turnigy 6 charger - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
turnigy 6 charger
Old 02-14-2009, 04:28 PM
gramps2361
gramps2361's Avatar
info turnigy 6 charger
just got the turnigy 6 charger went to use it programed in for nihm 1.0 amps to charge started it then it came up with connection break error with series of beeps. any body have any input on this? or is it "uep" user error problem
gramps2361 is offline
Old 02-16-2009, 09:27 PM
gramps2361
gramps2361's Avatar
found the problem went to lhs mark checked the nihm's out they were cooked didn't think they were holding a good charge he then cheked the charger had no problem setting up with a nihm battery left with wallet a little lighter 2 nimhs lighter, oh to be a newbie at this.
Old 02-16-2009, 10:06 PM
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
nihms are good to start out with because they survive crashes better.once you get the hang of it though lipo batterys will give you the best performance & bang for your buck.cant beat hobbycity prices on them-http://www.hobbycity.com/hobbycity/s...5&ParentCat=85
Rolling Thunder is offline
Old 02-16-2009, 11:55 PM
gramps2361
gramps2361's Avatar
thats where i bought my lipos and charger wish there shipping was a little quicker just bought a esc w/programming card. wish my lhs could come down in price all name brand $$$$ rather buy here than overseas.
Old 02-17-2009, 12:29 AM
weathervane
Needs more LED's
weathervane's Avatar
Gramps2161, How does the quality of that charger look? I have been thinking of getting one. Did it come with all of the ballancing plugs? (plugs to ballance Li-Pos) Are the directions easy to understand? What was your first impresion of it?
Thanks, Andrew
weathervane is offline
Old 02-17-2009, 12:56 AM
gramps2361
gramps2361's Avatar
http://www.hobbycity.com/hobbycity/s...lancer/Charger it list what it comes with as far as plugs mine came with plugs i don't even need right now there are 2 threads one that both gave it good reviews and the price 37 dollars and change charged my 2s 1500 mah in just about a hour, download the manual it is on the same page as the charger at the bottom ,very happy with it easy to use for this newbie.
Old 02-17-2009, 01:00 AM
gramps2361
gramps2361's Avatar
Turnigy Accucell 6 1st Impression this is one of threads that helped convince me to get it hope this helps out a little weathervane
Old 02-20-2009, 10:54 PM
Cdr. Instigator
Pimp My Plane
Cdr. Instigator's Avatar
Gramps.. Pm sent..
I'm just curious..
Reading up on the manual. It seems like you have to plug the balancing cable and the power cable on the battery to the charger.. I'm used to charging my Lipos using a balancer in between the charger and battery.. So, I've only charged my Lipos through the balancing cable..
Am I missing something..
I just got the charger myself and I don't want to blow nothing up..
the manual explained it clearly.. I just worry.. I have yet to use it and I have had it for 5 days now.. I have 2 planes waiting on their maidens because I have yet to charge my Lipos..
Cdr. Instigator is offline
Old 02-20-2009, 11:20 PM
gramps2361
gramps2361's Avatar
were the you connect the battery to the dean plug there are five slots the top slot next to the red output is were you plug in the white lead off the battery it has 3 pins that is what my 2 cell lipos have don't know if a 3 cell has more pins or not but make sure you have them lined up right so you don't damage them, they only can go in one way. my 2 cell lipo i didn't balance the first charge did it the second time.
Old 02-20-2009, 11:24 PM
gramps2361
gramps2361's Avatar
this charger will replace your balancer just keep an eye on it i was nervouse myself not having any lipos before just nihms and reading everything about lipos i might as well been a hen sitting on a egg waiting for the first charge to finnish.
Old 02-20-2009, 11:54 PM
Cdr. Instigator
Pimp My Plane
Ok, so..
The battery's dean connector is plugged into the chargers deans connector and the balancing connector is also plugged into the charger via the 3 or 4 pin plug?
