"FREE" Warbirds - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
"FREE" Warbirds
Old 08-08-2005, 04:27 AM
Ken Spencer
Ken Spencer's Avatar
Default "FREE" Warbirds
Not sure if these will interest anyone here, but they are Warbirds, I have drawn and they are electric. Best of all they are FREE downloads found at :
http://users.joplin.com/~wcflyer/freedir.htm
Keep Them Flying ! Your friend, Ken
ID:	333   Click image for larger version
ID:	334   Click image for larger version
ID:	335   Click image for larger version
Ken Spencer is offline
Old 08-08-2005, 03:59 PM
WWI Ace
triplane test pilot
WWI Ace's Avatar
I think they are pretty cool!!! Explain to me how you print them off like that. Do you print on paper in color and glue it to foam or what??
WWI Ace is offline
Old 08-08-2005, 08:28 PM
Ken Spencer
Hi, WWI
I, print the aircraft patterns onto regular 8 1/2 x 11 typing paper. Then roughly cutting them out, and apply the pattern with spray adhesive. Almost any good brand of adhesive will work, though you may want to use one that is foam friendly, if you intend to use the wing patterns also. The fuselage and the tail assembly is 1/32" sheet balsa. It sounds flimsy but becomes quite strong when laminated with the paper. I recommend using a figure eight thread type hinges. I personally prefer using a glue similar to Amberoid to glue this type hinge, it will not wick down and stiffen the hinge thread. Thus allowing a very free movement for the control surfaces. Five minute epoxy works well for attaching the foam wings. The construction of the Aircraft is mainly left to the discretion of the builder, BUT THE LIGHTER IT IS, THE BETTER IT WILL FLY.
Old 08-17-2005, 03:35 PM
olereo
olereo's Avatar
What printing program do you use? Mine prints out just part of the picture...
Anyway, it's a neat idea and I will try to make a P-40...
olereo is offline
Old 08-18-2005, 04:34 AM
Ken Spencer
Hi, olereo
Follow the instructions at the top of the plan web page. Save the JPG files to your computer first. Then using your printer setup, print them to 8 1/2 x 11 paper. If all the file does not print on your page, check your border default on your printer. They maybe moved in from the edge to far keeping the print from printing at 1:1
Old 08-19-2005, 10:09 PM
olereo
olereo's Avatar
I smarted up and read the instructions... Also made a "monster" set using "Tile Print"... Already cut out tailfeathers for large model... will use the smaller one directly from plan tonight. However, I am not familiar with the figure 8 hinge method. Is thjere a referance place to look? I am about to order motor and other stuff for small model... I assume the wingspan for the P-40 is about 18" and the fuse is about 12"... so small motor will do for it... not sure how much motor will be needed for the larger version (26" span approx). I'll use cirrus servo's on the larger model. Thanks for the plans... fun builds...
Reese
Hi, olereo
olereo is offline
Old 08-29-2005, 03:12 AM
bwillhite
Electrons are Cool!
bwillhite's Avatar
Hey Ken, too cool!
Greating from Pittsburg!
Brian
bwillhite is offline
Old 09-03-2005, 09:38 AM
titan74
Hi guys!
How did you make the main wings?..
titan74 is offline
Old 09-04-2005, 05:12 PM
Ken Spencer
Hi, titan74
The wings are made from wall insulation foam. They are cut to the airfoil shape with a hot wire type cutter. Or you can buy them already cut from www.BDSmicroRC.com along with any of the other parts and needed.
Old 09-04-2005, 05:31 PM
Ken Spencer
Hi, Brian
I am not ignoring you ! Just been very busy. Had a great time yesterday at your Outdoor Fun Fly. Looking forward to the next one. Hope you can make it over on the 1st of October.
Keep Them Flying ! Your good friend, Ken
tz250w
Warbird Electrics
12
08-22-2008 09:56 AM
Kosh
Aerial Photography
23
10-30-2007 07:26 PM
Ken Spencer
13
12-30-2006 02:05 AM
Sky Sharkster
WWI Era
10-15-2006 05:24 PM
Sky Sharkster
03-19-2006 04:45 AM
Quick Reply: "FREE" Warbirds
Page generated in 0.11979 seconds with 18 queries
