Let's talk about servos - Whatever is on your mind
Old 06-14-2015, 02:20 PM
  #276
owensman06
http://www.horizonhobby.com/sport-cu...nology-hbz4480
owensman06 is offline
Old 06-14-2015, 03:15 PM
  #277
Voltron
Voltron's Avatar
Default aileron servos
Check the servo arm location on the aileron that is moving the wrong direction. You may just need to change the arms location 180 degrees on the servo to change the travel direction. If you have not made any changes to the radio programming, I would bet that is the problem.
Voltron is offline
Old 06-14-2015, 08:44 PM
  #278
From what I can detest from the manual the Sport Cub S with SAFE technology is a 4 channel plane so the ailerons must be on a Y lead (ie both servos connected to the same channel) as channel 5 is used to select the SAFE mode and channel 6 for panic recovery.
Does yours have SAFE?
If your does not have SAFE then one of the aileron servo could be on channel 5 or 6 but it will require the 'dual ail' option to be set on your transmitter.
As AEAJR said it is almost impossible for a servo to reverse itself so most likely something was changed when you transferred the electric over to the new fuselage.
quorneng is offline
Old 06-15-2015, 12:03 AM
  #279
Good point. Did not think of that.
AEAJR is offline
Old 06-15-2015, 03:03 PM
  #280
For that fault to arise it would mean that you removed an aileron servo arm and put it back the wrong way round. Did this happen?
If you did not take off the arm but it is indeed now the wrong way round it means it has slipped on its spines as a result of the last crash and is no longer secure. That servo must be replaced before you fly again.
Is there any chance of a picture of the underside of the plane showing both aileron servos, theri arms and links?
quorneng is offline
Old 06-15-2015, 03:54 PM
  #281
I don't believe this is the case, but if the servos are on separate channels using an aileron diff mix or a flapperon mix then you could have accidentally reversed one.
AEAJR is offline
Old 08-26-2015, 06:55 PM
  #282
policetac
Heli Driver/Fixed Trainee
Default Let's talk about types, sizes, how to pick them, etc., whatever you like.
Hello.
I am an absolute beginner to this hobby so a lot of this is brand new to me. Since I don't have a club local to me, my only source for information comes from these forums.
I've got an 60" "Ugly Stick" park model that I'm building from the ground up out of spare parts and dumb luck that is in need of a set of servo's.
Searching the internet for servo's, one thing I've noticed is that many of the servo's being sold are listed as being either "micro" or "mini."
You mentioned at the beginning of your post that you would be discussing size, but unfortunately I think you forgot to cover it.
I've been looking at a set of 5 "Towerpro" MG90S Micro Metal Gear 9g Servo's because they are ball bearing servo's, have the metal gear on them, come with the servo arms, and are relatively inexpensive.
From what I've been hearing, it sounds like I'm going to have a difficult time even getting my plane to fly since it's not any kind of kit or anything and I'm building it out of spare parts and such, so I don't want to spend a lot of money on these, but I do still want to get the right parts for my plane.
Could you please tell me whether or not you think these servo's will work?
Thank you.
policetac is offline
Old 08-26-2015, 07:00 PM
  #283
For a 60" model you need to be looking at larger servos. Look at servos around 40g or more, 9g servos would be far too small and not have enough torque. If there any cutouts or mounting rails installed then probably easiest to get a servo of the correct size to fit the hole, that avoids doing any modifications.
BTW.. a 60" plane isn't really in the 'park flyer' category. Park-Flyer is a term usually used for smaller lightweight planes.
Old 08-26-2015, 07:48 PM
  #284
Voltron
Voltron's Avatar
Hi Policetac, The link below is for an inexpensive 58 gram standard size, ball bearing, metal gear servo. The Vendor is very reputable. I have done business there for several years with no problems whatsoever. http://www.headsuphobby.com/iFlight-...vo-F-565-B.htm
At $11.95, this servo is less than half the price of a name brand servo. The quality is good, I have never had a quality issue with anything I have purchased at Heads Up Hobby.
Voltron is offline
Old 08-26-2015, 09:27 PM
  #285
Save a lot of time and trouble... especially for your first model:
http://graysonhobby.com/dynam-piper-j3-cub-pnp.html
Pick your radio... Note the radio might last you 10+ years if selected well. Or you can choose an essentially disposable radio . The higher end radios mean a higher startup cost but lower long term cost. The economy radio (such as the Dynam 5 ch at Grayson) can serve your needs and do well but you'll want better later.
Old 08-26-2015, 11:05 PM
  #286
policetac
Thank you for the responses.
I've checked out the link provided and I now have a better idea of what I'm dealing with.
I appreciate the help.
Old 07-29-2017, 08:13 PM
  #287
Anyone have any tips on servos?
How to size?
How to mount?
how to fix?
AEAJR is offline
Old 07-29-2017, 11:11 PM
  #288
Tips on servos? Yeah, Jiggle the wires and shake them around while they are powered up and before you install them. Just had a Dymond D60 that jittered out of the box. While powering up pre install to find center and check torque and geartrain, one started moving around on it's own. I could feel it. Low and behold, the signal wire had a cold solder joint where it contacts the board. Easy fix on the bench. Very hard fix in the air.
Check your servos on the bench, fresh out of the box folks.
Old 01-04-2019, 04:47 PM
  #289
Has everyone gone to digital servos or are analog servos still popular? I have used digital servos in my competition sailplanes for years but most of my parkflyers still use analog servos.
AEAJR is offline
Old 01-04-2019, 08:37 PM
  #290
crxmanpat's Avatar
Just depends on what comes in the kits I buy. Most are still analog, but the bigger planes seem to be getting digitals these days.
crxmanpat is offline
Henry111
21
10-09-2011 08:09 AM
08-11-2011 10:55 PM
RCFlyer44
22
03-29-2011 04:55 AM
terrynshed
02-04-2011 08:33 AM
terrynshed
11-19-2010 07:48 PM
Quick Reply: Let's talk about servos - Whatever is on your mind
Page generated in 0.08386 seconds with 11 queries
