How can I get wattage measures?
Old 11-28-2005, 05:39 PM
arizonajoe
Default How can I get wattage measures?
I'm very slow on elec. I need to learn how to obtain wattage info. Is there anybody out there who can help me? I can get a meter to show me how many I'm running,but telling me how or why is what I need to know.
arizonajoe is offline
Old 11-28-2005, 06:04 PM
Bob_CO
Bob_CO's Avatar
You need to plug a watt/amp meter in-line between the battery and the ESC in order to measure the current. You can get one like this. http://www.horizonhobby.com/Shop/ByC...?ProdID=AST101 But there are several brands on the market currently.
Edit: Here is another brand. http://www2.towerhobbies.com/cgi-bin...&I=LXLMV0&P=ML
Bob_CO is offline
Old 11-28-2005, 06:16 PM
Elfwreck
PHD in Crashology
Elfwreck's Avatar
Hey now,
Right, get a watt meter, I know, you said you figured that part out. Also get a tachometer. There are several good ones out there, I use a Glo-Bee. Hook up the watt meter, switch on the power, let it run a few moments and watch the initial voltage drop, hold the tach to the prop and note all the numbers. Change props, take new readings. Do this with a range of props suggested for your motor combo. Also try different brands of props, youi'd be amazed at the differences.
Now, go out and fly the model. Change props, fly again, repeat. Take notes. How do the wattage changes alter the flight? Do different props at the same wattage fly differently? How much do rpm changes effect the flight? You're now learning what these numbers mean. How you apply them comes as you gain experience and notes.
RobII
Elfwreck is offline
Old 11-28-2005, 08:25 PM
Matt Kirsch
Matt Kirsch's Avatar
arizonajoe,
Could you try to better explain what it is that you are looking to achieve?
Watts is a measure of power, the metric equivalent to Horsepower (746 Watts equals 1 HP). Electric Watts or mechanical Watts, it's the same unit. Put 746 Watts of electrical power into a motor, and you will get 746 Watts of mechanical power out, ignoring losses. It takes so much power to make a plane of a certain weight fly in a certain way, so many mechanical Watts to turn that propeller... Because it's a direct translation from mechanical to electrical, and so easy to calculate electrical Watts (Volts times Amps), we work with electrical Watts almost exclusively.
Matt Kirsch is offline
Old 11-29-2005, 12:14 PM
arizonajoe
Thanks alot guys. I'm on my way to understanding elec.R/C. Double thanks to Mr. Kirsch, V x A = W was what I needed to know to get me over a bump in my path.
Old 11-29-2005, 01:16 PM
Matt Kirsch
Careful there, AJ, you're going to make me start thinking I'm clairvoyant or something
Old 11-29-2005, 07:45 PM
Rugar
FAA# OUTLAW!
Rugar's Avatar
LOL @ Matt
Rugar is offline
Old 12-20-2005, 11:17 PM
davidej
Another basic question from a beginner:
That is fairly straightforward for a brushed motor but what about brushless motors? How can you measure the amps?
David
davidej is offline
Old 12-21-2005, 12:06 AM
ForestCam
Bad Influence
ForestCam's Avatar
volts x amps = watts
All can be done with your basic multi meter.
ForestCam is offline
Old 12-21-2005, 12:16 AM
davidej
Yes but how do you measure the current which is divided between three wires - I assume that each carries an AC 120 degrees out of phase.
David
davidej is offline
Old 12-21-2005, 12:20 AM
ForestCam
Bad Influence
ForestCam's Avatar
You don't, you measure it between the battery and the ESC.
Old 12-21-2005, 12:24 AM
davidej
As easy as that!
Thanks.
david
davidej is offline
Old 12-21-2005, 12:25 AM
Big_Bird
Big_Bird's Avatar
David
David, I really don't know why you would want to measure current on the output of the ESC unless you are interested in motor winding imbalance or .... Most of the time people are interested in supply current to the ESC. Please elaborate.
Big_Bird is offline
max-nix
Humor
09-25-2006 03:16 AM
andy120
07-27-2006 08:47 AM
1987tc
Scale E-Powered Aircraft
11
05-07-2006 10:16 PM
thomdoe
03-29-2006 09:21 PM
dogfight
ParkFlyers
10-24-2005 11:27 PM
Quick Reply: How can I get wattage measures?
Page generated in 0.10072 seconds with 13 queries
