Ultrafly P40 Build
Old 02-27-2007, 07:10 PM
  #126
The Bandit
Originally Posted by barmonkey View Post
Bandit...could you post some pics of your flex rod set-up.
Yeah, I'll break out my dig. camera.
The Bandit is offline
Old 02-28-2007, 07:23 AM
  #127
The Bandit
Here's a picture of my set-up. Single servo near the front of the wing. From the bottom, you can see the route of the flex rods...90 degrees and no binding, I also filled in all the gaps and made a piece that goes over the mounting plate at rear of wing that can be removed to get to the mounting screw. I wanted a totally smooth, clean set-up. My main intent was to get the dead weight off the wings and move them closer to the cg of the aircraft...in hopes to gain a little more agility out of the airplane.
ID:	25314   Click image for larger version
Old 02-28-2007, 12:08 PM
  #128
alienx
alienx's Avatar
Very nice!
alienx is offline
Old 02-28-2007, 07:06 PM
  #129
The Bandit
Originally Posted by alienx View Post
Very nice!
Thanks...I'm still waiting for some more maiden reports. It looks like the wing will handle weight better than your average warbird. I normally carve extra battery space in all my models.
Old 02-28-2007, 07:21 PM
  #130
alienx
alienx's Avatar
Even at my stage in the game I should have known better. But the darn battery area and nose seemed cavernous so I guess I never worried. I can't believe how easy this WOULD have been if I did it before I glued it up.
Oh well, I think I should be able to spend a fair amount of time, hopefully finishing mine, this weekend. May even get a little fying in on Sunday. Who knows.
alienx is offline
Old 03-03-2007, 12:48 PM
  #131
alienx
alienx's Avatar
Default Getting close (I think!)
OK, I'm creeping along here, but I did another bit of work. I put a top on my battery location to keep the pack from rattling around or banging into the motor mount, or just moving out of position. I've done this in an Alfa before and it worked pretty well. I wanted to put some rails on the sides of the opening to accomplish this but I just couldn't get the angle worked out. And I wanted to sink them into the sidewall a little for extra hold but I couldn't get an accurate channel sanded in the fuse. So this is what I did instead.
All I have to do now is cut up some foam stops for the front of the location and I think that should do it. The battery is pretty tight in the space now, so I think like my Alfa and E-flite P47, I won't have to tie the battery down. The tight mount keeps it pretty secure. That's the beauty of doing this with foam ...it compresses to snug the battery in place.
I hope to finish up the stops later today, but I really don't feel any urgency with this build anymore. I guess that's the bad weather we've had. But I see no reason I wouldn't be ready to maiden next weekend if the weather is favorable. At least it will be nice to button this thing up and move it off the bench. I'd like to start another project now!!
Name:	battery top 1.jpg
ID:	25504   Click image for larger version
Name:	battery top 2.jpg
ID:	25505   Click image for larger version
Name:	battery top 3.jpg
ID:	25506   Click image for larger version
Name:	battery top 4.jpg
ID:	25507   Click image for larger version
Name:	battery top 5.jpg
alienx is offline
Old 03-04-2007, 05:54 PM
  #132
alienx
alienx's Avatar
Default Ready to Maiden!
I finally finsihed the P40!!!
I finished up the battery stops this morning. I used some 1/2" square stock balsa that was counter-sunk into the insides of the nose. Gorilla glue did a great job beafing up the fit and amount of glued surface.
Then I just had to tape or velcro in all the electronics. The ESC fit up into the top of the nose. I was able to slide the receiver and wires a little further forward than I originally thought I'd be able to. This let me ease the final battery location back about an 1/8" or 1/4". This made the access to the ESC/battery plugs easier and will also just make it easier to get the battery in and out.
The AUW is exactly 20.60 oz. I am excited about that. I've been flying my E-flight P47 on this same motor. I like the way it is powered at a little over 25 oz. So at a savings of almost 5 oz, this plane should fly pretty nicely.
I guess that's yet to be seen though. I over-prop that P47 and make about 191 watts with it using the stock 10x8 E-flite prop. I am going to maiden the P40 with a milder APC 9x6SF. It only makes 161.4 watts peak but also brings the static amp draw to a safer 14.76 (versus slightly more than 16 amps for the 10x8 prop). Mathematically, the P40 is making a little more power at 125.36 watts/lb versus about 121.02 for the P47. That doesn't tell anything about the flyability of either though. But that's all I can measure at home.
So those are all the facts. This is all theory until you turn it on and chuck it. But it is ready to drop a battery in it and I just need some decent weather to fly now.
Name:	battery stop 1.jpg
ID:	25604   Click image for larger version
Name:	battery stop 2.jpg
ID:	25605   Click image for larger version
Name:	battery stop 3.jpg
ID:	25606   Click image for larger version
ID:	25607   Click image for larger version
ID:	25609   Click image for larger version
ID:	25610   Click image for larger version
Name:	2 planes 2.jpg
alienx is offline
Old 03-04-2007, 06:03 PM
  #133
alienx
alienx's Avatar
Oh, I forgot the good part. I just bought a beautiful, new DX7 and a few AR6100 receivers. So I am probably going to swap out the RX in here now. Looking forward to checking out the new gear this week!
alienx is offline
  #134
pd1
Still Learning
pd1's Avatar
Andy, looks like you've got all the problems under control, now go have a great first flight.
pd1 is offline
Old 03-04-2007, 06:20 PM
  #135
alienx
alienx's Avatar
Thanks Paul!!! Glad to be able to air it out now for sure!
alienx is offline
Old 03-04-2007, 06:52 PM
  #136
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Looks good Andy. We knew you would work through it. Persistence has its rewards. Good luck on the maiden and be sure to take some pictures.
