Powerlab 8 V2 and 6 cell lipo problem - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-06-2015, 06:33 AM
JJ1
Default Powerlab 8 V2 and 6 cell lipo problem
I need some advice on a recently purchased a PL8 that is having trouble with charging 6S Lipo packs. At this stage I have tried everything I know of and suspect the PL8 is faulty.
If I use a 12V supply and try to charge above 6 amps the system soft start error occurs shortly after the charge current starts to ramp up. A 50Ah AGM battery and several Dell 750 watt server supplies have been tried.
The packs are Revo 3300mAh 6s 40C with EC5 connectors. I have tried charging one pack directly plugged into the CP8S-GP/KO6S-PAR balance board and all four packs with a Turnigy parallel board.
With a 24V supply (two AGMs or two server supplies in series) the charging starts OK and runs for a while, but ends with a Node over current error at some point unless the charge current is kept around 6 amps.
4S lipos so far have presented no issue at any charge current I have chosen up to 30 amps so there does not appear to be any issue with cables or connections. The 4S packs are Revo 4400mAh 60C.
Thanks,
Jason.
JJ1 is offline
Old 07-06-2015, 08:29 PM
Gregor
It looks like FMA has been trying to get a hold of you http://www.rcgroups.com/forums/showp...21&postcount=7
Gregor is offline
Old 07-07-2015, 03:47 AM
JJ1
Indeed.
Since I have now received advice from FMA on RCgroups I'm not expecting anything further in this thread.
I'm happy for this thread to be deleted or to remain in which case I will update as appropriate.
JJ1 is offline
Page generated in 0.08207 seconds with 12 queries
