zero colors & design - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-09-2005, 01:18 PM
arizonajoe
Default zero colors & design
I'm looking for the colors and the design that was used from early models during the war. I remember that they were yellow, with red. Can anybody help
arizonajoe is offline
Old 09-10-2005, 04:05 AM
[email protected]
Depends on the squadron. Different carriers had different stripes. Try the squadron Publications book on the zero. $15
Or you could just do a Google for A6M2. You could check out some of the scale modelers websites. Here's a link to one.
http://www.j-aircraft.com/gallery/navy/a6m2_gallery.htm
geo8498@mac.com is offline
Old 09-11-2005, 04:01 AM
flypaper 2
flypaper 2's Avatar
A good book to get or check out at the library is called Flying Colors. One of my more prized books.
flypaper 2 is offline
Old 09-11-2005, 04:06 PM
arizonajoe
zGEO8498 & FLYPAPER2, Thank you very much for valuable information. I needed help on this project. arizonajoe
Old 09-12-2005, 02:46 PM
CorsairJock
CorsairJock's Avatar
Here is link to the best source of Zero color schemes that I have seen yet:
http://www.rcuniverse.com/forum/ZERO...1738279/tm.htm
CorsairJock is offline
Old 09-13-2005, 12:18 PM
arizonajoe
Thank You CORSAIRJOCK...This was exactly what I was looking for. I'll need more information in the furture of differwent details but this is just great. arizonajoe.r
Old 09-25-2005, 03:30 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Zero Colorschemes
Hi Joe, I've been following the thread, good info. I'm just finishing a GWS Zero (slope kit) that will have a HiMaxx 4200 with 6:1 Cobri gearbox, C.C. 25A ESC and 3C 1320 or 2100 LiPos. I did mine in light gray, like the back cover of "Squadron/Signal Aircraft 59- A6M Zero". Used Rust-oleum "Painter's Touch" Winter Gray#1982, this is about one shade darker than the colors shown on the center pages but matches the back page exactly. I posted a note on "Scale Electric" Forum yesterday regarding a weathering technique using pastel colored pencils, might be of interest. Good Luck! Sky Sharkster
Sky Sharkster is offline
Old 09-25-2005, 10:37 PM
arizonajoe
Hi Mr. SKY, I'd like to see your ZERO. It sounds like it would really move and look well too. I'm almost finished with mine and I'll post descripion soon . Joe
Old 09-25-2005, 11:01 PM
Sky Sharkster
Default GWS Zero
Hi Joe, thanks for the kind words! I test flew the Zero today, it was a touch tail-heavy with the 1320 3S Lipos and a real handful to fly but the 2100 3S cured the problem...I was looping, inverted, rolls (a little slow, need more aileron throw), split S's on the 2nd flight. It is easy to fly unless you get it too slow-them it whips into a tip stall but recovery is quick, a bit more airspeed and everything's OK again. Don't know if you've followed the thread on "E-Zone" regarding the Zero wing incidence, seems it was designed for a less powerful motor and they built-in 3 degrees of wing incidence, which it DEFINITELY doesn't need with higher power motors like brushless. It will "zoom" up off the launch and need lots of downtrim to fly level. I shaved the rear bolt mount 3/32" to raise the wing T.E. during construction and still needed 2 clicks of down trim for level flight at 1/2 throttle. Also, before I added the downtrim I flipped it inverted and it dove down about 30 degrees. The trim corrected that problem, after my heart stopped pounding!
Now I'm just waiting for those "Corsairs" to show up! Good Flying, Ron
Old 09-25-2005, 11:23 PM
flypaper 2
flypaper 2's Avatar
Ron:
A couple of things to make it fly a little better. I bent the ail. wires a bit forward, about 1/8 in. to put in some ail differential. makes it roll more axially and quicker and less chance of tipstalling. Flew like a pattern plane till a servo shorted out. In the middle of building another one.:p
Old 09-26-2005, 09:59 AM
Sky Sharkster
Default Zero Tipstall
To Gord, thanks for the tip, buddy! I think you've helped solve the problem. I used a circle (disc) servo arm to get differential with the pushrods in the rearward holes. got the differential but very little throw, which is why ( I guess) it was sluggish in roll response. Now, using the bend in the torque arms I can use a longer servo arm and get more throw! Good tip, thanks again, Ron
fr4nk1yn
Delta & Flying Wings
14
05-05-2008 01:21 AM
Stan-the-Man
12-02-2007 09:07 PM
Kosh
Aerial Photography
10-25-2007 04:52 AM
Richard Parkes
3D Flying
01-10-2007 12:48 AM
Derick Veliz
Aerial Photography
10-26-2006 04:42 PM
Quick Reply: zero colors & design
Copyright İ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
Page generated in 0.10539 seconds with 13 queries
