hobbico quick field charger & E-Flight batt help - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-14-2005, 02:34 AM
rmbler
Default hobbico quick field charger & E-Flight batt help
hi all.... i need some info before i do something i might regret i have the hobbico Field charger mkII and want to charge an e-flight 11.1 860 Mah battery i just need to make sure i have the set up and setting right i have it a 0.7v and am using and using the white lead to charge the battery so before i kill the battery and possible fire is this what i want to have it set at and how long should it take to charge and battery that's a bit less that half discharged anyone with this info please help me out here don't want to blow up the house.
Thank you
Regards,
Phil
rmbler is offline
Old 12-14-2005, 04:40 AM
cyclops2
Do yourself and house a big favor. Do NOT use the charger till you call the manufacturer and have them tell you what to do. We will all sleep better.
cyclops2 is offline
Old 12-14-2005, 01:51 PM
Matt Kirsch
Matt Kirsch's Avatar
First off, you won't blow up the house. Even if the pack catches fire, if you're prepared and paying attention you will be able to quickly get the fire under control. You are charging in a fire-resistant container that can be quickly covered to smother any flames, right? Your mom's/wife's old pyrex casserole dish is an ideal charging vessel for small packs in a pinch.
But, the pack is not going to catch fire because you're going to make sure you have the charger settings right before you charge.
You've got the current set correctly, but more important is the cell count. Does this charger have a way to set the number of cells, or the pack voltage? It should be set to 3 cells, or 11.1V, or 12.6V depending on how the charger works. Many chargers autodetect the number of cells. You need to carefully read the instructions.
Matt Kirsch is offline
Old 12-14-2005, 02:21 PM
RiverPlane
I do charge my LiPo 7.4V 2200 mah with this charger. Initial charges (4 or 5 times) were at 0.6 Amp taking 3 hours aprox to get at 95% (8.12V). Charger stops itself when this V reached. I always put the batt in a copper pan with its lid on and checking its temp. Once did this initials charges you may charge at 1C (0.8A in your case) I can't do that 'cause the MKII won't charge more than 1A for LiPos, so I'm always under a safety threshold.
I guess you have not problems as you keep this secure procedures. The charger is capable to work with 4 LiPos packs. My advice is to charge your batt at 0.4A for the 4 or 5 first times, then you may use 0,8A
Alex
RiverPlane is offline
Old 12-16-2005, 03:37 AM
rmbler
thanks for the reply guys, one more question just how warm is the li-po suppose to be when charging or does that depend on the specks of each battery.
Regards,
Phil
rmbler is offline
Old 12-16-2005, 12:15 PM
TRASHBUG
I don't think your batteries should get warm during charging. I have the same charger and have never had a battery warm up during charge. Just remember green LED for lipos!
Jim
TRASHBUG is offline
Old 12-16-2005, 01:07 PM
RiverPlane
My lipo never get warm, just a little when discharged.
IF GET A LITTLE WARM WHEN CHARGE, DISCONNECT IMMEDIATELY.
Always watch your battery while charge
Old 12-25-2005, 03:48 AM
Ron S
Ron S's Avatar
Location: Lawrenceville,(in the middle of nowhere) Illinois
Same here! My packs never get warm during charging! Don't exceed 1C (example- 1200mah = 1.2 amps. or 1C. They are better off being charged at the lowest rate your charger has! Like 250mah! Field (fast charging ) works them a little hard,but is ok as long as you don't exceed 1C ! Ron:p
Ron S is offline
Old 12-27-2005, 06:49 AM
danmilo
danmilo's Avatar
Default Hobbico MkII
Rmbler, I used the Mark I before (non-lithium) and now use the Mark II since I am rolling over to more lithium packs. When charging lithium packs on the Mark II, irregardless of what you adjust the dial to, the maximum rate is 1000 mah. This is spelled out in the owners manual. If you don't have one you can visit either Hobbico's or Tower Hobbies web site to download it for free.
I read it through many times because as you stated, everyone is concerned about overcharging lithium packs. Now that I have used this charger for over a year I still find it to be a great charger for the money. I have nicads, nimh and lithiums. This charger does very good on all three type and I enjoy charging two batteries at once.
Dan:p
danmilo is offline
Dan Matheson
01-20-2008 06:44 PM
busyflyin
05-11-2007 03:17 AM
raceredg
11-05-2006 07:16 PM
usedhippo
06-21-2006 03:29 PM
Bowhunterhd
05-28-2006 03:13 PM
Quick Reply: hobbico quick field charger & E-Flight batt help
Page generated in 0.06541 seconds with 13 queries
