Top Flite Giant Scale F4U Corsair
Old 05-14-2007, 02:23 AM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Originally Posted by onlyemokid View Post
wow, I like that
Thanks.
Here's more progress on the sheeting of the fuse.
Name:	Forward deck 1.JPG
ID:	31217   Click image for larger version
Name:	Forward Deck 2.JPG
ID:	31218   Click image for larger version
Name:	Cockpit AreaJPG.jpg
rea59 is offline
Old 05-27-2007, 06:54 PM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Default Canopy Cylinder Mounted
The cylinders have all arrived from Robarts. Although it took a long time I still want to thank Robarts for getting these cylinders made for me.
Putting the Canopy Cylinder in the plane required a lot of extra framing. I also had to decide how best to mount the cylinder to the canopy. This was made more difficult due to the fact that the canopy itself will not be mounted for a long time. I decided on using an aluminum tube through the fuse. This makes the plane from the outside look similar to the original.
I also made the cylinder mount out of aluminum and made it a floating style. (Wouldn't want the canopy to bind up.)
The stroke on the cylinder is 2.5 inches. This should allow for a good view of the detailed cockpit and also allow a pilot to fit in and out.
All bolts and nuts use Locktite and will then be covered over with Epoxy. (Once the sheeting is on this area will never be accessible).
Here's the pic'ssorry about some being fuzzy my camera doesn't do close-ups very well) 5/29/07 -- I found the Macro setting for my camera but it's too late for these pic's.
1. New Framework
2. Floating Mount
3. 4-40 Blind Nuts and Epoxy
4. Canopy Rod to Rod end mount
5. Threaded ends
6. A view of where the canopy will mount.
7. Top view
8. Side view
9. Cylinder retracted
Name:	NEW FRAMING.jpg
ID:	32142   Click image for larger version
Name:	FLOATING MOUNT.jpg
ID:	32143   Click image for larger version
Name:	BLIND NUTS AND EPOXY.jpg
ID:	32144   Click image for larger version
Name:	CANOPY TO ROD END.jpg
ID:	32145   Click image for larger version
Name:	CANOPY MOUNTING POINT.jpg
ID:	32147   Click image for larger version
ID:	32148   Click image for larger version
ID:	32149   Click image for larger version
rea59 is offline
Old 05-29-2007, 03:50 PM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Default A little more progress on sheeting the fuse Top.
A little more progress on sheeting the fuse. The first couple of pics show the actuator for the Canopy as compared to a pic of the original F4.
The top has a block added which has to be shaped for the Turtle back (some call it the Turtle Deck some the Razor Back I prefer the Turtle Back as thatís what we called it in the F4 Phantom II community.
The block for the Turtle Back is also the part of the structure for the vertical fin (rudder fin) and as such needs to be oriented correctly. The top of the frame needed to be sanded flat for this block. I found using a long sanding bar to be very helpful.
Looking at the front of the fuse (previous post) youíll note that this is a circle cut in half down the length of the plane. With the top half firmly on the building table (no warps or twists, it lays flat real nicely) I put my inclinometer on the bench and zeroed it. Then I was able to check the top of the Turtle Back frame and also the vertical fin (both side and trailing edge).
I know this is a slow build guys and maybe I can keep the posts steady for a while. Hope you are all enjoying this and maybe learning something along the way. Let me know if youíd like more detail (or even, less). I did stand-up teaching for seven years and Iíd hate to bore you or make this a hard read.
Enough of that hereís the picís:
1. Canopy Actuator
2. Comparison Pic
3. Turtle Back
4. Turtle Back/Rudder Fin
5. 24" Sanding Bar
6. Bench Zero/Incinometer
7. Turtle Back Frame Zero
8. Rudder Fin Side 90 Degrees to Turtle Back
9. Rudder Fin Trailing Edge 90 Degrees to Bench
Name:	Canopy Actuator.jpg
ID:	32353   Click image for larger version
ID:	32354   Click image for larger version
Name:	Turtle Back Before Shaping.jpg
ID:	32355   Click image for larger version
Name:	Turtle Deck-Rudder Fin.jpg
ID:	32356   Click image for larger version
Name:	24 Inch Sanding Bar.jpg
ID:	32358   Click image for larger version
Name:	Turtle Back Zero.jpg
ID:	32359   Click image for larger version
Name:	Rudder Fin Side.jpg
ID:	32360   Click image for larger version
Name:	Rudder Fin Back .jpg
rea59 is offline
Old 05-30-2007, 07:59 PM
19thsqn
19thsqn's Avatar
keep up good work! i keep my eye on this thread all the time..
there is not too much big scale electric warbirds.
i've been watching document from F4U. i think its marvelous bird!
smart design. and very good looking plane landing with flaps down!!!
lots of good looking moving scale details and so on.. yeah i like it!!!
19thsqn is offline
Old 05-31-2007, 12:30 AM
It's really starting to look nice Ray! Can't wait to see her done!
