Help with Powerlab 6 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 02-05-2015, 09:16 PM
shung1
Default Help with Powerlab 6
Hi Everyone,
New to wattflyer and hope you can help?
Just purchased a powerlab 6 and am having issues charging my 3S 2200mAh lipos out at the field using a car battery (12v) as the power source. I have gone into the options in the charger menu and selected "battery" as the power source and have selected "fast charge" and 4.4amps as the charge rate.
The issue is that I am only getting a maximum of 1amp coming out of the car battery? Am I doing something wrong or is there another setting in the charger that needs adjusting?
Cheers.
shung1 is offline
Old 02-06-2015, 06:18 PM
Stevephoon
Stevephoon's Avatar
There is a max current draw setting in the PL6. I'm not sure what the default is...
From their manual
Battery Max Amps Out: Set for maximum supply battery current draw. If the charge rate is set higher than the input current allows, the PowerLab 6 will draw no more than the level set here, which may limit output current to the pack. If Battery Max Amps Out is set too high, the battery’s output voltage may drop below the Battery Low Voltage Out setting and charging will stop and the input battery could be damaged from excessive current draw.
The manual can be found online here:
http://www.revolectrix.com/support_docs/item_1380.pdf
Stevephoon is offline
Old 02-06-2015, 08:08 PM
shung1
From their manual
Hi mate,
Ive read the manual and seen this section, the default was set at 15 in the charger. Ive had it all the way down to 3 and still had the same issue. I think its going to be trial and error to find the right combination between amps in and amps out to get it to work?
Thanks for the reply.
shung1 is offline
Old 02-06-2015, 10:23 PM
Flubber
Flubber's Avatar
Denny is good with the powerlabs and I am sure he will see this post. How are you checking the amps out of the car battery? When I watch my powerlab 6 It starts at a much lower charge rate than I have set while it works some magic on the battery. After a short time it begins to increase the charge rate to the amount set. If it is during this ramp up time that you are seeing the low amp draw it would be understandable. I wish I could be of more help, but I use mine with a power supply and a parallel board so I can charge six batteries at a time. I hope you get it figured out because it is a great charger.
Flubber is offline
Old 02-07-2015, 01:18 AM
shung1
I also use mine with a power supply and parallel board, just wanted to try the battery option for times when I head out to the park etc.
Yes it is a great charger!
shung1 is offline
Old 02-07-2015, 01:42 PM
Stevephoon
Stevephoon's Avatar
You should be able to do exactly what you are talking about. I usually charge at home from a power supply, but take it to the field for special events. The only thing I remember doing is selecting the power supply type at start up. Have you tried just using the power supply settings when connected to your car battery? I wonder if you are hitting a low voltage limit on the ower supply side.
If you have the ability to use the CCS software, it makes the setup a little easier.
I'm confused with you.
Old 02-07-2015, 10:35 PM
Gregor
It sounds like the charger is limiting due to hitting the low supply voltage value set too high. The default is 10v. If its set to 10v now, then its likely the connection between the charger and the battery source.
You can see the reason for limiting in the CCS. Take a look and post your results.
Gregor is offline
Old 02-08-2015, 01:17 AM
Default LiPo Battery Issue?
Originally Posted by shung1 View Post
Hi Everyone,
Cheers.
Have you tried another LiPo battery?
Those Cellpro chargers will really back off on the charging rate if they run across a battery out of balance. The charger goes to a much lower charge rate, while it uses its one ampere ability to balance out the cells.
Use the Cellpro charger, and scroll to the voltage on each cell, and make sure they match up. Exactly.
Howard Matos
FMA Direct
11-25-2013 09:22 PM
Batteries & Chargers
01-19-2013 08:01 PM
Tim Marks
FMA Direct
63
09-21-2012 05:09 AM
24
07-29-2012 03:29 AM
Howard Matos
FMA Direct
10-25-2011 07:03 AM
Quick Reply: Help with Powerlab 6
Page generated in 0.06261 seconds with 13 queries