Grasshopper is offline
Old 03-04-2007, 07:35 PM
  #137
alienx
alienx's Avatar
Thanks Tom! I'm hoping somebody else will be at the field to video tape it.
What to work on next ...
My P47 is really going slowly. I think Roger is a little worried about the glassing (even though it sounds like he's done it a fair amount before). But it's going to look great with paint and all the decals I've been gathering. And no antenna sticking out the back!!! I can't wait to get the airbrush on that one. The finish should be really nice to paint on.
In the meantime, I don't know whether to put a firewall in my Lancair and finish that, build the GWS Spitfire I have on the floor, build another "project" E-flite P47 I have some ideas for (and the plane in the box), or pick up something that can house all the big servos and reciever that come with the new Spektrum???
alienx is offline
Old 03-05-2007, 02:23 AM
  #138
kahloq
kahloq's Avatar
Pick up something that can use the bigger servos Heheh. H9 Spitfire
kahloq is offline
Old 03-05-2007, 02:28 AM
  #139
barmonkey
barmonkey's Avatar
alienx, good luck on the maiden. Glad to hear the weight was less than you thought. I haven't made any progress on mine...all I really need are some servos and to figure how I want to run the motor/esc wires.
barmonkey is offline
Old 03-05-2007, 02:48 AM
  #140
alienx
alienx's Avatar
I was thinking Cub, but the spit is nice too!
alienx is offline
Old 03-05-2007, 02:51 AM
  #141
alienx
alienx's Avatar
Thanks Barmonkey! I kind of wish I had mounted the motor with the wires at the top. I think a nice 1/4" notch in the top of the firewall would have been a good set-up. That way you can keep the ESC at the top of the nose.
You may not have the same problem though. If you battery is anywhere near the stock location, you can mount the ESC under the motor right in the airstream!
I tweaked mine a little tonight and added two additional magnets on the slant at the back of the cockpit. One would probably have been enough, but what the heck. Seemed like a shame to peel the nice paint off by using tape.
alienx is offline
Old 03-05-2007, 03:48 AM
  #142
barmonkey
barmonkey's Avatar
I may add some more magnets to my canopy as well. It doesn't want to stay put as is.
Alienx, if you like AT-6 Texans you may want to check out Mr. Lin's latest. Looks very nice! Not a big AT-6 fan myself...but it looks good. And then of course the FW-190 is coming soon!
Old 03-05-2007, 03:49 AM
  #143
barmonkey
barmonkey's Avatar
Bandit thanks for the pics!
Old 03-05-2007, 05:36 PM
  #144
alienx
alienx's Avatar
I do like the Texan. And GWS seems to be making some nice planes (an evolution in quality). They are also tempting just because they seems to finally be slightly larger, which is something that I like.
I'm sure I am in the minority, but I would love to see what GWS could do with a razorback P47 (or even a Bearcat or any other cat for that matter!).
alienx is offline
Old 03-06-2007, 12:48 AM
  #145
gunracer
still no maiden?
gunracer is offline
Old 03-06-2007, 01:01 AM
  #146
alienx
alienx's Avatar
Originally Posted by gunracer View Post
still no maiden?
No, but at least I'm ready now. Hopefully some calmer weather is coming!
alienx is offline
Old 03-11-2007, 04:01 AM
  #147
barmonkey
barmonkey's Avatar
alienx, any word on the maiden yet?
Old 03-11-2007, 05:01 AM
  #148
alienx
alienx's Avatar
Bar, I am kicking myself so badly right now. It was gorgeous today. Mostly sunny, 56 degrees (been 12 all week!), and calm winds. But it was supposed to be rainy and gusty, so I never got to go to the field.
So no maiden yet, but I am ready. I just need some predictable weather.
I AM getting anxious though ...
How is your P40 shaping up?
alienx is offline
Old 03-11-2007, 05:30 AM
  #149
barmonkey
barmonkey's Avatar
Right now it is servo-challenged. I have some cheap Tower Pro servos, but I can't make myself use them in this plane...I want something with a bit more quality...so I will have to wait for some spare cash to get some HS-55's. Also, I am waiting on a new battery. I want to try a 1350Mah rather than the 2150Mah that I originally wanted to use. I guess that won't be here until Monday now.
The weather has been pretty nice here, although it was a bit windy. Not good for a maiden anyway. Did fun stuff like cleaned up the garage and worked on the motorcycle instead.
I will have a few brewskis and ponder the servo situation...I may just rob the servos out of my Spitfire...so many planes...so few servos...
Old 03-11-2007, 05:56 AM
  #150
alienx
alienx's Avatar
Yea, I watched the Daytona 200 today while I should have been loading the car to go to the field! Proud to see Kawasaki take the top 2 spots!!
I too bailed on some Tower Pro's. I got a set of them from the guy that sold me my Florida Cub. I put two in the wings, and the other two in the tail. But the two in the tail made horrible clacking noises, so out they came.
I got a lot done today on my Spitfire, which I am really looking forward to painting. I am going to take a little liberty on the colors and not make them as dull as they probably would be in real life. Maybe going to use a grass or tree green and some cool shade of brown on top.
alienx is offline
Quick Reply: Ultrafly P40 Build
Page generated in 0.15001 seconds with 28 queries
