Mini Telemaster Build thread
Old 10-25-2007, 02:51 AM
  #101
Craig
I am nearly finished with framing up my Telemaster. It has been a pretty simple build other than I have not had a whole lot of time to spend on it. I am remodeling my basement so that has taken up a lot of my modeling time. I have stuck to the plans except for the wing. I am adding ailerons to the plane. The only thing I am debating on now is whether to do 2 servos in the wing or a single centered servo. I can see advantages to each.
Next up is choosing a color scheme. I want to go a bit different with this one. I will post some pictures soon of my plane.
I decided to order a new motor for it as well.
I went with the this one.
KA20-20L
Dimentions: 28x32mm
Rating: 1050kv
Battery Config: 3 Lipo Cells
Shaft: 3.175mm
Weight: 56gr
Operating Current: 6-15A
Max Current: 19A
Prop: 9x6
Craig is offline
Old 10-25-2007, 06:43 PM
  #102
mudduck
Hello Craig,
I also have a Mini Telemaster Kit but have not yet started building; I will get it going sometime next month or even December.
I'm looking at your motor and wondering where you pruchased it. I haven't heard of a KA20-20L. Is it compatable with an AXI or Atlas or the ones that Tower Hobbies offer?
Regards,
Ron
mudduck is offline
Old 10-26-2007, 01:51 AM
  #103
Craig
I am getting it here- http://www.planeinsanerc.com/motors.html
You can also get it here: http://donsrc.com/cart/index.php?act...d&productId=40
In fact a lot of places carry the motor. I have no clue how it compares to AXI motors though.
Craig is offline
Old 10-29-2007, 05:11 PM
  #104
mudduck
Craig, Thanks for the addresses. It looks like a good choice for the Mini Tee. I'm presently working on a Miss Stik Jr. from Hobby-Lobby. I'm at the point ready to cover. It runs on a 300 brushed motor with a finished weight of around 12 Oz's. I haven't built a stick plane in quite a while. I don't build fast but it is a fun project.
Ron
mudduck is offline
Old 04-23-2008, 04:12 PM
  #105
w5kfg
Bill B
w5kfg is offline
Old 05-18-2008, 01:08 AM
  #106
w5kfg
The instructions say to cut 14pc 1/8x1/4 forward braces using the bottom lg block as a guage, The side view plans don't show 14 side braces. Am i missing something here
Bill
w5kfg is offline
Old 05-18-2008, 01:26 AM
  #107
velojet
velojet's Avatar
Default Cross brace positions
Bill
No, their position is not as clear on the plans as it could be. It's actually forward of the top edge of the sheet sidewalls, so as to maintain a constant fuselage width from the nose to the end of the sidewalls.
I made a scan of the plan where I've numbered the 14 positions. You can see my annotated scan plus a photo from my build showing the braces in their places in this posting on RC Groups.
John
velojet is offline
Old 01-01-2009, 12:04 AM
  #108
Izaak
Izaak
Default Finisthed my Mini Telemaster
Hi: Well due to the snow falling almost every day of December, I have been inside my hobby room building my first KIT model, the Mini Telemaster. I have built 3 ARF Senior Telemaster 8ft. Wing span and ONE 12ft. ARF Telemaster. I use the 12ft. Wing span TM for training and taking Videos for the Forest Service. The Telemaster is without a doubt one of the most stable and consistent RC model planes I have ever flown.
If you are a first time builder of the Mini Telemaster might I suggest you go to Hobby Lobby and download the instruction manual for the " ARF Mini Telemaster"? The instructions that come with the Mini Kit are very lacking in photos but the ARF version will give you a lot of photos and insight into what the poor mini plans lack. I would not have been able to complete the kit without reading and seeing photos of the Mini on this forum. A million thanks to all that have contributed there impute to the Mini Telemaster build forum.
Thank You
Izzak
Name:	P1030942 (Small).JPG
ID:	88622   Click image for larger version
Name:	P1030945 (Small).JPG
ID:	88623   Click image for larger version
Name:	P1030950 (Small).JPG
ID:	88624   Click image for larger version
Name:	P1030953 (Small).JPG
ID:	88625   Click image for larger version
Name:	P1030955 (Small).JPG
Izaak is offline
Old 01-01-2009, 11:54 PM
  #109
Issak - it looks great! Nothing flies like a Telemaster....
Old 01-02-2009, 12:20 AM
  #110
velojet
velojet's Avatar
Default Size matters
Originally Posted by Izaak View Post
... Mini next to 8ft. Could not get my 12ft. Wingspan Telemaster in next to these two.
As a park flyer, my Mini Telemaster has always seemed reasonably large to me. Now I understand why it's called 'Mini'.
velojet is offline
Old 01-13-2010, 07:36 AM
  #111
182 STOL Driver
Default Mini Telemaster builld
I'm building a mini Telemaster and enjoyed the write up I see so far.I've
followed most of the plans and looked at some of the details in your pictures. After 50 years of gas models I decided to try electric. I bought a park flyer 2.4 Ghz (Spektrum 7DX) radio ,whitch I know is overkill.
