Cellpro 10S won't charge two packs -- errors codes display - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-04-2010, 04:09 PM
Prof100
Default Cellpro 10S won't charge two packs -- errors codes display
I bought my Cellpro 10 last spring at the Toledo Weak Signals RC show. It's worked great until today. Now I can only charge 1 pack.
When I use the discharge cables I get Safety code 86 (charge switch close failure) when the banana plugs are installed and I hook up two packs for charging.
When I remove the discharge cables and use the yellow banana plug I get C2 pack detected (Pack was added to Ch2 while charging) but that is not the case. Both packs were connected before pressing the charge button.
I get the error messages when I press the charge button to begin charging and the charger goes into "Checking Packs".
Troubleshooting attempts:
1. I have swapped charge connectors from Ch1 to Ch2 and the same problem persists.
2. Power supply is 6 amps and the current is limited using the software. I have connected to 850 amp hour car battery. The problem still persists.
3. I have reloaded the firmware.
4. If I can't get this fixed this is a mighty expensive 5 cell single pack charger if i can't get it to work on Ch2.
5. I checked continuity between 2 and 3 and there was no continuity. I replaced the internal 15A 125V soldered in fuse that bridges the two with 15 amp automotive blade fuse (a FMA suggestion). I NOW HAVE CONTINUITY but the problem still persists.
Assistance from FMA would be great. This is a mighty pricey charger that can only charge up to 5S and only one pack at a time when it's supposed to do two at a time.
Prof100 is offline
ottertok
FMA Direct
01-10-2010 09:27 PM
Larry3215
10-05-2009 12:48 AM
Curtster
Batteries & Chargers
10-30-2008 03:57 AM
Mike Freas
101
05-04-2008 09:59 PM
guest001
01-23-2008 04:33 PM
Quick Reply: Cellpro 10S won't charge two packs -- errors codes display
Page generated in 0.07718 seconds with 13 queries
