Power supply ModelPS13.8V28A-Bp - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-20-2010, 11:21 AM
Henry Sistrunk
Henry Sistrunk's Avatar
Default Power supply ModelPS13.8V28A-Bp
Last nite This power supply popped the breaker on the curcuit it is plugged into while charging a 4 cell lipo. Nothing lights up on the front panel. Help
Henry Sistrunk
Henry Sistrunk is offline
Old 04-20-2010, 09:18 PM
Howard Matos
Production Supervisor
Howard Matos's Avatar
Originally Posted by Henry Sistrunk View Post
Last nite This power supply popped the breaker on the curcuit it is plugged into while chargind a 4 cell lipo. Nothing lights up on the front panel. Help
Henry Sistrunk
Hi,
There is an internal fuse in the power supply that you check.
1. Make sure the power supply’s power switch is set to OFF.
2. Disconnect the AC power cord.
3. Wait at least one full minute for the power supply’s capacitors to discharge.
4. Remove 4 screws securing the lid through the side panels.
5. Remove the lid.
6. Remove the fuse, located near the AC input socket.
7. Install a new 6A fuse of the same type.
8. Replace the lid and secure it with 4 screws.
If this does not correct the problem, please return the supply to us with a note as to the problem. We will get it replaced for you.
Howard Matos is offline
Old 04-21-2010, 01:37 AM
Henry Sistrunk
I had followed the fuse change instructions that came with the power supply. The old fuse was burned. I pluged the power supply in and when I turned the switch on LIGHTNING flashed all inside. And it also burned the new fuse out. Something is seriously shorting out in the power supply. It will be in the mail tomorrow.
theluckyone17
Batteries & Chargers
17
10-17-2010 05:59 AM
big daddy
11-10-2009 04:53 PM
mtdoramike
06-14-2009 09:16 PM
JckedUpCustomz
Ebay for sale
09-13-2007 08:14 AM
JckedUpCustomz
New Product Announcements
09-10-2007 07:12 PM
Quick Reply: Power supply ModelPS13.8V28A-Bp
Page generated in 0.08787 seconds with 13 queries
