Habu 32 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Habu 32
Old 02-28-2012, 10:53 AM
zakarian
Zak
Default Habu 32
Hello
First excuse my English because I am French.
While practicing the model aircraft for many years, I am a novice for EDF.
I have mounted the Habu 32 E-Flite fiber version, with the recommended equipment except the controller who is a J. Perkins model "En-ErG Pro B-115 Opto" 115 A continuous.
Problem: I put the engine full throttle, the aircraft on ground in static mode, and after a 1,3 minutes, the motor blocked and controller calcined.
The engine teardown, overheating is clearly visible and the coil at the black wire is fused, after the welding.
Thank you in advance for your help, I like to know the real cause of the problem before ordering a new motor and controller.
Regards
Zak
zakarian is offline
Old 02-28-2012, 05:13 PM
NJSwede
3D wannabe
NJSwede's Avatar
Originally Posted by zakarian View Post
Hello
Regards
Zak
Zak, I'm no expert, but running the motor on the ground for more than a few seconds is usually a no-no! The ESC depends on cooling it gets from the headwind as the model travels through the air.
NJSwede is offline
Old 02-28-2012, 09:39 PM
dkrhardy
Swede, I agree. Some folks say that props provide enough cooling on the ground, but I disagree. I doubt that the fan blows any air over the ESC on an EDF plane.
Don
dkrhardy is offline
Old 02-29-2012, 01:37 AM
Elfwreck
PHD in Crashology
Elfwreck's Avatar
Hey now,
In the edf crowd it's comon to run no more than thirty seconds maximum of face serious melt down. Mostly we try hard to keep it to ten seconds or less.
Make sure everything is balanced well and totaly free spinning before you run it up too. You really need air flowing over the motor and esc. Unless you maybe somehow nicked or scratched the windings like maybe used too long of a motor mounting screw? That could also cause the problem.
Good luck with it. It's a fun plane.
RobII
Elfwreck is offline
Old 02-29-2012, 10:01 AM
zakarian
Zak
Hi everybody
Thanks for your answer.
I think this plane very comon in your country, and I have another question to ask.
Is the ESC cooling enought (under the battery), or it's beter to place it in one of the 2 air inlet veins of the turbine, by practising an opening.
Zak
zakarian is offline
Old 02-29-2012, 05:32 PM
Elfwreck
PHD in Crashology
Elfwreck's Avatar
Hey now,
More airflow over the esc is always better. However cloying up the ducting, either intend or eflux is very bad. You need the ducting to be smooth and clear for it to work properly.
I've flown several of these as a test pilot for friends and like most E-Flite brand models it works very well box stock. So you shouldn't need to modify it in any way.
RobII
Elfwreck is offline
Old 03-02-2012, 08:50 AM
zakarian
Zak
Hi Elfwreck
Thank you for your answer
Zak
zakarian is offline
Old 03-29-2012, 06:39 PM
zakarian
Zak
Hey
The Habu 32 is now powered with the recommended equipment and E-flite 80-Amp Pro Switch ESC. But I have another problem:
When I push the throttle stick gradually until the motor start,the engine runs during 1 or 2 sec., then current increase and the motor stops.
In your opinion what would be the cause the motor or the ESC programming (timing is default setting 15).
again thank you
Zak
zakarian is offline
Old 03-29-2012, 06:44 PM
zakarian
Zak
Hey
When I push the throttle stick gradually until the motor start,the engine runs slowly well during 1 or 2 sec., then current increase and the motor stops.
again thank you
Zak
zakarian is offline
phillipmorris
10-31-2011 10:42 PM
Appleman6161
Foamies
10-16-2011 04:59 PM
Albatross
07-25-2011 03:46 AM
4stripes
Electric Ducted Fan Jets
06-22-2011 02:09 AM
flyboy_fx
13
06-04-2011 03:38 PM
Quick Reply: Habu 32
Page generated in 0.06427 seconds with 13 queries
