E-Flite P-47 bubble top conversion with retracts.
Old 07-08-2008, 03:34 PM
  #451
Prof100
Originally Posted by pd1 View Post
I re tapped the anchor nut and use a 6-32 nylon bolt.
When I hit hard, I hope the wing will release and not break.
Well, as much.
Paul
Paul,
Good idea on using nylon, but I would still like to know the size of the stock one.
Prof100 is offline
Old 07-09-2008, 03:08 AM
  #452
wilmracer
Got the gear dry-fit and couldn't wait to see her on her own legs... grabbed a couple of pictures. Cowl is mostly painted... just need to paint up the motor and the rear-most sections. Gear linkages need to be completed. Figure I've got a few more weeks on this project as I only get a few minutes a day to work. Need to settle on an upgraded power setup.
ID:	72005   Click image for larger version
ID:	72006   Click image for larger version
wilmracer is offline
Old 07-09-2008, 12:25 PM
  #453
pd1
Still Learning
pd1's Avatar
wilmracer, Looks real nice.
Can you get yours as heavy as Grasshoppers?
Paul
pd1 is offline
Old 07-09-2008, 12:44 PM
  #454
wilmracer
You bet I can!!!
I didn't glass this one (may glass the wing before I'm done) so that will help a bit... and I consolidated the ailerons to a single servo to counteract the weight of the flap servo...
If I can get the wing buttoned up this week I'll put everything on the scale sans power setup and start figuring that out.
Old 07-09-2008, 12:59 PM
  #455
pd1
Still Learning
pd1's Avatar
Remember the Grasshopper is the King of heavy.
You'll really have to work hard to match him.
Drive him nuts, put an orange prop on it too.
Paul
pd1 is offline
Old 07-09-2008, 04:58 PM
  #456
Grasshopper
Some Assembly Required
Grasshopper's Avatar
I don't think can get anywhere close to getting it heavy enough. Paul's just jealous that I can fly a plane that is physically incapable of flying. I should have painted mine yellow with black stripes and called it the Bumble Bee.
Grasshopper is offline
Old 07-09-2008, 05:02 PM
  #457
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
Paul, you will appreciate this: I ordered some GWS 9050 props from the LHS and they gave me orange(!). I expressed some mild displeasure and they assured me they only came in orange. Now I know this to be patently false, but I didn't argue. Tom will be pleased to know I will be painting them black.
Paul
Voyager2lcats is offline
Old 07-09-2008, 05:20 PM
  #458
pd1
Still Learning
pd1's Avatar
Orange props are much easier to find if they get lost.
Gnasher crashed his plane in 4 foot high grass last night.
If he had an orange prop on it we would have found it much easier.
But if you don't crash in the tall grass and instead crash on the flight line, I guess black is OK.
Paul
pd1 is offline
Old 07-09-2008, 05:33 PM
  #459
Voyager2lcats
No high grass on my landing/take-off pad. Asphalt runway- although orange shows up nice against it as well- hmm, maybe I will keep it orange!
Paul
Old 07-09-2008, 07:14 PM
  #460
Grasshopper
Paul
He must not be crashing correctly. The prop should be completely burried after a proper crash.
Old 07-09-2008, 08:19 PM
  #461
wilmracer
Come to think of it... I don't think I've had a prop survive a crash. When I do crash it tends to be a quite a spectacular sight. Forget trash bags... if you hit hard enough most planes can fit in a zip-lock bag or two
crashnburn
WWI Era
10-02-2011 02:05 PM
gwong
143
08-06-2010 12:58 PM
jayxer
Warbird Electrics
02-03-2009 03:59 PM
The Swede
Warbird Electrics
03-06-2008 04:18 PM
Rob Schaffer
10
05-20-2007 03:00 AM
Quick Reply: E-Flite P-47 bubble top conversion with retracts.
Page generated in 0.10045 seconds with 17 queries
