Nakajima K9M Kikka WWII Jet
Old 06-11-2020, 10:56 PM
JohnBoren
Default Nakajima K9M Kikka WWII Jet
This is a Nakajima K9M Kikka. Japan had over 20 of these on the assembly line before the war ended. One took flight and it flew only once. My model is a 1/6 scale, spanning 65.6 inches. Overall length is 59.7 inches. To keep the scale intake and exhaust sizes I decided to go with a pair of Freewing 70mm EDF Power System w/ 2957-2210kV In-runner Motors. A set of JP Hobby electric retracts will be used but I am still up in the air about the gear struts. The model will be constructed entirely out of wood. I hoping for a take-off weight between 10 and 12 pounds. The fuselage and engine nacelles are planked with 1/8" thick balsa. The wings were covered in 3/32 sheet balsa while the horizontal and vertical tail were covered in 1/16 balsa. To date it has taken almost one month to get to this point during the build. I had the fuselage designed first but the rest of the parts I designed once the fuselage was under construction.
The model is going together very well with only a few mistakes on my part that I have since corrected in my files. As seen with both engine nacelles installed the framed up model weighs in at 4 pounds even.
John Boren
ID:	188001   Click image for larger version
ID:	188002   Click image for larger version
ID:	188003   Click image for larger version
ID:	188004   Click image for larger version
ID:	188006   Click image for larger version
ID:	188007   Click image for larger version
ID:	188008   Click image for larger version
ID:	188009   Click image for larger version
ID:	188011   Click image for larger version
ID:	188012   Click image for larger version
ID:	188013   Click image for larger version
ID:	188014   Click image for larger version
ID:	188016   Click image for larger version
ID:	188017   Click image for larger version
ID:	188018   Click image for larger version
ID:	188019   Click image for larger version
JohnBoren is offline
Old 06-11-2020, 11:02 PM
JohnBoren
More Build Images
ID:	188022   Click image for larger version
ID:	188023   Click image for larger version
ID:	188024   Click image for larger version
ID:	188025   Click image for larger version
ID:	188027   Click image for larger version
ID:	188028   Click image for larger version
ID:	188029   Click image for larger version
ID:	188030   Click image for larger version
ID:	188032   Click image for larger version
ID:	188033   Click image for larger version
ID:	188034   Click image for larger version
ID:	188035   Click image for larger version
ID:	188037   Click image for larger version
ID:	188038   Click image for larger version
ID:	188039   Click image for larger version
ID:	188040   Click image for larger version
ID:	188042   Click image for larger version
ID:	188043   Click image for larger version
ID:	188044   Click image for larger version
ID:	188045   Click image for larger version
ID:	188047   Click image for larger version
ID:	188048   Click image for larger version
ID:	188049   Click image for larger version
ID:	188050   Click image for larger version
Old 06-11-2020, 11:08 PM
JohnBoren
More Build Images.
John Boren
ID:	188052   Click image for larger version
ID:	188053   Click image for larger version
ID:	188054   Click image for larger version
ID:	188055   Click image for larger version
ID:	188057   Click image for larger version
ID:	188058   Click image for larger version
ID:	188059   Click image for larger version
ID:	188060   Click image for larger version
ID:	188062   Click image for larger version
ID:	188063   Click image for larger version
ID:	188064   Click image for larger version
ID:	188065   Click image for larger version
ID:	188067   Click image for larger version
ID:	188068   Click image for larger version
ID:	188069   Click image for larger version
ID:	188070   Click image for larger version
ID:	188072   Click image for larger version
ID:	188073   Click image for larger version
ID:	188074   Click image for larger version
ID:	188075   Click image for larger version
ID:	188077   Click image for larger version
ID:	188078   Click image for larger version
ID:	188079   Click image for larger version
ID:	188080   Click image for larger version
ID:	188082   Click image for larger version
ID:	188083   Click image for larger version
ID:	188084   Click image for larger version
ID:	188085   Click image for larger version
ID:	188087   Click image for larger version
ID:	188088   Click image for larger version
ID:	188089   Click image for larger version
Old 06-12-2020, 09:49 AM
Looking good John!
