Grayson parkjet lipo setup
Old 07-19-2011, 10:04 AM
n3o
Default Grayson parkjet lipo setup
Hi folks!! My pal got the grayson parkjet yesterday. But the guy whom he got it from didn't mention any lipo setup.
after looking up different sites, I am thinking about using this one
http://www.hobbyking.com/hobbyking/s...dProduct=16345
however considering the weight another contender was
http://www.dealextreme.com/p/mystery...-battery-46058
Will it be good enough?
-n3o
n3o is offline
Old 07-19-2011, 11:35 AM
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
For that 2200kv 50gram motor, depending on your application a 3s 1500-2200mah lipo would probably be best. Which plane will you be using this in?
HeliScRapYard is offline
Old 07-20-2011, 12:24 AM
crxmanpat's Avatar
I've used the Grayson combo in pusher jets weighing between 12 and 20 ounces, and have used everything from a 3S 1300 to 3S 2200. It really depends on the plane you're putting it in. Obviously, the bigger the battery the longer the duration.
crxmanpat is offline
05-28-2020 10:50 PM
n3o
07-18-2011 11:15 PM
Henry111
Batteries & Chargers
118
03-18-2011 07:27 PM
Wrongway-Feldman
03-14-2011 05:50 PM
Quick Reply: Grayson parkjet lipo setup
Page generated in 0.07377 seconds with 15 queries