Old 07-08-2007, 11:14 PM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Default More Progress
I've made a little more progress. The turtle back is now glued in a shaped. Next the fuse has to sit upside down to build the other half. This in itself presented a challenge. I could just mock something up for the build, but then when you think about it I'll also need something to keep it on its back while I put the batteries in and wing on. So thats when I decided to build a stand for it. Now that I can have it stable upside down I can now start adding control rods. Post more later.
BTW; with the stand I was able to use it to weigh the fuse. Stand = 8lb 5.8oz and the Upper fuse is 2lb 7oz (with air tank and canopy cylinder)
Pics;
1. Shaped Turtle Back
2. Stand
3. Stand (Yes thats a full size truck battery)
The stand had to be tall to accommodate the rudder. It looks high but the rudder will only have a couple inches clearance.
ID:	35098   Click image for larger version
ID:	35099   Click image for larger version
rea59 is offline
Old 07-09-2007, 12:34 AM
smokejohnson
smokejohnson's Avatar
Nice job Ray. Just want to say thanks for sharing and subscribe.
smokejohnson is offline
Old 07-09-2007, 03:16 AM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Thanks Smoke! Still a long ways to go yet.
rea59 is offline
Old 07-10-2007, 10:37 PM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
With the stand made and the fuse flipped the first step in building the bottom is to install servos and control rods. This is a large plane with large control surfaces, not withstanding the expense of the plane I would not want anyone to get hurt or property damage to occur due to a failure of a control rod or a stripped gear in a servo so I will be using 4-40 rods and high torque metal gear servos.
#1. If your like me inserting the brass grommet into the rubber grommet of a servo can cause pain to the fingers and a general sense of frustration to your normally calm state of mind.
Take a wooden dowel about the size of a pencil and sharpen it with a pencil sharpener. Used this to insert the brass into the rubber. Your state of mind will appreciate it's use. Note: do not use a real pencil as the lead will break. (don't ask how I know this).
#2 & 3 Rudder Servo: JR DS8711 digital, Metal Gear, Alum. Heat sink.
Height 1.5"
Width .83"
Length 1.59"
Weight 2.36 oz
Torque 403 oz/in @ 6V (yes I will run at 6V with a JR 2700mah Rx battery.
Speed 60 degrees in .15 sec
#4. Close up of 4-40 ball link for servo end.
#5. Close up of Solder connector for Rudder end. This area will have no access after model is completed. (after cutting to length I roughed up the rod by running a 3mm die over it.) Still need to get some silver solder to attach it.
Name:	Inserting Brass.jpg
ID:	35260   Click image for larger version
Name:	Installing servos.jpg
ID:	35261   Click image for larger version
ID:	35262   Click image for larger version
Name:	4-40 Ball Link.jpg
ID:	35263   Click image for larger version
Name:	Solder Connector.jpg
rea59 is offline
Old 07-10-2007, 11:14 PM
Tinman
The Hot dog man
Tinman's Avatar
Wow your one heck of a builder Ray! Looks great! Thanks for sharing and keep up the good work!
Tinman is offline
Old 07-17-2007, 05:55 PM
Mustang11
Ray,
An observation here......... shouldn't the brass servo grommets go in from the bottom? I thought they were there to limit the rubber mounting pad crush as the screws are tightened, and without the collar/lip on the bottom they'll simply dig into the plywood/balsa base. That's been my experience anyway......... awesome build regardless!!
Mustang11 is offline
Old 07-22-2007, 02:00 PM
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Originally Posted by Mustang11 View Post
Ray,
Very interesting observation. :<
I have worked with many different isolation mounts and the flange on the grommet always goes toward the screw or bolt head. This is to prevent the screw or bolt from digging into the rubber and there by allowing the rubber to slip off the brass grommet and screw. Note that the opposite end has a large surface which prevents it from moving in that direction. The point you raise is a valid one with regard to digging into the soft wood. If I flipped the brass grommet around I would need a washer against the screw head to hold the rubber. Then again a washer could be put against the wood side to prevent the digging.
(Sorry it took me so long to answer your post, I took the kids on vacation to my Dad's farm in Missouri)
Do any others out there have a method they use that's different??? And what is your all's experience with the servos coming loose???
On a side note: While I was in Missouri I found hanging from the ceiling in a storage room a .40 size P40 Warhawk built in 1972. I have brought it home and will start another thread on making it flyable.
rea59 is offline
Old 07-22-2007, 03:05 PM
  #63
smokejohnson
I have mine with the flange up. What Mustang11 is saying does make since but I have not had any issues going flange up. If I ever have that problem though now I have some ideas to fix it. That is if I can remember .
Will you keep the Warhawk a slimer or convert it to electric? Sweet find .
