Somethin' Extra electric conversion
Old 08-16-2020, 10:35 PM
prowler53
Default Somethin' Extra electric conversion
Well here she is after 17 years of hanging in a bedroom and never flown. I removed all the covering and gave it a fresh look, Made some Mods for the conversion. Added a hatch at the front for battery and a hatch under the front fuse for ESC. Dubro landing gear and 2 1/2" wheels for prop clearance. I have a 13x8 on her right now but probably room for a 14" If I decide to go larger. E-flite Power 46 and 60 amp ESC. 4S 4500 mah Lipo. Extended The Rudder and covered in Monokote. I used Oracal 651 vinyl for the graphics. She still comes in a little tail heavy with everything moved forward, so I'm thinking about a larger battery & prop spinner. 5.4 Lbs right now without adding more weight, so I think I'm going to end up around 6 Lbs when ready to fly. A little heavier than I wanted but I think it should be ok.
prowler53 is offline
Old 08-17-2020, 03:19 AM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
That looks AMAZING! Nice work!
Joe
Turbojoe is offline
Old 08-17-2020, 10:54 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Originally Posted by prowler53 View Post
... I have a 13x8 on her right now but probably room for a 14" If I decide to go larger. ...
Both current and power drawn are proportional to diameter⁴, here they would increase by factor (14/13)⁴=1.35, 35%more.
(Ignoring higher voltage losses in battery, wiring, controller, motor due the higher current).
What's the current draw with the 13"diameter prop?
14" is better but you may need to reduce pitch should current get too high. Current drawn is proportional to pitch (also proportional to #blades, voltage≤ and Kv≥).
ron_van_sommeren is offline
Old 08-17-2020, 11:05 AM
ron_van_sommeren
It is a good practice to have some headroom built in.
About derating motors, controllers, batteries, electronics in general:
Old 08-17-2020, 09:25 PM
prowler53
Joe
Thanks Joe
Old 08-17-2020, 09:27 PM
prowler53
14" is better but you may need to reduce pitch should current get too high. Current and power drawn are proportional to pitch (also proportional to voltage≤ and Kv≥).
I'm not sure of the draw yet....I have a Watt meter ordered and should be here this week.
Old 08-23-2020, 03:04 PM
prowler53
Watt meter arrived but now I'm waiting on my transmitter that is being repaired or replaced because of the faulty scroll wheel switch. I was bored yesterday and took an hour drive to the closest r/c hobby shop. Ended up coming home with an E-flite Night Timber x BNF.
I heard good things about this plane, and thought it would be good to get some practice with before flying the Somethin' extra. Now I just need my transmitter to get flying.
06-28-2017 04:22 PM
02-16-2016 12:19 AM
Doc Austin
3D Flying
01-05-2013 03:19 AM
12
04-06-2011 10:46 PM
sgillmore
04-01-2011 03:37 PM
Quick Reply: Somethin' Extra electric conversion
Page generated in 0.07196 seconds with 13 queries