Old 02-21-2009, 12:12 AM
gramps2361
gramps2361's Avatar
thats the idea.hope it helped out did you check out the link to the other thread for this charger Turnigy Accucell 6 1st Impression he is supposed to add some more comments to it.
Old 02-21-2009, 12:14 AM
Cdr. Instigator
Pimp My Plane
Yeah, I did read the thread on the link you provided.. Very good info. It answered my questions, but I had already posted here.....
Thanks Gramps!!
Old 02-21-2009, 01:19 AM
gramps2361
gramps2361's Avatar
glad to help chance to payback for all the help i've gotten so far from everyone.
Old 02-22-2009, 06:25 PM
Cdr. Instigator
Pimp My Plane
Time to build me a PC Power Supply..
Last night I charged 5 3c batteries using my car. I forgot to run my car after the 3rd battery just to see if it would crank..needless to say, I didn't..
I charge 5 batteries and when I went to start my car.. I guess it need more than 10v to crank up.. it was dead!
I will go to Radio Shack and by a 10W 10ohm sand bar resistor and 3 sets of banana jacks.. That's all I need to start my Power Supply Mod to charge my batteries from now on..
http://www.rcgroups.com/forums/showp...&postcount=343
Old 02-22-2009, 06:35 PM
gramps2361
gramps2361's Avatar
that bites i have been using my trolling motor with battery charger hooked up to it. picking up laptop power supply from one of the IT guys were i work they have extra and best of all it's free.bringing the charger with me just to get one that fits. my truck door didn't shut all the way one night, just the dome light drained my battery what a way to start a mon. morning 10 degrees out that morning not a happy camper hooking up a charger to get enough to crank it over life is fun.
Old 03-25-2009, 11:52 PM
weathervane
Needs more LED's
I recieved my Turnigy-6 charger last week. What a nice unit. It is small, quiet, and easy to use. The main reason for me was, I wanted a unit to charge everything I have and ballance my Li-Po's. This will charge / ballance them and allow you to look at the voltage of each cell while charging. How cool. It came with every cord and plug you could ever need. No need to make any.
I cut off the stock clips and made a plug that I can use with my portable jump box. I plug the charger into the jump box and use it to charge what ever I need. Weather at home or at the field. I use the wall wart to keep the jump box charged. It will not over charged and is always ready to go. I keep all of my chargers plugged into a power strip that I keep on a timer. Every day at 8:30 pm everything gets a 30 min charge.
-Andrew
Old 03-26-2009, 01:35 AM
gramps2361
gramps2361's Avatar
Glad you like it weathervane so far it has been working just fine for me. Your right about every plug ya need. have to get the y connector so I can charge 2 like batteries at the same time.
Old 03-26-2009, 05:58 AM
ozflyer
Hi there I have ordered one of these and am waiting for it to arrive. I'm sure I read that you can program it to shut off, if the input voltage gets too low, thus not draining your car too much.
ozflyer is offline
Old 03-26-2009, 05:42 PM
gramps2361
gramps2361's Avatar
I never so this in the instructions, post it if you have the instructions on how to do this. My luck I would drain my battery.
Old 03-29-2009, 08:51 PM
RoadKingAl
RoadKingAl
RoadKingAl's Avatar
Default Instructions
Fey Gramps, what instructions do you need.
I have the latest instructions for what seems to be the generic 6 cell charger with a balancer built in. Best of all of the instructions I have yet seen
Let me know if you need a set.
Al
RoadKingAl is offline
Old 03-29-2009, 09:53 PM
gramps2361
gramps2361's Avatar
ya I would be interested in programing it to shut off before the battery in my truck dies. I didn't see that in the downloaded instructions from HK.
k
RoadKingAl
14
12-23-2010 09:05 PM
jlaffin
Aerial Photography
01-29-2009 02:33 AM
gazzacov
3D Flying
12-19-2008 10:21 PM
stout890
09-30-2008 11:20 PM
humboldt guy
08-22-2008 09:02 AM
Quick Reply: turnigy 6 charger
Page generated in 0.09326 seconds with 13 queries
