Scorpion Motor Q&A - Show us your Scorpion!
Old 01-19-2008, 01:49 PM
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Originally Posted by Foamiesrfun View Post
just now reading this I have a Katana 46" wing span right over 5 pounds with a Scorpion 3026-12 using a 13 inch prop and running A123 2300 5 and 6 cell batterys, the thust is great on it, plenty of power these motors are great, however with 2300MAH only a 4 1/2 min flight so I have since taken it off and the motor will go on something else.
but I really love the motors, my father owns 3 and i am about to get another one, and put on a Mini showtime.
Originally Posted by cloud-9
How many A123 cells you have in that setup?
Jim
Had 5 cells then went to 6 cells trying get more flight time, but it didn't help. Plane flew great but with 2300MAH thats all A123 offer right now, just short flights.
EpoweredRc is offline
Old 01-19-2008, 11:12 PM
Hogger
Here is my TMPro Yak-54.
Scorpion 3014-18
Scorpion 45A ESC
4 HS-81's
2250mah 11.1v li-po
46" wingspan
40 oz.
Hogger is offline
Old 01-20-2008, 05:29 AM
cloud-9
cloud-9's Avatar
Thanks, missed that in the text of your post. Have you tried running A123s in both series and parallel, or are they just too heavy?
Jim
cloud-9 is offline
Old 01-20-2008, 12:26 PM
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Jim
The 6 cell pack was autally two 3 cell packs that I hooked in Parallel to fly, thats the only way I could charge it, cause not having a charger i zip charged them.
they are heavy, as in to heavy to have two 5 cell packs. 3-5 cell themselves are not bad. over 5 cell getting a lil heavy.
Old 01-20-2008, 06:42 PM
Liquidity
Combat Vet
Liquidity's Avatar
I just completed another Scorpion power plane. This is the Slow Stick X Night Sticky Rip-off plane.
She is powered with a Scorpion 2215-22 motor, a Scorpion 25A esc, ar6100 rx, 4 HS-55 servos, 3s1320 TP lipo and a APC 10x7 SF prop.
Data is 14.8 A static, 145W, and she weighs a hefty 22.3oz, but carries 20 8,000 mcd LEDs
I will get some better pics tomorrow at the field during the maidening.
ID:	52766   Click image for larger version
ID:	52767   Click image for larger version
Liquidity is offline
Old 01-21-2008, 03:52 AM
Liquidity
Combat Vet
Liquidity's Avatar
Better pics plus some night shots.
ID:	52856   Click image for larger version
ID:	52857   Click image for larger version
ID:	52858   Click image for larger version
ID:	52859   Click image for larger version
Old 01-21-2008, 04:28 AM
CygnusX1
CygnusX1's Avatar
3008-32 going into a 2.5M ASW-28
CygnusX1 is offline
Old 01-21-2008, 04:33 AM
EpoweredRc
3D Flyer
EpoweredRc's Avatar
That looks really neat there. Did you home make the lights or buy them like that? Thats really cool, I have wanted to do something like that to my profile plane. Well I autally do have the wire of the lights inside the wings and got the lcd to the tip of each wing, but inside like that looks really good.
where did you get the stick mount for that motor? does the 22 series line up with the e flight 480?
I was thinking about that motor for my profile edge 540 it is right at 21ounce with 1100 a123's
Old 01-21-2008, 04:35 AM
Liquidity
Combat Vet
Liquidity's Avatar
I custom made the LEDs. It is not too hard. I have 2 other LED planes that look like UFOs. It is just tedious (sp?). I had to solder resistors on to each LED, then solder the leds onto very thin magnetic wire. It really is not hard, it just takes some time.
Old 01-21-2008, 11:34 AM
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Liquidity,
That lighted wing is just awesome - Great job! That really makes me want to build something like that. I'd like to try it with a programable light controller so I could animate the lights a bit.
Hogger,
Those Yak-54's are sweet. Can I use your planes on my Scorpion powered models web page?
Ramovan is offline
Old 01-21-2008, 05:34 PM
Hogger
Sure, let me know if you need more info. Thanks.
Jordan
Hogger is offline
Old 01-21-2008, 05:55 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Tell me everything there is to know about the Scorpion HK2221-6...
Someone is sending me one for bench testing, and I know nothing about it. :o
My customer is looking for something which will produce a lot of SPEED, but very little thrust... Is this motor suited for this purpose?
Old 01-21-2008, 07:22 PM
  #63
Hogger
Here is a start for you.
rcdude.com HK2221-6
From a little googling, it looks like more of a heli motor, than a plane motor.
