Parkzone J3 Cub BL
Old 09-16-2010, 04:38 AM
  #151
Gofer303
Gofer303's Avatar
I can not get a new shaft for the 370 brushless in the LHS will have to order online does any one make a comparable slightly stronger motor for the J3?
Gofer303 is offline
Old 10-17-2010, 03:26 PM
  #152
Gofer303
Gofer303's Avatar
Got a new shaft and found out that the set screws to hold the bell to the shaft would not tighten up ever again apparently a single shaft motor! Been thinking of and tried to put a Motrolfly dm2210 motor with a 3s 1300 mah 25 c battery and man the thrust on a 6" prop was amazing could not put that up in air as Idle made it Rog! full I could hardly hold on to the plane ! So I am gonna put it on a slow stick and fly a big camera that ought to tame it down! Might have to get a new motor unless some one can tell me how to re-shaft without permanently sealing bell to motor.
Gofer303 is offline
Old 06-09-2011, 08:26 AM
  #153
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
i have this bird, and have replaced the stock electronics with a 30A esc and a Power up 400 zoom (2200Kv) From Headsuprc.com run on 7.4v 2s Lipos w/8x4e prop. and the performance is wonderful. i just ordered a set of GWS floats to add to the Fun. Has anyone else successfully put floats on this bird?
HeliScRapYard is offline
GreenAce92
8
06-14-2008 02:48 AM
Grasshopper
05-18-2008 02:45 AM
Figure.N9ne
ParkFlyers
03-05-2008 03:30 AM
GreenAce92
ParkFlyers
13
02-28-2008 02:31 AM
GreenAce92
Test Posting Forum
04-09-2007 03:42 AM
Quick Reply: Parkzone J3 Cub BL
Page generated in 0.08596 seconds with 12 queries