Old 06-12-2020, 01:12 PM
riverrat
circa: 1946
riverrat's Avatar
Default Subscribed
Nice!!!
riverrat is offline
Old 06-13-2020, 04:00 PM
JohnBoren
Default Fiberglass
I fiber glassed the engine nacelles last night. Because of their complex shape I tacked the 2 oz cloth down with 3M 77 contact spray that I applied very lightly. It worked great. I then covered the cloth with West Systems Epoxy. The two photos show the nacelles before and after the resin has been applied.
John B
ID:	188091   Click image for larger version
Old 06-13-2020, 10:06 PM
WOW! what a project. I take it you have your own laser cutter and CNC skills. Makes this old fellow jealous. We could only dream of this stuff years ago.
A lovely model.
Old 06-13-2020, 11:00 PM
JohnBoren
Yes, I purchased my laser about a year and half ago. I've been building model for 50 years Been learning Auto Cad for about 20 years now. Still Lots of stuff I don't know how to do. The laser was the best tool I ever purchased.
John Boren
Old 06-13-2020, 11:27 PM
Thanks John.
It is only the CAD part that puts me off looking further into it. If I was younger I wouldn't hesitate. I'm nearly 73 and been building since primary school too. Always scratch drew plans and scratch built because in NZ there was very little available but balsa and aero cement back then. Things have sure changed.
Maybe I could gain enough knowledge to cut wing ribs or the basic stuff but that would be about it.
Just as a curiosity, what make/model cutter? Thanks
Old 06-19-2020, 06:02 AM
JohnBoren
Default Intake Ducts
Today I constructed the air intakes for my nacelles. I used 1/64" plywood. Before I glue them in place I will add a wrap or two of carbon fiber tow in a couple places along the duct to help prevent it from getting sucked inward.
ID:	188101   Click image for larger version
ID:	188102   Click image for larger version
Old 06-19-2020, 10:13 AM
John
Just a thought and It might be difficult to construct but if the nacelle formers were extended so the inlet duct could be clued to them the duct would not only be well supported against collapsing but the nacelle itself would be considerably stiffer.
Old 06-19-2020, 10:46 AM
I have to say also that my Laser has paid for itself many times ...... and there's no real need for CAD as I can draw in Paint ... save to JPG .... import to laser and vectorise ... cut.
I have to admire the build .... superb work.
Old 06-19-2020, 03:14 PM
JohnBoren
"@quorneng" I certainly could have designed the nacelles so the intake duct would rest against the inside of a couple formers but that would have required more work on my part and I'm lazy. This would be something to consider on the next one that gets built. I'm pretty sure the plywood ducts are strong enough as is but for almost no weight gain I can simply wrap a piece of Carbon fiber tow around the duct in one or maybe to locations and glue them in place with thin CA.
I really do appreciate your comments
John Boren
Old 06-24-2020, 05:04 AM
JohnBoren
Default Engine Nacelles
Today I mounted the engine nacelles. They need to be flared into the front and rear of the wings. I also installed the landing gear to confirm she is sitting at the right angle. I need to machine a steel 1-1/4" long extension to the nose leg but for now I'm simply using a wood dowel.
John Boren
ID:	188111   Click image for larger version
ID:	188112   Click image for larger version
ID:	188113   Click image for larger version
ID:	188114   Click image for larger version
Old 06-24-2020, 06:20 PM
pmullen503
What software do you use to vectorise?
pmullen503 is offline
Old 06-26-2020, 10:57 PM
JohnBoren
She is on her wheels.
John Boren
ID:	188116   Click image for larger version
Old 06-26-2020, 11:36 PM
Thumbs up on that John.
Old 07-14-2020, 04:02 AM
JohnBoren
A few more build images.
ID:	188128   Click image for larger version
ID:	188129   Click image for larger version
ID:	188130   Click image for larger version
32
12-03-2013 12:21 AM
Joe 1320
06-03-2013 02:53 PM
Quick Reply: Nakajima K9M Kikka WWII Jet
Page generated in 0.17762 seconds with 118 queries