Hogger is offline
Old 01-21-2008, 07:46 PM
  #64
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Default HK-2221-6 Motor
The Scorpion HK-2221-6 motor is a high Kv outrunner made for helicopters and planes with small props. It's a drop-in replacement for helicopters like the T-Rex 450 and provides much more power than the Align stock motor. These motors comes in 6, 8, 10, and 12 turns. The 8 turn is the most popular T-Rex upgrade, while the 6 turn is for balistic power. The 10 and 12 turn are designed for those that want to run a 4-cell pack.
These motors are blowing away $150 motors in helicopter drag race competitions!
You will want to run the HK-2221-6 on a 3-cell lipo and use an ESC rated at 55A or better (pulls 52 amps max). If you're going to use this in an airplane application the best thing to do is download the Scorpion Calc software so you can play with some numbers and determine the best prop for your application. Here's a link to the download....
http://innov8tivedesigns.com/Scorpio...c_Imp_v236.zip
Ramovan is offline
Old 01-21-2008, 08:46 PM
  #65
Lieutenant Loughead
UNCLUB OWNER
LOL -- yeah, I've played with the software, but I've learned not to trust software -- it's vastly different from TRUE bench testing.
My customer wants something that goes FAST... I guess he's going to get it.
52 amps!
Old 01-22-2008, 01:02 AM
  #66
Liquidity
Combat Vet
Liquidity's Avatar
Interesting motor. I am currently hitting 127-131 with dons inexpensive motors. I might want to give this one a shot, however 44000rpm is massive.
Old 01-23-2008, 12:58 AM
  #67
everydayflyer
Southern Pride
everydayflyer's Avatar
Scorpion calc is a different animal. I have 4 Scorpions and the 3 I have bench tested and flown with a logger have all matched SC very closely.
Charles
everydayflyer is offline
Old 01-23-2008, 01:39 AM
  #68
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Default Scorpion Calc Software
Charles
I agree. When bench tests are performed on the Scorpion motors the results are compared with the Scorpion Calc results and then the software is updated if needed. This keeps the software realistic.
Scorpion doesn't want inflated numbers as that would just result in unhappy customers when the motors didn't perform as stated.
Ramovan is offline
Old 01-23-2008, 03:15 PM
  #69
Lieutenant Loughead
UNCLUB OWNER
Well, maybe it works well with Scorpion motors, but when I put in two "custom" motors (a Himax and a Mega), the numbers were pretty far off! :o
In short, I simply do not trust software which "predicts" power system results.
Old 01-23-2008, 07:46 PM
  #70
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Default Props charts
The Scorpion Calc software is "fine tuned" for Scorpion motors so I'm not surprised that a custom motor is not very accurrate. Fortunately, Scorpion motors are bench tested and props charts are produced that are very accurrate. These prop charts are conservative and realistic so you really do experience the performance shown. To me, this is the best feature of the Scorpion motors. I like to see the THRUST produced by the motor instead of just WATTS and Kv.
So you can "not trust" software and still easy determine the right motor for your model.
Ramovan is offline
Old 01-24-2008, 03:05 AM
  #71
Liquidity
Combat Vet
Liquidity's Avatar
Randy, Do you know when you will be getting more Thunder Power 12V power supplies in?
Old 01-24-2008, 07:47 PM
  #72
EpoweredRc
3D Flyer
EpoweredRc's Avatar
Oh alright, well did you not see my other question or...
hey Ramovan I PM you but not heard back, guess you been busy.
Old 01-24-2008, 08:04 PM
  #73
CygnusX1
CygnusX1's Avatar
Slightly off topic but here is what I use on my EGE for lighting.
http://www.directron.com/caraccessories.html
Powered off of the 8-cell NiMh directly and very light and bright.
CygnusX1 is offline
Old 01-24-2008, 08:55 PM
  #74
Liquidity
Combat Vet
Liquidity's Avatar
Sorry Chris, I overlooked it. Yes, the Eflite mount works perfect with the Scorpion motor. Hodges did not have any Scorpion stick mounts in, so I checked if it woudl fit the EFlite perfectly, and it did.
Old 01-24-2008, 09:09 PM
  #75
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Default Scorpion 22mm Stick Mount
Scorpion does have a stick mount that fits the 22mm series of motors. They are $1.95
http://www.rcdude.com/servlet/the-25...er-22mm/Detail
Ramovan is offline
Quick Reply: Scorpion Motor Q&A - Show us your Scorpion!
Page generated in 0.17575 seconds with 21 queries
