Electric suggestion for an Extra300, 64" - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-24-2016, 03:28 PM
robinleblond
Default Electric suggestion for an Extra300, 64"
Hello,
Iím planning to convert my Extra 300 to electric. It was flying (some time ago) with an old 35cc with a prop around 18/8.
I have an habu, so Iím not that new to electric, but I will need something a way bigger for the Extra 300. Can you suggest me a setup for it (engine, battery and ESC), I just need a starting point to do me researchÖ
Thanks!
robinleblond is offline
Old 05-24-2016, 03:39 PM
Auw? Gonna 3D?
Based on similar size ply and balsa planes I have, I'd be looking at a .46 or .60 500-600 KV motor with 80 -100 amp esc running 5S or 6S 4000 mah lipo.
What's the actual model? Mfg?
I like the Powerup brand from headsuprc
But lots of other choices including Hobby King.
Of course, you're Habu is an edf and you cannot compare the two.
Wish I knew more,
Old 05-24-2016, 03:46 PM
robinleblond
AUW is very hard to tell since it was with a gaz engine before and the engine is no loger in it since a while...
Yes, I will do some 3D.
Old 05-24-2016, 03:59 PM
Is the frame fairly light? Like one from 3DHS ?
Quite a bit of discussion on this over on RCG. Just google: 35cc RC
Motor to electric and you'll find threads on this very topic. You're not alone.
Looks like a 60 size electric motor. G60 Turnigy, Rimfire 60 from Tower, Powerup 60 from headsuprc, Hacker 60, etc.
The world is your oyster !
Welcome to WF and good luck,
Old 05-24-2016, 09:44 PM
i have the great planes Extra 300s[64inch ws] kit built out converted to electric. using a Eflite power 60 with 7 cells[40c4000mah 4cell and a 3 cell 4000mah 40c hobby king zippy in series].
100 amp castlecreation ice esc. she flys unlimited vertical and lands fast do to being fairly heavy. it's a kit build and i built the battery compartment in the bottom feeding the batteries in through the bottom of the cowel. i have a video somewhere of me knocking off the landing gear on a bumpy landing. will see if i can find it. using a 15inch prop apc.
found it:https://youtu.be/LdlUL69-wFI
06-28-2017 04:22 PM
01-09-2017 02:23 AM
11-02-2014 01:32 AM
invertedthoughts
07-05-2011 01:13 AM
Quick Reply: Electric suggestion for an Extra300, 64"
Page generated in 0.08495 seconds with 13 queries