Haven't built a R/C airplane in 10-15 years. Haven't flown R/C in last 3-4
years >>> but do have a 1956 Cessna 182 that I fly all over the southwest U.S. when funds are available. I need a small electric plane to take with me in my 182 on those dirt strips I go to to relax. I'm adding
ailerons and using a speed 400 motor with Lipo 7.4 V and 1500 ma.
battery under belly. Is Monoacoat too heavy for covering ? Don't want to bend wing. Thanks
Bill
182 STOL Driver is offline
Old 01-13-2010, 03:58 PM
  #112
Great to see you enjoyning the build!
I would use the lighter coverings for sure. Monokote is a bit heavy for this application.
Old 01-13-2010, 05:08 PM
  #113
182 STOL Driver
Default Covering ?
What would you use ? How about silkspan like I used to use on old gillow
rubber models ? I'd prefer a iron on with light red or yellow or green.
Bill
Old 01-13-2010, 06:45 PM
  #114
buzzbomber
Matt Smith
buzzbomber's Avatar
Ultracote lite, Solarfilm Lite, Aerofilm Lite, or any other "lite" iron on film will work. Regular Ultracote(like monokote) will bend the wing when shrunk, speaking from experience.
buzzbomber is offline
Old 01-13-2010, 07:04 PM
  #115
Yep I like the Nelson Solite. Also sold as Coverite Microlite.
http://www3.towerhobbies.com/cgi-bin...?&I=LXGDV9&P=7
Matt points out some other good ones.
Old 01-14-2010, 05:56 PM
  #116
182 STOL Driver
Default Camera in electric aircraft ?
I've been seeing a lot of videos on U tube with mini-telemaster etc. I've got a cell phone (Mortorla Razor ) that's no longer usable as a cell phone but camera works good-both still and video ---hmmmm.
Nice light weight that can be downloaded to my computer .Any body else using old cell phone camera ? Ive got extra channels and servos to operate ?
Old 02-09-2010, 07:58 PM
  #117
Brian76239
Default Definitely a Nice Airplane
I built mine last year. I added strip ailerons and mounted the wing using
4-40 nylon bolts. I also added some additional area to the vertical fin and
the rudder. Power is e-flite 400 with APC 9x6 Prop. Juice is from a
Thunderpower 2250 and an e-flite 25 ESC.
I love the way the plane performs. Plenty of Power combined with the
good manners of a Telemaster.
Name:	September 09, 2009 005.jpg
Brian76239 is offline
Old 02-10-2010, 01:26 AM
  #118
PaperAirplane
Subscribed...
PaperAirplane's Avatar
Very cool build rcers, is the mini a very easy flying trainer that you rarely fly because its very easy or one that you take out often?
PaperAirplane is offline
Old 02-10-2010, 01:43 AM
  #119
If you take a quick look at the date on this thread you will find the age of this airplane.
Sadly it scored a goal at the field I fly small planes at, and no longer exists.
Old 02-10-2010, 02:27 AM
  #120
its a great flyer,very easy to build and repairif needed...don't ask how i know...my mini was my first build and 15 builds later its still a joy to fly.
it was a wall hanger in the playroom,but a thread on skis brought it back to life.....does nice in the snow and looks like we'er getting some tonight..woo hooo.
one thing to note,the fuse breaks very easy in the back.if i were to build the mini again id skip some of the cross bracing and sheet the side with 1/32 balsa..it would'nt weigh much more and stength would greatly be increased.
this birds 2 years old and still flys great after many many repairs.not sure if i already posted a picture of it but this is how the old bird looks now.
Name:	dec. of 09 pictures 080.jpg
ID:	120217   Click image for larger version
Name:	dec. of 09 pictures 073.jpg
Old 02-10-2010, 03:38 AM
  #121
PaperAirplane
Subscribed...
I definitely noticed
Too bad, it sounded like you enjoyed the plane.
Thanks, ill be sure to note about the fuse if I ever get around to building one.
Old 02-10-2010, 05:22 AM
  #122
LipoPilot
Flown A Lipo Lately?
LipoPilot's Avatar
AWWW The Mini Telemaster....
Well I seen this post and thought I would add to the Telemaster Madness. I have had my MT for over a year and love it, but she doesnt get to fly much anymore as I got to many other planes to play with. Heres the life of my MT from Hobby Lobby...GREAT FUN. Shes for sale on Wattflyer now as I said I dont get to take her out much anymore, but shes waiting for a new owner.
Videos of my fun with the Mini Tele Master
Maiden Onboard
[media]http://www.youtube.com/watch?v=iLwxKdadyUU[/media]
Fish N Fly
[media]http://www.youtube.com/watch?v=NPOO36dZq9s[/media]
No hands Landing
[media]http://www.youtube.com/watch?v=XUBO2a4n4Wo[/media]
Cartwheel Landing
[media]http://www.youtube.com/watch?v=dyGb_n6QoQw[/media]
Thanks for letting me share...Peace
LipoPilot is offline
btyler
09-11-2008 04:53 PM
btyler
10
08-19-2008 07:23 PM
Liquidity
10
03-20-2008 06:33 AM
Papaw14
ParkFlyers
06-19-2007 05:47 PM
JohnBlankenship
ParkFlyers
13
09-16-2005 03:25 AM
Quick Reply: Mini Telemaster Build thread
Page generated in 0.14493 seconds with 22 queries
