Pink Pusher Jet Build
Old 09-11-2007, 07:15 AM
Hi Everyone Well as you can see, I went from a Red Head to a Medium Blond with Highlights,and shorter, its just much cooler in this triple digit weather we have been having lately, they say, Blonds have more fun, But I really think RCrs have more fun And Who says Blonds are Bimbos, Ok Ok Britney , Take care, Chellie
Old 09-11-2007, 07:37 AM
max2112
max2112's Avatar
Default Who is that lady?!?
Looks Great, Chellie! Your avatar looks like you're getting ready to go out and paint the town red!
As to the pusher build I can't wait until I'm able to begin a build project like this. We have to move every three years and for now I am stuck with medium to small park flyers and no bench space to build or experiment on.
Anywho, Thanks for the great thread.
John
max2112 is offline
Old 09-11-2007, 07:46 AM
John
Thank you John Your Sweet A folding table / card table works great, with a piece of partical board on top of it to cut on, That way, Your better Half wont get mad at you using the dinning room table Take care, Chellie
Old 09-11-2007, 11:10 PM
DavidWent
Holdmybeer and watchthis
DavidWent's Avatar
Hi Chellie
All I can say is...HUBBA-HUBBA!
David
DavidWent is offline
Old 09-12-2007, 12:08 AM
oimmuk
Monkey Minion
oimmuk's Avatar
Originally Posted by DavidWent View Post
Hi Chellie
David
You said a mouth ful Brother...UUUUUUU HUUUUUUUH!!!
oimmuk is offline
Old 09-12-2007, 03:47 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Love the new look Chellie!
gotta try one of these as soon as I get back in town! even have a full bundle of FFF waiting for me!
xuzme720 is offline
Old 09-12-2007, 04:05 AM
oimmuk
Monkey Minion
oimmuk's Avatar
What the plane or the Blond hair with highlights?
oimmuk is offline
Old 09-12-2007, 04:07 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
love the new hair color...going to try the jet build...
imagine me with a pink jet and blonde highlights!
xuzme720 is offline
Old 09-12-2007, 04:08 AM
oimmuk
Monkey Minion
oimmuk's Avatar
Hmm a Pink jet with blonde highlights, please post pics
oimmuk is offline
Old 09-12-2007, 04:14 AM
Thank you Guys Your all Sweet, Well Thats a confidence builder Will be taking the pusher jet out for a maiden Friday or Saturday, hope to get some good video of it flying, Take care, Chellie
Old 09-12-2007, 04:19 AM
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
Hi Chellie the new hair looks great. ........I think you have driven the guys loony toons with it.
Looking forward to the flight report.
Biplane Murphy is offline
Old 09-12-2007, 04:25 AM
oimmuk
Monkey Minion
oimmuk's Avatar
oimmuk is offline
Old 09-24-2007, 02:33 AM
  #63
smokejohnson
smokejohnson's Avatar
Well Chellie that was a bummer reading about your maiden. Get that Hitec receiver in there and give it another try. I'm sure it will be great flier, after all you built it .
smokejohnson is offline
Old 09-24-2007, 02:54 AM
  #64
oimmuk
Monkey Minion
oimmuk's Avatar
Whahappen?
oimmuk is offline
Old 09-24-2007, 03:16 AM
  #65
Hi James Hi Oimmuk I put a new nose on it put in the hitec receiver, took that junk corona receiver out, installed a 6x5 prop, added a little nose weight and flew it again, It flew PERFECT and SWEET , then I took off the 6x5 prop and put on a 6x6 prop, for more speed, big mistake, my 25 amp ESC shut off during take off, and in it went again, not to bad, but needs a nose Job again :p I am getting good at doing noses OK, so what did I learn today, stay with tried and true electrical hardware, I normally use a 30 amp ESC, but this 25amp esc came with a 2409-12 TP outrunner that I got from united hobbies, and it should have been good enough for a 2408-21, but I guess not, What else did I learn today, I need to quit being Soooo Cheap and invest in a watt/ amp meter anyway, this pusher Jet was my R&D tester, and I got all the bugs out of it now, I know where the best CG is at now, what esc to use, 30 amp, stay away from junk corona receivers, and get a Wattmeter see I learn fast anyway I had a good day today, and I made some bigger tail feathers for my DR1, so I will be testing that out soon, and my F111 is going to be flying soon too, Take Care Everyone, Chellie
Old 09-24-2007, 04:09 AM
  #66
smokejohnson
Glad to hear you got it worked out Chellie.
Old 09-24-2007, 04:51 AM
  #67
Hi Everyone Well i got the bugs worked out of this pusher jets powerplant , electronics and CG it flys SWEET, with fast Barrel Rolls, I will post some video soon and give the CG point after i get the new nose on it I Did a lot of R&D on it today , take care, Chellie
Here is what seems to work the best,
1. a 2408-21 1600kv TowerPro outrunner or a very good quality motor
2. 30 amp ESC, or bigger
3. 6x5 or 6x6 prop A 7x6 cut down to a 6x6 or your preferance
4. 1200 to 1350mah 3 cell lipo 15c rated
5. Hitec or a very good quality receiver
6. 9 gram Towerpro servos or HS65 hitec servos are great too, HS55
might be a little lite for the big ailerons.
7. The CG is 13 1/4" from the nose of the plane back, attach a 4" piece of string to a small screw, at the top of the fuselage, at the CG screw in the string and screw, lift plane with the
string and Check your CG, also check wing tip to wing tip balance, wings should be level, if
not, add a washer to the wing tip that is up, on the bottom with epoxy
Old 09-24-2007, 05:11 AM
  #68
catapultone
Hi Chellie, Thanks for the plans! Now how about plans for that fold up table for us fellows that live in the Desert (AZ) Catapultone
catapultone is offline
Old 09-24-2007, 05:22 AM
  #69
Sure no problem, I need to put away a lot of the clutter that is on it, so i can fold it up will get back to you soon with some pics and a plan of the fold up hobby bench , take care, Chellie
Old 09-24-2007, 01:13 PM
  #70
pd1
Still Learning
pd1's Avatar
Hi Chellie,
Sorry to read about the problems.
Glad you've got then sorted out.
Like the new avatar much better than the copter.
Paul
pd1 is offline
Old 09-24-2007, 11:55 PM
  #71
Spencer J
ELECTRIC > GAS
Spencer J's Avatar
Chellie's avatar is creepy lol sweet plane btw, good color choice. If you go to Michaels or some other craft store, they sell clear sheets of 8x10 with a sticky side...great for printing designs on and slapping them on your plane. The next time I put togeather an open-structure balsa plane, I will try using it as a covering alternative
Spencer J is offline
Old 09-25-2007, 12:51 AM
  #72
gfdengine204
gfdengine204's Avatar
Looking mighty fine, Chellie. Oh if I was single again.......<sigh>
gfdengine204 is offline
Old 09-25-2007, 12:52 AM
  #73
Biplane Murphy
Yep... I like the new Avatar.... much prettier than the old Heli one.
Old 09-25-2007, 02:37 AM
  #74
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Yea.....What they said.....oh thats right, I am single again
rea59 is offline
Old 09-25-2007, 02:41 AM
  #75
oimmuk
Monkey Minion
oimmuk's Avatar
Watch out Chel, there guys who are saying "Again" I would wonder about...
oimmuk is offline
Quick Reply: Pink Pusher Jet Build
Page generated in 0.12456 seconds with 11 queries
