Scorpion Motor Q&A - Show us your Scorpion!
Old 08-19-2008, 10:12 PM
  #176
everydayflyer
Southern Pride
everydayflyer's Avatar
just ordered a Scorpion 2208-34 and 25amp ESC I plan on putting in an Alfa Models P-47. I hope these scorpions live up to some of the hype I've been reading about
No hype ,just performance.
everydayflyer is offline
Old 08-22-2008, 06:19 AM
  #177
EpoweredRc
3D Flyer
EpoweredRc's Avatar
okay guess not one figured out what motor would be best.
EpoweredRc is offline
Old 08-23-2008, 02:53 PM
  #178
everydayflyer
Southern Pride
Guess not.
I had hoped that Randy would use my numbers in post
http://www.wattflyer.com/forums/show...&postcount=174
and find a Scorpion with as good or better effeciency.
Rimfire is in the 80% effeciency range according to the calc program I used and I know these numbers are better than any of my compariable(?) Scorpions based on past testing.
Would ask on the other site but what a mess .
Charles
Old 08-23-2008, 07:32 PM
  #179
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Default Electrostick Power
Guys - I still vote for the 3020-12 motor as a replacement for the Rimfire. The description of the Rimfire power system for the Electrostick says "up to 77% efficiency". The 3020-12 is about the same size and weight as the Rimfire and would provide a really wide range of performance with different sizes of props. If efficiency is a concern you could run an APC 10x5 prop which is 79.4% efficient on a 4-cell A123 pack. This still gives you 59oz of thrust which is a bit over a 1:1 power ratio. This only pulls a max of 31A according to Scorpion Calc. If you decided this wasn't enough power for your taste you could simply change the prop all the way up to a 12x6 for gobs more power at 88oz of thrust, 52.6A.
I've used the 3020-12 in a number of planes this size and always been happy with the results. It's one of the most popular motors in the 30mm series. I normally run them on a 3-cell lipo with a APC 12x6 prop which seems to be the best setup (77oz thrust @ 42A in bench tests).
Looks like the stock prop for the Rimfire is a 11x8.5 by the way.
Thoughts?
Ramovan is offline
Old 08-23-2008, 09:59 PM
  #180
everydayflyer
Southern Pride
Thanks Randy.
Everytime I run Scorpion calc I end up bouncing between 32020-12 and 3020-14 for 4S and 5S A123.'
To me the 3020-14 is the closest to the RimFire 4042-1000
RimFire 12X8 4S actual 7,700 / 38.5A / 418 watts
Scorp Calc 3020-14 12X8 4S 7,800 / 42 A / 430 watts
I have a 3020-12 on my EF Yak 54E which I rarely fly so I may just give it a go . I know I have measured 650 watts with a 4S A123 and a 13X6.5 on it.
Charles
Old 08-23-2008, 10:26 PM
  #181
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Originally Posted by everydayflyer View Post
Thanks Randy.
Charles
I think you're right about that. The 3020-12 is just a bit more Kv than the rimfire, and the 3020-14 is just a bit under the Kv of the Rimfire.
I was just looking at what I thought might power that plane well. Obviously the 3020-12 or 3020-14 is the closest match. Deciding on one or the other probably depends on what prop you'd want to run on the Electrostick.
Thanks for your input. You've got some good data and real-world experience with A123 cells which we all know Foamiesrfun LOVES.
Ramovan is offline
Old 08-24-2008, 03:42 PM
  #182
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Blame EDF for that lol, he started flying A123 before me ( only cause he had planes that would carry the weight) as soon as I got a plane that would I got them also, I love them. really made my 480 e flite come alive.
Thanks for all the data. Maybe I can talk edf into us trying his motor on my stick( just ordered it) to see how it works then if it works well I will buy one. I appreciate all the info you try to give us on these motors.
I would most likley just get a rimefire but there not avl. untill Oct. and i do like these scorpion motors.
Old 08-24-2008, 04:51 PM
  #183
Liquidity
Combat Vet
Liquidity's Avatar
Randy, here are some pics of my latest Scorpion powered model ..
E-Flite Deuces Wild 25e
2 3026-12 motors
2 Scorpion 70A
Ar7000
6 Ds821 servos
1 HS 422BB servo
1 Dimension Engineering VHVBEC
2 4s4000 lipos
2 13x6.5 counter rotating props
Robart pneumatic retracts
10lbs 2oz total weight
1652W (826W to each motor)
54.4A to each motor
I will give you a flight report later on as it has not been maidened yet
ID:	76311   Click image for larger version
Liquidity is offline
Old 08-24-2008, 06:32 PM
  #184
Manta1
No Shoes is MY FRen
Manta1's Avatar
dats one purty plane rite thar
Manta1 is offline
Old 08-24-2008, 07:49 PM
  #185
EpoweredRc
3D Flyer
EpoweredRc's Avatar
2 3026-12 motors
2 Scorpion 70A
Ar7000
6 Ds821 servos
1 HS 422BB servo
2 4s4000 lipos
54.4A to each motor
Nice plane, Get us a video if you can, and diff let us know how it flys I thought about that plane its a beautiful plane but man I added up what it cost and figured I could own two normal planes for price of that one.
But you do have a great feild to fly it off of.