Old 07-22-2007, 03:13 PM
  #64
rea59
BEEP..Bleep..BEEP
rea59's Avatar
I don't know yet. Let me get some detailed pic's and post a thread then you guys can give me some ideals. (I know all the electronics have to be replaced)
rea59 is offline
Old 08-13-2007, 11:17 PM
  #65
Mustang11
Ray,
Funny you should mention the washer on top trick, I just used that on a SebArt Katana with microservos as the brass inserts were too long to allow any crush of the rubber pads. That's one of the multitude of things I love about this hobby; there are so many ways to do things and all of them work equally well! No worries on the reply time, my daughter is 5 and I understand about busy. Larry
Old 09-05-2007, 06:35 AM
  #66
xuzme720
c'mere Monkey
xuzme720's Avatar
somehow have missed this one until now! fantastic build, Ray!
xuzme720 is offline
Old 09-05-2007, 10:20 PM
  #67
haze_b
haze_b's Avatar
Aloha,
I'm a HUGE fan of electric flight, but just curious, why did you go for electric on such a big plane? ??
Wouldn't a gas/ignition setup be more economical?
haze_b is offline
Old 09-05-2007, 11:11 PM
  #68
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Originally Posted by haze_b View Post
Aloha,
As you say gas would be more economical but this build wasn't about saving money. I'm actually going a little overboard on this one money wise. When I was younger I had a nitro plane and then while in Japan I had nitro cars and trucks. I got back into RC a couple years ago with the electrics and haven't looked back since. They are much cleaner and less hassle to deal with. There weren't many big electric planes out there so this has been about the challenge of making a big heavy old war bird fly with electric power.
rea59 is offline
Old 09-06-2007, 03:54 AM
  #69
Bundy
Bundy's Avatar
Hi Ray
Just came across this thread and you are doing a great job - always good to see large scale electrics.
I've built an electric version of the Brian Taylor Corsair which is a little smaller than yours at about 82" span. I still haven't maidened her yet as I'm having trouble getting her to balance. When people said to build the Corsair's tail light I thought I would be right with a 6" speaker for sound, working cowl flaps and a 10S lipo up front but I was wrong. I did build a scale tail wheel, working arrestor hook and working canopy but nothing too heavy in the tail I thought.
The EVO20 packs I planned to use are 300mm long but I just can't get enough weight far enough forward. I am already at 20 lb and I don't want to add nearly another 2 lb of dead weight in the front.
I've just received some of UnitedHobbies' 6S lipos which are a more compact shape so I hope these will balance her without adding lead. Don't know much about them but I guess I'll learn having used only EVO for the last few years.
I don't know about the Top Flite Corsair but the Brian Taylor one needs the tail built light! I just wish I'd taken the advice more seriously at the start.
For a bit of inspiration have you seen this folding wing on YouTube? http://youtube.com/watch?v=rBI1oA1Gjfc
Good building and I'll be sure to check back in often.
Richard
ID:	40180   Click image for larger version
Name:	corsair progress 006.jpg
ID:	40181   Click image for larger version
Bundy is offline
Old 09-06-2007, 04:02 AM
  #70
Wow Richard that is really awesome!
Ray that should fire you up a bit huh?!
Old 09-06-2007, 04:26 AM
  #71
smokejohnson
Wow Richard! Nice plane. Will you have machine gun sounds along with motor noise?
Old 09-06-2007, 07:02 AM
  #72
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Originally Posted by Bundy View Post
Hi Ray
Richard
Great looking bird you've got there. Good luck on the maiden. The Top Flite even with the gas motors require 3lbs of lead in the nose.
Thanks, I guess I do need to get back to it.
rea59 is offline
Old 09-09-2007, 05:01 AM
  #73
Pig
Pig's Avatar
Ray, I know this is a long way off still, but what unit will your Corsair be a part of? May I suggest one of the most well known Navy Corsair pilots, Greg Boyington. Granted, he was a drunk and in later life accused of being a money grubber and exaggerator, but he was a helluva pilot! He was also posthumously awarded the Medal of Honor after he was thought dead. But, enough of history.
Fantastic work on this build!! That motor his huge!!! This is going to be awesome when done!! Please have lots of video footage of this in flight!
For reference, he's a good pic of Boyington's LuluBelle.
Name:	Boyington 86 corsairF4u-1a.JPG
Pig is offline
Old 09-09-2007, 06:15 AM
  #74
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Boyington would be a popular one and I have thought about it. Right now this is where I'm leaning. (I spent 4 years with the red devils)
rea59 is offline
Old 09-19-2007, 11:58 PM
  #75
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Default Still working on it.
Just an update to let everyone know that I'm still working on this. I've spent a lot of time flying and working(for pay) that I haven't been able to spend on this project.
I have the main support for the wing saddle in and this creates the box area that the batteries Will go in. This in itself slows me down due to this plane originally is a gasser and I'm converting it as I go to electric. So i spend and inordinate amount of time just thinking and making plans for my next step in order to not miss anything in the conversion. (I don't want to be on step 435 and find out I should have done something different on step 173)
Right now I'm looking at the battery sizes and area available and options for mounting and also for cooling.
I'm about 2 steps away from having the nose in it's full "round" configuration. I'll post more pic's as get a little further.
Thanks for keeping up with me.
rea59 is offline
Quick Reply: Top Flite Giant Scale F4U Corsair
Page generated in 0.15380 seconds with 45 queries
