required... ...was flying it in some gustey winds yesterday, was trying to land it in cross winds...15 mph...lol....[media]http://www.youtube.com/watch?v=BlOdYlt6RC8[/media]
Old 07-06-2008, 06:53 PM
  #136
clt12981
clt12981's Avatar
Smile DHC-2 Beaver
GREAT PLANE!
I have the beaver with over 100 Water flights on it. The plane will fly and I have flown it with many motor and battery combo's. My first flights were with the 32 and 42004s combo, more then enought power. Will do vertical till your tired. 42003s will do all standard moves no prob.Have flown with 25 and 3s. Fls like slow flyer just be careful and don't stall, needs long run to get off water. 42004s will fly OK. I like a lot better then my J-3. Landings no probs. Good luck great plane.
clt12981 is offline
Old 07-17-2008, 03:58 AM
  #137
clt12981
clt12981's Avatar
Default My Fleet
Name:	Seawind 3-08 (2).jpg
My water fleet.
Chuck
clt12981 is offline
Old 08-13-2008, 02:04 AM
  #138
nascarwings
Default Beaver Cub
Just wondering if any ones still fliying the beavers.....Click image for larger version
Old 08-13-2008, 02:15 AM
  #139
navy atc
Default still flyin beavers
yep. Unfortunately not as much as I want. The only place big enough to fly the seaplane is 25 miles away. When I first started flying it, I thought nothing of making the drive.Now w/gas the way it is, Ive only been to fly Beav 2 once. How are your reincarnations doing? Still making me look bad w/your cool float mods. Send pics if you have. Good hearin from you.
navy atc is offline
Old 08-13-2008, 02:20 AM
  #140
iFLYrc_Vic
I maidened mine several weeks ago. I really like the plane even with the adverse yaw. Makes a real pilot out of you as you have to use the rudder to properly make turns.
iFLYrc_Vic is offline
Old 08-13-2008, 02:39 AM
  #141
clt12981
clt12981's Avatar
Default Beaver Flying
Yep. With lake 300 feet outside of back door. Probably fly the Beaver 6-8 times a week. Up to 192 flights on it now. It's still in one piece to.
Chuck
P.S. It's gotten wet a couple of times tho.
clt12981 is offline
Old 08-13-2008, 10:53 PM
  #142
nascarwings
hey navy that sucks..25 miles to fly im lucky i guess im about 25 feet from my front door....and im paying about $5.50 a gal for gas up here now that sucks..lol...
Old 08-13-2008, 11:11 PM
  #143
nascarwings
Default just some pics...
some pics from the lake....Click image for larger version
Old 08-14-2008, 01:38 PM
  #144
navy atc
Default nice pics
Nice shots Nas. As I sit here looking at them, I'm wondering what kinda lame excuse I can find to ditch work today and go fly.
Alas, I've used them all.
5.50 a gallon? I dont feel so bad. Its dropped to about 3.75 in Atlanta.
Take care
navy atc is offline
Old 09-24-2008, 01:30 AM
  #145
nascarwings
Just a note my beaver had its last flight today...lost all power from bad battery connection i guess , lost all control sailed in from about 200 ' not nice...and the price eflite wants for a new one (249 dollars last i looked you would have to be a nut to pay that), the beaver is just a memory now...and i think eflite is to...
Old 09-24-2008, 01:45 AM
  #146
clt12981
clt12981's Avatar
Default Beaver
My Beaver today after 200 Flights.
Chuck
Name:	Beaver Floats.jpg
ID:	79016   Click image for larger version
Name:	Beaver Floats (3).jpg
clt12981 is offline
Old 09-24-2008, 01:47 AM
  #147
nascarwings
still looks good need any parts...lol
Old 09-24-2008, 02:23 AM
  #148
navy atc
Default Oh Man
I am sooo sorry for ya NW.I had the very same thing happen, only at 20ft, so wasnt too bad.What a helpless feeling. Oh man.
Likely your floats exploded too right?
99.99 bucks now to replace those. Im with ya on that price of a new one.
Eflite can keep it. They've turned me away on their increases.
They want 169.00 for a taylorcraft!!!??? Maybe when gas goes back to
2.50 a gallon, but for now, this poor boy is lookin out of necessity, elsewhere.
Take care NW. Youre a great modeler man.
Keep in touch.!!
navy atc is offline
Old 09-24-2008, 02:34 AM
  #149
nascarwings
[ATTACH][ATTACH]Click image for larger version
ID:	79029[/ATTACH][/ATTACH]yep the floats are in rough shape..lol....ya want some fun on water i took a telemaster 40 and put it on floats...lol...what a blast to fly....
ID:	79027   Click image for larger version
Old 09-24-2008, 02:40 AM
  #150
navy atc
[ATTACH][ATTACH]Attachment 79029[/ATTACH][/ATTACH]yep the floats are in rough shape..lol....ya want some fun on water i took a telemaster 40 and put it on floats...lol...what a blast to fly....
Good job as usual. Yer killin me. Some guy was selling one rtf for 130.00 bucks at a flea mkt last week.Elec set up. Natch, I didnt have the cash on me.
I hadnt thought of putting it to sea or I problably wouldve finagled some deal.
navy atc is offline
Quick Reply: Should Start a thread on the Eflight DHC-2 Beaver..?
Page generated in 0.14846 seconds with 18 queries
