Pink Pusher Jet Build
Old 07-19-2012, 09:54 PM
  #226
PinkYak RC,
Lots of places and lots of threads.
What do you want to build? I've built F-22's, an F-15, F4J Phantom II, SU-27, Convair Sea Dart. Plans are all over the place on RCG and RC Universe. Check out Bob's thread here on Wattflyers: http://www.wattflyer.com/forums/showthread.php?t=67264
Several plans are on media fire: http://www.mediafire.com/?9aut8jp61e...yqmvk13sx3nqmc
Also Check out www.Mikeysrc.com and www.6mmflyrc.com. You can run a search on RCG and it's likey a build log with plans will come up. Also:
http://flitetest.com/articles/delta_wing
I love the smell of epoxy in the morning !
-Hawk
Old 03-19-2014, 05:18 PM
  #227
dustint209
Reviving an old thread here. I built mine with dollar tree foam. I made a cockpit by cutting 4 more nose peaces and then added the top peaces. Didn't realize after putting it all together that I made the tail 10" too long lol. Oh well, it flies great. I have a 2826 NTM prop drive 1350kv with a 7x5 prop. The video is my maiden with a 1300 3 cell. I'm going to try the 4 cell today. Also have a 3 axis gyro in it. It's a bit heavy at 590 grams! lol. I may order a higher kv motor soon. Sorry the video is so short. More to come!
http://youtu.be/i1ViHpx_icw
dustint209 is offline
Old 03-20-2014, 12:13 AM
  #228
riverrat
circa: 1946
riverrat's Avatar
Looking great!
Regards
Jimmy
riverrat is offline
Old 03-20-2014, 05:13 AM
  #229
That looks great and flys good too try a 7x6 prop, take care and have fun, Chellie
Old 08-29-2015, 08:15 PM
  #230
Jack_K
Jack_K's Avatar
What is that motor mount on the Alley Cat and where do I get one?
Jack
Jack_K is offline
Old 08-30-2015, 10:19 AM
  #231
Jack
It Depends on what motor you have, you can use a stick mount, or a flat base motor mount depending on the motor your using, also the plane can be made to accept any motor mount or motor you want with in reason,
http://www.headsuphobby.com/Firewall-Mounts_c148.htm
http://www.headsuphobby.com/Mounting-Sticks_c260.htm
http://www.headsuphobby.com/Stick-Mounts_c259.htm
http://www.wattflyer.com/forums/showthread.php?t=39483
Old 08-30-2015, 05:37 PM
  #232
Jack_K
Jack_K's Avatar
Thanks Chellie. With your previously given permission, here's the PDF file of plans for your Alley Cat. I scaled them to 22x33 since that's the largest format that my Microsoft Visio knows about. Everything except one of the two booms fit on that size.
It's scaled to fit on a sheet of DTF. If Visio would permit a larger format I could scale it to fit a sheet of Depron.
To print the plans, open the file with Adobe Reader and select Print. Then select your printer and click on the "Poster" block. Once Poster opens click the "Tile only Large Pages" and make sure the box is checked. Then click on "Print". Tape the sheets together.
Of course, you could always get the full size plans printed at Staples, etc.
Jack
File Type: pdf
Jack_K is offline
Old 09-12-2015, 04:10 PM
  #233
Jack_K
Jack_K's Avatar
I finished mine and have installed everything except the battery. I moved everything pretty far forward, but it's so tail heavy that I can't move the battery far enough forward to balance it.
I set the CG at 13-1/4" from the nose or 6-3/8" from the rear end of the canopy (19-5/8 - 13-1/4 = 6-3/8"). So, what have I done wrong?
BTW, I used doubled DT foam with all paper removed for everything except the stab and elevator. They're 6mm Depron.
Jack
Update:
I used several of the online CG calculators and they all say 8" to 8-1/4" back from the LE of the wing. That would put the CG no where near 13-1/4" back.
What's correct?
ID:	181707   Click image for larger version
Jack_K is offline
Old 01-06-2016, 11:40 PM
  #234
Jack_K
Jack_K's Avatar
Here's a good place to buy foam.
http://www.rcfoam.com
Jack
Jack_K is offline
Electric Ducted Fan Jets
75
09-04-2018 02:35 PM
Theycallmecrash
10-08-2012 10:53 PM
michael7810
06-01-2008 04:54 PM
harrymc
Foamies
10
02-22-2006 02:44 AM
patrnflyr
01-15-2006 12:09 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Quick Reply: Pink Pusher Jet Build
Page generated in 0.10381 seconds with 15 queries