Old 08-24-2008, 08:16 PM
  #186
Liquidity
Combat Vet
Liquidity's Avatar
I am trying to hold out until the electric Fly in at Hodges to maiden it. We will see, I am getting very antsy and want to fly it now.
Old 08-24-2008, 09:12 PM
  #187
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Liquidity,
That plane is so cool. I'm glad to see you completed that airplane as I was quite interested in how it would turn out. Let us know how it flies when you've done the maiden.
That would make a great addition to the Scorpion powered models webpage.... mind if I add it?
Ramovan is offline
Old 08-24-2008, 11:15 PM
  #188
Liquidity
Combat Vet
Liquidity's Avatar
I will let you allknow how it flys.
Feel free to add it to the page.
Old 08-29-2008, 11:27 PM
  #189
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Well here is my ny A123 & Scorpion powered plane Stick info
GP ElectroStick
Scorpion S-3014-16 motor
Suppo 70Amp esc with Dimension engineering bec
2 Futaba S3004 full size/standard servos for tail
2 Hitec HS-82MG's for ailerons.
AR7000 rx with DX7 Radio
11x8.5 Prop Flown maiden flight ( still might play with props)
Tested on the ground
46amps- 480 watts 8,000 Rpms
Flown with 4 cell A123 2300mah
Plane w/o batterys is 47.5 ounces.
Flying weight 58.5 ounces.
Flys great, Look for more info the Electrostick thread.
Plane flys great, about 20 foot run on tall uncut grass and list off, plenty of speed when comes off ground and once it builts up more its fast arounds 60mph or so. will do loops over and over at half stick, flying it 5 minutes to buzzer then a nice landing approch and landing, arounf 2,000 back into the 2300mah batterys.
nice plane great planes done a good job with this one.
ID:	76710   Click image for larger version
Name:	mine and dads.jpg
ID:	76711   Click image for larger version
ID:	76712   Click image for larger version
ID:	76713   Click image for larger version
Old 08-30-2008, 09:12 AM
  #190
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Chris,
Awesome twins you have there! They remind me of my E-flight Mini Ultra Stick. Great all-around sport planes with no bad habits, easy to handle, and wide performance envelope. It's been one of my most-flown planes this past couple years.
Can I add it?
Ramovan is offline
Old 08-30-2008, 01:06 PM
  #191
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Chris,
Can I add it?
I posted the same but a lil driffrent three driffrent locations so got confused one of those is mine the other is everydayflyers. they do look nice together, yes You may post it on the site, EDF's info should be in the stick thread on this site.
I am just glad to know of a scorpion set up that will work with this plane.
Old 08-30-2008, 08:27 PM
  #192
Liquidity
Combat Vet
Liquidity's Avatar
WOW. I flew the Deuces Wild today. Excellent flyer and a lot of fun. Once I got calmed down, I had a blast with it. Scorpions are the way to go with it.
Just reenforce the firewalls!!!
Old 08-30-2008, 10:30 PM
  #193
everydayflyer
Southern Pride
My Electro Stik has a Rimfire on it however I have another one that I am going to assemble and it will have a Scorpion on it.
Charles
Old 08-31-2008, 09:07 PM
  #194
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Thats great, so where is the video? how much run way did you need to get it up and how much did it take to get back on the ground?
Old 08-31-2008, 09:13 PM
  #195
Liquidity
Combat Vet
Liquidity's Avatar
I took a nice long roll out slowly increasing power. I did not want the firewall to bust out. See my build thread for more information. My landing was really fast, but for te first flight I would rather be too fast than to slow.
The video is coming uploading to Youtube as we speak and will be posted in the build thread.
Old 08-31-2008, 10:05 PM
  #196
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Default Scorpion page update
Foamiersrfun/Liquidity,
I've added your planes to the Scorpion powered models webpage which helped me complete the page. You can check them out at the bottom of page 3. Let me know if I made any mistakes. Notice the touch up on both your photos - Chris actually disappeared from his so no one is holding the plane anymore.
Thanks guys! We're sure getting a lot of planes from Georgia on there! On to page 4. Thats 60 models now. I'd like to get up to 100 by the end of the year so keep them coming.
Ramovan is offline
Old 08-31-2008, 11:28 PM
  #197
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Thats great for you, I hope you seen my updates on mine from today.
I had to get a AR700 in it I just love my dx to much not to use it.
Well just call GA the Scorpion state Maybe I can add my 60 size Koas to the list over the winter.
Old 08-31-2008, 11:37 PM
  #198
Liquidity
Combat Vet
Liquidity's Avatar
Awesome. I have a couple more models you can add to the site if you would like. A mini Telemaster and a Telemaster Electra. I will get you some pics and info tomorrow.
I am too lazy now to take that big Telemaster down.
I would have a Scorpion powered Micro Telemaster also, but Scorpion does not make anything that small.
Old 09-01-2008, 02:45 AM
  #199
EpoweredRc
3D Flyer
EpoweredRc's Avatar
wow is it really that small? we talking a inside flyer? I thought the 20 series are pretty small.
Old 09-01-2008, 02:50 AM
  #200
Liquidity
Combat Vet
Liquidity's Avatar
I run the micro on a Park 250, which is way more motor than it needs
Quick Reply: Scorpion Motor Q&A - Show us your Scorpion!
Page generated in 0.12184 seconds with 20 queries
