Parkzone Micro Cessna 210
Old 06-16-2010, 01:16 PM
  #201
Nunja Business
Originally Posted by philipa_240sx View Post
No, they are not Spektrum compatible so you cannot 'bind' them.
The Micro Cessna Centurion 210 and Micro Citabria use a different and proprietary 2.4Ghz radio.
If you want to make your Cessna 210 into a Spektrum compatible, you will need to replace the RX brick in the plane. There is an article on Horizon Hobby's website explaining the conversion process:
http://www.horizonhobby.com/Articles...ArticleID=1931
Thank you! Apparently, the ESC has to be replaced too. Guess I will hold off.
Nunja Business is offline
Old 06-16-2010, 05:00 PM
  #202
philipa_240sx
Not really. The new Spektrum brick contains an ESC as well as the servo's. It is the only component you have to replace. However, at $59.99 it's not cheap:
http://www.horizonhobby.com/Products...ProdID=PKZ3351
A brand new PZ UM J-3 Cub and the HobbyZone Champ can be had for only a few dollars more.
I would keep a lookout for a used Spektrum brick from one of the following planes:
- Vapor
- Ember 2
- UM J-3 Cub
- UM Sukhoi
- UM P-51
- HZ Champ
- Or a Spektrum AR6400 RX
The only difference between all of these bricks is the Vapor/Ember/Champ/J-3 Cub are dumbed down versions without the extra aileron channels and X-port. But for a 3ch plane like the Citabria, you don't need these options.
philipa_240sx is offline
Old 06-17-2010, 02:37 AM
  #203
Nunja Business
- Vapor
- Ember 2
- UM J-3 Cub
- UM Sukhoi
- UM P-51
- HZ Champ
I may just be golden then. I just happen to have a brand-dang-new AR500 laying here on my desk.
So, it is a fairly simple swap? The 210 has been opened before so I am not too apprehensive about tackling it.
(By the way, I have a Champ - LOVE.IT!)
Old 06-17-2010, 02:44 AM
  #204
philipa_240sx
Um, no. The AR500 is just a receiver. It won't work. By the time you add the ESC , and servo's... the plane won't fly then... it will be far to heavy.
You need the AR6400 brick found in the planes I mentioned above... it is a complete RX plus 2 linear servo's and ESC on board.
AR6400:
And this is what the existing brick in the Cessna 210 looks like... you have to replace this with the AR6400 above which is DSM2 (Spektrum) compatible.
Old 06-17-2010, 01:30 PM
  #205
Nunja Business
Thanks Philipa. Bummer. Guess I'll just watch for a deal on the brick.
Old 10-01-2016, 05:24 PM
  #206
skylane42
I see some different size batteries, 160 mah etc. What is the largest and brand battery you guys have used in the 210?
skylane42 is offline
Old 11-29-2016, 11:15 AM
  #207
Virgil Kee
Default Largest Batt. for the Micro Cessna
The 180 mAh is probably the largest batt. possible. The 200's and up are too big physically, and possibly too heavy.
Virg.
Virgil Kee is offline
ralph99
07-03-2008 08:26 PM
dotdigital
03-08-2008 03:47 PM
gfdengine204
43
03-02-2008 04:05 AM
herk_1
41
10-21-2007 12:49 AM
goldberg
09-19-2007 04:38 AM
Quick Reply: Parkzone Micro Cessna 210
Page generated in 0.08011 seconds with 11 queries
