Hangar 9 Corsair
Old 04-04-2011, 12:53 AM
  #76
hemlock
Default flap mod
Originally Posted by hemlock View Post
Please - anybody have any good flap mods? I cannot get the one "The Bandit" posted. can't get the inboard flap to move the mid flap...
Here is The Bandits post http://www.wattflyer.com/forums/show...+corsair+flaps
hemlock is offline
Old 11-05-2011, 04:44 AM
  #77
dawhale
Default E-flite 60 Motor Mount
I am going to install an E-flite 60 in my Hangar 9 Corsair. It looks like I need to mount 1 1/2" off the firewall. I am having trouble trying to find one that will adjust this close. What motor mount did you guys use?
dawhale is offline
Old 11-05-2011, 06:24 AM
  #78
UGLYPUG
Default Motor mounts
I made mine. I used 4 threaded rods the length needed for the distance off the firewall, sized to fit through the motor mount, and some blind nuts on the fire wall, and the rods fit through the motor mount, and some spacers on the rods and nuts as needed. I made a stand off motor mount like this for all my planes. Quick and easy to pick up all the parts at Ace Hardware.
UGLYPUG is offline
Old 11-05-2011, 12:37 PM
  #79
CorsairJock
CorsairJock's Avatar
Likewise: I fabricated mine from plywood, basically added an extension to the firewall.
Hobby Lobby used to sell (maybe they still do?) a pretty good motor mount for motors this size, I am using one in my Top Flite Mustang. I think it's called something like AM500? I'll try to find it and post a link.
CorsairJock is offline
Old 11-05-2011, 01:09 PM
  #80
CorsairJock
Here's the one I used on my Mustang:
http://www.hobby-lobby.com/aluminum_..._1365_prd1.htm
But as you suggest: it is probably TOO long. You could drill new holes in it (the part that mounts to the firwall) and shorten the 'legs'. I did that on my Me-108 come to think of it.
Old 11-05-2011, 07:07 PM
  #81
70sflyer
I thought the Hobby-lobby was not strong enough so for my AXi4130/20 so I went with the firewall style mount from R/C dude hobbies.It looks stronger and many holes for alot of different configerations.Good luck.Dean
70sflyer is offline
Old 11-05-2011, 07:11 PM
  #82
CorsairJock
That is exactly the same motor I am using on my Mustang, with the Hobby Lobby mount: no problems.
Old 11-05-2011, 08:47 PM
  #83
UGLYPUG
NOW you see why I make my own,, quick,, no waiting for an order, just pick up parts at ACE hardware or home depot etc,, cut to size very easily, and easy to adjust for thrust line. I just made one for a .10 size foamy mustang and did not need spacers, just extra nuts tightened against the fire wall and motor x-mount that comes with the motor,, easy to adjust the thrust line,, lots of good ideas on here from everyone
UGLYPUG is offline
Old 11-07-2011, 03:03 AM
  #84
dawhale
UGLYPUG, any chance you could post a picture of your home made motor mounts?
dawhale is offline
Old 11-07-2011, 06:08 AM
  #85
UGLYPUG
I'll try to add some pics,,, it keeps failing,,, files too big or something... I put a picture on this website,, check there,,,, You can also see where I have started using Velcro to hold the cowling on,, It holds very well, and you don't have to drill holes in the cowling, and it is easy to adjust to center on the motor in case you have to adjust the thrust line on the motor,, I left the mounting blocks from the old cowling that had holes in it, when I had a Saito 100 on this thing. BTW, anyone ever tried using 8 lipos on a power 60 ? I don't think it will handle 8 cells.
http://www.rcuniverse.com/forum/m_81...m.htm#10800316
UGLYPUG is offline
bert269
Scale E-Powered Aircraft
11-01-2010 10:51 PM
boomerace
ParkFlyers
9
06-14-2008 12:16 AM
Angler-Hi
Warbird Electrics
05-26-2008 01:25 PM
RSS Feed
RCU RSS Feed
10-22-2006 03:40 AM
Doppelganger
08-07-2006 12:39 AM
Quick Reply: Hangar 9 Corsair
Page generated in 0.09688 seconds with 12 queries
